Question about Elmo Projectors TRV-35H Slide Projector
Trying to replace the bulb - Elmo Projectors TRV-35H Slide Projector
    Novelist:
  • 170 Answers
Contact Bulb Direct.com. Ask for part number 8549-1. Their number is 800.772.5267. Service info available for download from the Elmo website.
Posted on Nov 18, 2008
We have just replaced the bulb on our Sanyo TV PLV65W. We have replace bulb before and always worked. This time it keeps asking for new bulb and will not come on
I cant say for certain, but it is either a faulty bulb you've replaced, or poor connection between bulb and contacts.
Try getting a new bulb in case it is faulty!
Feb 02, 2018 | Sanyo Televison & Video
How do I replace light bulbs in a Bernina sewing machine model 1080?
Check the bulb model number old versus new and make sure you have the same number bulb. The bulb number should be on the base of the bulb somewhere. If the bulb has tabs sticking out of the base, check to see that they are placed such that both tabs are on the same plane on the bulb base. Some bulbs have offset tabs that only go in one way to the socket. Try rotating the bulb 180 degrees and insert it again to the socket before trying to rotate it. Check your manual for bulb replacement procedure. Make sure also that you didn't rotate the glass bulb out of its base when you pulled the old one out, leaving the old base still stuck in the bulb socket. If this is the case, unplug the machine and use needle-nose pliers to remove the old bulb base before trying to replace the bulb.
Jan 14, 2015 | Bernina Sewing Machines
I just replaced my turn signal bulb,now the arrow stays lit and it also blinks vey fast when useing it.
It sounds like you used the wrong bulb, should be a two element bulb or you might have inserted a two element bulb incorrecelty there are two retaining points on the bulb, one is higher up the bulb base and they must be aligned properly. Try replacing the bulb again and be sure it is the correct bulb.
Oct 04, 2014 | Cars & Trucks
I replaced the primer bulb and I can't get the gas
A common mistake while replacing primer bulbs is getting the lines reversed. Try switching the lines, then push the primer bulb and see if it draws in fuel.
Sep 02, 2014 | Garden
Headlight not working
TRY ANOTHER LIGHT BULB.BUT DONT LET BARE HANDS TOUCH BULBS BECAUSETHEY ARE HALOGEN.OILS FROM YOUR FINGERS OR HAND WILL CAUSE THE BULB OVER HEAT AND BLOW.IF YOU TRY ANOTHER BULB AND STILL DONT PROBLEM COLUD BE BULB SOCKET CORRODED OR DAMAGE OR WORN BULB CONTACTS.LOOSE POOR GROUND WIRE OR SHORT IN WIRES TO BULB SOCKET.
Jul 12, 2010 | 2005 Chevrolet Impala
I am trying to replace the front parking light bulb.
you will have to remove the headlamp to get to the bulb.
Jan 08, 2010 | 2002 Buick LeSabre
My light bulbs keep burning out prematurely on my garage door opener.
I tried a REVEAL(brand) 40 WATT DOUBLE LIFE CEILING FAN LIGHT BULB , and almost two months later it still works. It is sold at Home Depot in Illinois. The filament is much thicker than any of the other heavy-duty bulbs I have tried, and that seems to be the difference. The REVEAL bulb is the only one I have tried that has lasted this long.
Feb 01, 2008 | Sears Craftsman LiftMaster Chamberlain...
Elmo Projectors TRV-35H Slide Projector Logo
166 people viewed this question
Top Elmo Projectors Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you an Elmo Projectors Office Equipment and Supply Expert? Answer questions, earn points and help others
