Question about GE (PSS26MSRSS) Side by Side Refrigerator
Water supply line
How do u remove water supply line from the icemaker door so it can be replaced
  • smithteena0 Sep 24, 2008
    thank you that helps a lot to know and i appreciate the prompt reply
  • 1,543 Answers
If you want to replace just the water line going inside the door, you are out of luck. The water line is foamed in place inside the door and is not replaceable without replacing the entire freezer door. If you want to just remove the door, the water line disconnects by pushing the collar on the insta-push fitting toward the center of the fitting while pulling on the tube, all of which is located behind the toe kick plate near the bottom hinge of the freezer door. The same door is used on the PSS26MRSASS, PSS26MRSCSS, PSS26MRSDSS, and the PSS26MRSESS. It is part # WR78X11742 and runs about $500. (note: even if you don't like what you just read, accurate info on your repair question deserves a "FixYa" rating, not just a "helpful" or "tanks for trying".)
Posted on Sep 24, 2008
  • Carl Schulzetenberg
    Carl Schulzetenberg Sep 24, 2008
    Just because the answer was not what you wanted to hear, it was correct. (a "FixYa" rating)
    Don't shoot the messenger !
Frigidaire icemaker not getting water supply at all
Remove back panel and locate the water supply line. Remove line and blow out with air compressor. Somehow, these lines can clog.
Aug 18, 2014 | Refrigerators
Mfd2561 icemaker and water dispenser not working
The water supply line is possibly being restricted by lime tuild-up
  1. Turn water off, then start your inspection at the saddle valve attached to your cold water line, then go up to the water valve attached to the unit, Remove the water line and inspect for lime build-up or for foreign material. You may have to replace both valves. Link should help you
  2. https://www.repairclinic.com/RepairHelp/Refrigerator-Repair-Help
Oct 18, 2017 | Maytag MFD2561HE Bottom Freezer French...
I moved my GE TFX277PFSB (new in 1994) side by side to my enclosed sun porch 2 years ago when i got a new fridge for the kitchen. Today, I decided to run a water line to it to allow it to make ice again. ...
Make sure the arm on the icemaker is in the down position,if it is up and locked in place the icemaker is off. If it is down and the icemaker is turned on,each time it got cold enough the to cycle the icemaker(usually about a hour) the icemaker started and for 7 years power was sent to the water inlet valve to fill the icemaker and the icemaker side of the water valve is burnt up. The water valve has 1 inlet teh house water supply attaches to and 2 outlets 1 for icemaker and 1 for door dispenser
Gene
Aug 07, 2011 | Kitchen Ranges
No water coming into ice maker
First, make sure your icemaker is on. if the switch has been acidentally flipped, that is why you have no water coming in. next see if the line is pinched behind the fridge.also check to see that a child or maybe someone cleaning didnt turn it off at the water supply line. if neither of these,check to see if you water supply is working. shut it off,remove the line, turn it on again with a glass or bowl underneath to be certain you have a water supply. if that is ok, check your water line again that goes to your icemaker, it may need replacing.
Jan 13, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice is not being made. How can I get the ice to start being made?
Start with the most basic. Is the right amount of flow getting to the unit? First check. On most units from the door with a water dispenser. You should get app. 8 oz. in 10 seconds. If not, remove water line from unit. Turn water back on with line in a bucket. If just a stream then supply valve is bad even if it is new. If not reconnect line and check water output from first water valve that line connects to. Just unhook line from that valve that supplies water to the water filter to see if flow is there. If so then other than kinked lines then filter or secondary valve in door. Can cycle icemaker. Press and hold button on ice maker. If water is good. Icemaker defective. Replaced many.
Oct 15, 2010 | LG Panorama 20.5 Cu. Ft. Side-by-Side...
My refrigerator water dispenser is not working. I
In the back of the refrigerator there is a water inlet valve. It will have three hoses one coming in, two going out. A 1/4 line for the icemaker and a 5/16" for the water dispenser. If your icemaker is working and you dont have water at the door the valve to the water dispenser is faulty, you need to replace the water inlet valve. If neither icemaker or water dispenser is working chek your water supply line
Feb 22, 2010 | Refrigerators
New water valve not filling the ice maker.
take the supply line to water valve and blow into it
you will feel it if it is clear if blocked remove tube
and clean
Apr 13, 2009 | Refrigerators
JCD2389GES water dispenser over-runs and also starts on own
Low water pressure can be very problematic when it comes to icemaker/water dispenser water inlet valves. If there is low water pressure to the valve, the valve may not seat correctly causing icemaker fill tubes to freeze, icemakers to over/under fill or water dispensers to leak or not shut off fast enough. Check the water pressure to the valve like this:
Turn off the water supply to the refrigerator and remove the water supply line from the water inlet valve behind the refrigerator.
Put the end of the water line in a bucket and turn the water supply on. There should be a good stream of water jetting from the tube. If there is not, the water supply shut off valve is probably plugged and needs to be replaced or there could be an in-line water filter that needs to be replaced. Only use a drill style (non-self piercing) saddle valve http://www.repairclinic.com/SSPartDetail.aspx?s=t-584723-%3d%3di584723&PartID=584723 for the water supply.
If there is a good stream, the water inlet valve that the water line connects to at the back of the refrigerator should be replaced.
*Note: Reverse Osmosis (R/O) systems should never be used to supply water to icemakers.
TheRepairGuru --- www.repairclinic.com
Jan 27, 2009 | Jenn-Air JCD2389G Side by Side...
Whirlpool refrigerator stopped making ice.
If there are ice cubes in the icemaker sitting there waiting to be dumped then the problem is in the icemaker. If the icemaker is dry then you have a water supply problem, even if you have a water in the door working.
1.Check the fill line inside the freezer at the icemaker, if it is clogged with ice then remove this ice and replace the water valve.
2. Check the water supply. Turn the water supply off, disconnect the water line from the Ref, turn the water back on an fill a small glass. If the water supply is good the solenoid on the water valve should be checked. This is done with an OHM meter.
If you got this far and need more info to DIY - ronbuice.com
Dec 13, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Icemaker won't make ice
First, check to make sure you have water pressure at your supply line. (flex hose) If you have pressure and the icemaker is cycling, (arm moving up and down on its own) you most likely have a defective water inlet valve. This is the valve that the supply line connects to. Water is fed to this valve through your flex hose and then passed through a solenoid to your icemaker when the solenoid is energized.
Mar 04, 2008 | Refrigerators
GE (PSS26MSRSS) Side by Side Refrigerator Logo
288 people viewed this question
Top Refrigerators Experts
Sal De GO PATS
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
