Question about Logitech Dual Action for Pc (963292-0403:) Game Pad
This is a test
Thanks
  • Ekse Sep 24, 2008
    Saunalahti adsl actually
  • Roberta Smith
    Roberta Smith May 11, 2010
    you use verizon ?
    Robert
    Brigadier General:
  • 5,158 Answers
Should have used verizon they have people that test for you.... "can you hear me now"
Robert
Posted on Sep 24, 2008
Tip
Field Test
The test mode display is activated through the test mode command: <b>*3001#12345#</b>. Once you enter this command, you are given a list of options, including 'Field Test'. Select Field Test and then hit 'Enabled'. You must power down the phone and power it up again to get out of the test mode menu. The test mode screens may vary somewhat between different firmware versions and providers.<br /> Once you power up the phone you are given a new menu choice at location 10 called 'Field Test'. There are several different test mode screens. Type in a test number to get the screen listed below. Alternatively you may use the arrow buttons to move between the 199 different field test screens. Entering test number '0' will disable the test mode, but will still allow you to access the test menu.<br /> If you are using the field test mode and are unsure what the screens mean then hold down the # key for about four seconds to get a brief description of the screen. Repeat holding the # key to return to the test mode values. <b>Thanks to L. Tee for this tip</b><br /> If you would like to see what is behind the test mode screen then keyguard the phone, wait until the 'press unlock and then *' screen disappears, and then press one of the numeric keys to see the regular screen. <b>Thanks to L. Tee for this tip</b><br /> Note: If you make or receive calls while in test mode, you may not be able to change the speaker volume. To turn off the field test mode you can select field test '0' or enter a few digits and then clear these digits.
on Jun 19, 2011 | Cell Phones
Not heating up right
Hi,when Element does not heat up correctly
1. Test for power to determine that the unit is receiving the correct voltages.
2. If the power voltages are correct and you have standard surface burner elements:
1. Test Surface Burner.
2. Test the Receptacle.
3. Test the Burner Switch.
3. If the power voltages are correct and you have solid-disc elements:
1. Test the solid-disc element.
2. Test the Burner Switch.
4. If the power voltages are correct and you have radiant heating elements:
1. Test the radiant heating element.
1. Make sure the controls are set properly that the oven selector switch is set correctly and that the temperature switch is set to the desired temperature. Where applicable, make sure the oven timer is set to manual.
2. Make sure the oven door is slightly ajar as per your owner's manual.
3. If nothing else on the Range, Oven or Cooktop is working then:
1. Check the circuit breaker or fuse
2. Test for power
4. Test the broiler element.
5. Check the oven thermostat.
6. Check selector switch.
7. Check oven cycling relay.
REMEMBER YOU ARE WORKING WITH 220 VOLTS - USE EXTREME CAUTION .
Please if no experience, please contact a skillful personnel for assistance.
Thanks for using fixya..and please don't forget to rate me 100%.
Thanks.
Oct 28, 2010 | Ovens
Error Code "TEST"
Just had the same problem & found the following solution via the web :-
1. When tESt shows hold down both the ON/OFF Button & the START Button together & let the Test proceed holding the two buttons down for the entire test (Approx 3 Minutes ) .
Continue to hold the " buttons down until the word Done appears.
After which you should be able to proceed with the normal wash cycle
May 28, 2009 | Hotpoint Ultima WF860 Front Load Washer
Diagnostic jump test wrong terminals - now Suzuki won,t start
Thanks for your reply. It turned out that the fuel pump quit at the same time as the diagnostic test so I'm back on track now. Should be running by tomorrow. Thanks again.
Mar 19, 2009 | 1994 Suzuki Sidekick
No sound
on google right test my sound card.
this will then give you onfo on testing sound card use the link.& follow the instucions ok m8
thats what i done and it worked for me it takes about 10 mins to do.
many thanks lee.
Jan 03, 2009 | Acer Aspire 5600 Series 5630-6951 Laptop
SGH-G600
thanks for that the sound on my g600 is much louder now and my music is louder too great thanks alot
Nov 04, 2008 | Samsung SGH-G600 Cellular Phone
Printronix T5000r syntax to print
It's been several years since I had to program these.
try this
4 sets of double quotes
or this
double quote, single quote, single quote, double quote.
It's too bad I didn't have my manuals back when I was working for Pitney Bowes. If those don't work I'll see if I can Google the PCL manuals on Google.
Jul 14, 2008 | Printronix T5306 Thermal Label Printer
Motorola RAZR V3 Cellular
you should take the phone to a professional and ahve them test it
Jun 02, 2008 | Motorola Mobility RAZR V3
Logitech Dual Action for Pc (963292-0403:) Game Pad Logo
24 people viewed this question
Top Logitech Video Game Consoles & Games Experts
Zhenya Ogorodnikov
Alun Cox
Are you a Logitech Video Game Console and Game Expert? Answer questions, earn points and help others
