Question about HP Computers & Internet
External dvd burner
I purchased an external dvd burner that requires 2.4 ghz processor speed and I have 1.81 ghz. Can I use it?
  • HP Master
  • 32,281 Answers
You can try, most likely not.
Posted on Sep 24, 2008
Why does my iMAC 4,2 reject blank DVD-Rs but plays burned DVDs?
Your machine has a DVD-rom drive, but not a DVD-burner. There is a difference.
Basically, you can read and play the DVD's, but the drive is not capable of burning them.
Nov 04, 2012 | Apple iMac G5 MA064LL/A Desktop
External disc reader/ burner
Short answer: Yes, it will.
Slightly longer answer: 3 things will be important:
1) The version of USB your computer has will matter (the higher the version, the better; recommend a minimum of USB 2.0)
2) The version of operating system is important. Assuming you're on a Windows/Intel-based system, XP would be the lowest/oldest OS that would be practical
3) Speed of processor and amount of RAM plays an important role here too - again, higher number on the processor, and more RAM will (generally speaking) provide a better experience.
Oh, and depending on what you want to do with it, you'll need software, such as CD/DVD authoring software (try www.tucows.com).
Jun 01, 2012 | Acer Computers & Internet
I just bought a USB External/GE24 Super Multi Rewriter, with 24x speed. my problem is, when it burns, it burns EXTREMELY slow. I used to have an 8x burner, that would burn in about 5 minutes, and this one...
Hello mklvon,
Welcome to FixYa.Com!
I would like to recommend that you first take a look at your computer. Check if you have a USB 2.0 High Speed port. Reason is because although you have a USB 2.0 Ext Multi-Burner but your connecting it to a USB 1.0 or USB 1.1 port, the Multi-Burner will only run as fast as the USB port can transfer data.
Another time I would like to recommend is for you to take a look at the USB cable itself. As it is an Ext. Multi-Burner it may require a power USB port w/c is the reason why most Ext. Burner's have a Y-connector that is one USB port on one side and the other side branches off to 2 USB ports as it required extra power. If it is, you may want to consider your options as to getting a powered USB port.
And lastly, I would recommend that you take a look at the type of discs you are burning on to. Not all DVD R are the same. Whilst some have 24x speed some can have 4x speeds which can also affect the burn speeds.
Regards,
Deathschythe33
Aug 22, 2011 | LG External DVD Burner USB 2.0 GSA-4120B...
I have an HP Mini 1151NR PC, with an Intel 1.60 GHz processor and 1 GB RAM, and 1024x576 pixel screen resolution. I want to purchase a Steinberg Cl1 Advanced Integration USB Studio for music/audio...
If you plug in an external monitor, you can go much higher than the 1024x576 that you are locked into used the mini monitor on your computer. Your issue is going to be raw computing horsepower. A 1.6 GHz processor will not handle (at least not well) something that requires a 2GHz processor. There are nothing out there that turns a 1.6 into a 2 or greater.
Sorry.
Semper Fi,
Z
May 05, 2017 | HP Computers & Internet
How long does it take to burn a 2 hour movie? I have 512 MG DDR SDRAM with 3200+ AMD Athlon XP Processor.
That will depend a bit on the speed of the dvd drive and the media speed. Basically should take about 30-40 minutes. On a faster drive it should take about 25. A 2 hour movie should almost fill a dvd 4.7gb in size. Those times are for a internal burner not a external usb burner.
A dual layer dvd should take twice as long but from my experience it doesn;t seemt to take more than a few minutes longer than a normal dvd which is strange but nice.
Make sure you have lots of space on C and try not to be running anything other than the burner software to max out on the speed. And don't worry if you toast a few dvd's at first. They are cheap.
Jul 31, 2010 | LG GSA-2166D DVD RW Dual Layer Burner
Cannot install final cut pro.....the software says my macbook pro(macbook3,1) does not have minimum system requirements. my mac.... 2.2 ghz 800mhz core 2 duo 4gb ram 2x2gb @ 667mhz GeForce 5600m gt 128mb...
yes it seems that your laptop dose not meet the minimum requirements to install final cut pro software.you will need to purchase a laptop with the correct requirements,sorry.
ken
Apr 04, 2010 | Apple MacBook Pro Laptop Computer with...
Can Windows 7 be installed on X05? I get ACPI incompatible BIOS and have updated to last known one. Please help!
The only issue i can see is if your your ram has not been updated since leaving the factory, you will notice from the tables W7 requires a min of 1GIG and your machine leaves the factory with 256mb(dependant on country possible) so check your ram. I run windows 7 on 2GB and its great, your machine will take 2GB. The Samsung X05 was released 2004 and the NVIDIA Geforce 4 should be fine. i would point out drivers and compatability but windows 7 so far is really good but driver support is crucial
hope this helps
Here is the requirements for Windows 7
Windows 7 minimum specs
  • 1GHz CPU
  • 1GB of RAM
  • 16GB of drive space
  • DirectX 9-capable graphics card or integrated chip (true of most releases 2002 and after)
  • BELOW YOUR MACHINE SPEC
  • MPN nx05tp8e0a/suk
    Key Features
    Laptop Type Thin and Light Laptop
    Use Corporate Business • Small Business • Business
    Processor Pentium M 1.5 GHz
    Installed Memory 256 MB (DDR SDRAM)
    Display 14.1 in. XGA TFT LCD
    Operating System Microsoft Windows XP Professional
    Mobile Technology Intel Centrino Mobile Technology
    Processor
    Processor Manufacturer Intel
    Processor Type Pentium M
    Processor Speed 1.5 GHz
    Motherboard
    Chipset Intel 855GM
    Bus Speed 400 MHz
    Memory
    Installed RAM 256 MB
    RAM Technology DDR SDRAM
    Max Supported RAM 2 GB
    RAM Speed 333 MHz
    Installed Cache Memory 2048 KB
    Hard Drive
    Hard Drive Capacity 30 GB
    Storage Controller Type Ultra ATA 100
    CD / DVD
    CD / DVD Type CD-RW/DVD-ROM
    Optical Drive Read Speed 24x (CD) • 8x (DVD)
    Optical Drive Write Speed 8x (CD)
    Optical Drive ReWrite Speed 8x (CD-RW)
    Display
    Display Tech XGA TFT LCD
    Screen Size 14.1 in.
    Display Max. Resolution 1024 x 768
    Video
    Graphic Processor NVIDIA GeForce4 440 Go
    Graphic Bus Interface AGP x4
    External Video Resolution 1920 x 1200
    Audio
    Audio Output Type Headphones • Sound card • Speaker(s) • SPDIF out
    Audio Input Type Microphone
    Operating System
    Platform PC
    Technical Features
    Expandability 1 x Type I/II PC Card Slot, 1 x Memory Stick Card Slot
    Expansion Ports 2 x USB 2.0, 1 x IEEE 1394a (FireWire), VGA out, RJ-11 (modem), RJ-45 (NIC), S-Video out
    Input Method Keyboard • Scroll Button • Touchpad
    Networking
    Networking Type Integrated 10/100 Network Card • Integrated Wireless LAN
    Data Link Protocol Ethernet • Fast Ethernet • IEEE 802.11b • IEEE 802.11g
    Modem
    Modem Type Fax / Modem
    Analog Modulation Protocol ITU V.90
    Battery
    Battery Run Time 2.2 Hours
    Battery Technology Lithium ion
    Dimensions
    Width 31.5 cm
    Depth 25.9 cm
    Height 2.4 cm
    Weight 2 kg
Nov 05, 2009 | Samsung X05 Notebook
Which is better laptop deal?
Hi !!
Ofcourse 2.4 ghz is better than 2.1 ghz but its not a very big difference if price difference is more than 100$ than go for first one else second one is good and the most important thing i want to mention is that it all depends upon your needs you havent mention for what purpose you are going to purchase. But both are enough for gaming, daily use and for techie as well.
Hope that helps
Thanks
Jul 10, 2009 | Computers & Internet
Samsung SHW08A DVD±RW doesn't burn dvd+r
Please let me know your Operating system and the program you are using to burn the dvd, as well as the word-for-word message you recieve, and I will get back to you right away.
May 20, 2008 | Samsung SH-W162C 16x16x8x6x5x4 DVD +/-...
Does not read dvd
Is This The lightScribe ?
Heres Some Basic Information, that may help Resolve Your Problems:-
Minimum system requirements Operating system Microsoft Windows XP and 2000 SP4 or later (the latest service pack is recommended). Interface IDE interface. Processor/RAM 800 MHz Intel Pentium III processor or equivalent , 2.2 GHz Intel Pentium IV processor or equivalent recommended. (Actual drive performance depends on PC configuration). 128 MB of RAM (256 MB is recommended for video editing). Hard drive space required 1GB free for software installation. 10 GB free for DVD video disc creation. 18GB free for double-layer DVD editing. Video resolution 1024 x 768 video resolution with a minimum of 16 bit color required for video capture, authoring, and editing. ** Please do note Rate This post Until Your problem Has Been resolved **
Thanks mike.
Feb 26, 2008 | HP dvd740i DVD±RW Dual Layer Burner
Computers & Internet Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
