Question about IBM Wheelwriter 30 Typewriter
Wheelwriter 2 we had no power for a week with hurrican IKE, I cannot now get two of our machines to work. the line space lights blink, but I replaced the batteries, and they still blink. Please help asap, I need these units!!
  • jbetts Sep 29, 2008
    the 1 and 3 line are blinking continuous
  • IBM Master
  • 3,594 Answers
If you can remove the cover chech the connectors on thr board especially thos from the keyboard. It would help if I had a better description of the lights which ones are blinking and how many beeps.
DickyO
Posted on Sep 29, 2008
Wheelwriter 5 turns on but not working. the light for line spacing keep blinking
Could be many things. If you know how to remove the case look for debris on or around the PC board and power supply.
DickyO
Feb 10, 2011 | IBM Wheelwriter 6 Typewriter
Light is blinking for both 1 AND 2 FOR LINE SPACING AND MACHINE WON'T RUN AT ALL, HOW DO YOU CHOOSE LINE 1 OR 2
You probably have a bad keyboard, you can try my yip under WW1000 or contact Geo. Beters Co. @800-392-8085 for a KB rebuild.
DickyO
Jan 04, 2011 | Lexmark Wheelwriter 1000 Typewriter
IBM Personal Wheelwriter 2 Lights for spacing
Many possibilities; Check to be sure the printwheel is properly installed, then try turning it on while moving the flat keyboard connectors around if it works see my tip under WW1000.
DickyO
Oct 27, 2009 | IBM Office Equipment & Supplies
When I turn on my wheelwriter 1000 it beeps 5 times then the #1 and #2 line space lights blink. The keys are frozen as if the typewriter is on off mode. I powered the machine down and unplugged it and...
First be sure the printwheel is installed properly, and look for debris in that area. Put some light oil on the silver shaft that the carrier slides on (WD40 is good).
DickyO
Jul 30, 2009 | IBM Office Equipment & Supplies
IBM Personal Wheelwriter 2 by Lexmark not working
It sounds like the keyboard is going bad see my tip under WW1000.
DickyO
Jun 24, 2009 | IBM Wheelwriter 30 Typewriter
Power company turned power off for line repairs - tv no go since
most likely fuse, main a/c filter, shorted bridge-diodes. this occurs often when surges of up to 220v line is run into house. we've had alot here in south texas after HURRICANE IKE. good-luck mch
Feb 20, 2009 | Sanyo DS32224 TV
IBM wheelwriter 15 Series II not working
It sounds like the keyboard is bad. Check the two bflat connectors from the keyboard to the PC board, if they are connected ok a keyboard is in order.
DickyO
D
Dec 30, 2008 | Lexmark Wheelwriter 15 Series II...
Lights blink and machine beeps
Check the flat connector that goes to the indicator lights the edge of the keyboard sometimes wears into itand causes a reset sequence.
DickyO
Oct 06, 2008 | Lexmark Wheelwriter 1000 Typewriter
Keyboard Frozen -1 and 2 line spacing indicator lights blinking
You probably have a bad keyboard, see my tip under Wheelwriter 1000.
DickyO
Sep 17, 2008 | Lexmark Wheelwriter 1000 Typewriter
LED 1, 2, 3 blink machine doesn't work
If it beeps three times then the line space lights blink
1 the batterys are installed incorectly
2 no batterys are installed
3 the batterys are weak or dead
Feb 22, 2008 | Lexmark Wheelwriter 5 Series II Typewriter
IBM Wheelwriter 30 Typewriter Logo
134 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
Jim Keysor
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
