Question about RIM BlackBerry Pearl 8100
Button stuck my number 1 button is stuck it wont let me use the number or in a text it wont let me use the e or r letter....what can i do?
  • amynpeck Sep 24, 2008
    it was working if you held it down really hard and now it just doesnt work anymore... the button will move just wont work. what else info do you need?
  • Jalal Sordo
    Jalal Sordo May 11, 2010
    u mean its pressed or its not working??
  • RIM Master
  • 1,800 Answers
Okay
first i need u to take that phone apart and locate the number one button on the board like:
this for example :
Posted on Sep 24, 2008
When I text I need tro know how to switch from numbers to letters on keypad
helps to know what make phone it is they do not all work the same
Feb 05, 2015 | Verizon Communications Cell Phones
My blackberry curve starting texting weird, i pressed 1 letter in a text and that letter plus 5 other letters would appear, til i got to the point i couldnt text at all. now its just went to screensaver...
Hi
seems like you have a problem with the keypad. may be a water damage or moisture damge keypad near the track pad. thats make your keypad malfunctioning and it just keep sensing like you keep pressing a key while even if you are not using your phone. you can try remove your battery and put in a bowl of rice for 1 day or you can try drying your phone with air dryer. if its still the same issue then you may have to clean your keypad contact. thanks.
Oct 16, 2011 | RIM BlackBerry Curve 8520 Smartphone
How to undo predictive text v3
Welcome to Fixya. If you want to undo the preddictive text just follow the guide below.
1. From any text entry screen (ie. when you are writing a text message), press the top center button, the one above the directional wheel.
2. Press on Entry SetUp
3. Select the Primary Set Up or Secondary Setup by choosing your preferred input mode among the ones below. Us the wheel by pressing on the right arrow to change mode:
ITAP: it's a built-in software which predicts the word you are typing. THIS IS PREDICTIVE TEXT
TAP: enter individual letters and numbers by pressing the keys multiple times. Ie. for the letter F press the number 3 button three times.
Tap Extended: enter individual letters, numbers and symbols by pressing the keys multiple times
To change from one mode to the next you can select it by pressing the top center button from a text entry screen, and Press on Entry Mode. Shortcut: you can press the # key on your phone when you are writing a message and you will see abc1 for your primary mode, 123 for numeric; @ for symbols; and abc2 for your secondary mode.
If you have questions please let me know. Thanks for using Fixya.
Apr 04, 2011 | Motorola Mobility RAZR V3
How do you change the text message settings to TAP instead of Abc
How to set up Text Entry Mode?
2. Press on "Entry SetUp"
3. Select the "Primary Set Up" or "Secondary Setup" by choosing your preferred input mode among the ones below. Us the wheel by pressing on the right arrow to change mode:
  • ITAP: it's a built-in software which predicts the word you are typing.
  • TAP: enter individual letters and numbers by pressing the keys multiple times. Ie. for the letter "F" press the number 3 button three times.
  • Tap Extended: enter individual letters, numbers and symbols by pressing the keys multiple times
  • Jun 11, 2009 | Motorola Mobility RAZR V3
    Wireless keyboard will not type numbers. Only the corresponding symbols will show up. The shift key is not down nor is it stuck down.
    Although Shift key is not pressed down, maybe the electronics are messed up due to shock if you dropped the keyboard. Turn off Caps Lock, go to text editor of your choice and try to type numbers together with some letters. If you get big letters, then Shift button is pressed down.
    In both cases, just to make sure, try your keyboard on some other computer and see if it works.
    If you find out that Shift button is always pressed, than it is a hardware problem that may or may not be fixable.
    Jan 15, 2009 | Dell Wireless Keyboard Optical Mouse w0147
    Trouble entering message into itext sms text messenger
    I updated someone else's instructions to make them more clear...
    Instructions to a Sakar sms text messenger - sending text messages.
    Press the NUMBERS/LETTERS below the keypad icons.
    Example: SEND a message from one Messenger to the other
    • For the messenger (USER 1) receive a message
      • Press SMS button,
      • then the RECV button and leave it like that - don't do anything
    • On the messenger (USER 2)sending the message
      • Press SMS
      • Type with the numbers/letters (NOT THE PICTURE)
      • Click SEND (it will display P/i ?)
      • click the (I C Q chat) button with the smiley face
    • The message will appear on messenger (USER 1) display
    Dec 29, 2008 | Sakar Cyber Gear Slide Click Text...
    Need instructions for the itext SMS text messenger from Claire's
      • Press SMS button,
      • Press SMS
    Dec 28, 2008 | Toys
    The iText SMS Text Messenger wont work
    I had the same problem because I was pushing the colored buttons. Push on the number/letters between the buttons and it will work.
    Dec 15, 2008 | Teac AG-D8900 Receiver
    To form a jumbled words
    Using VB as an example
    Dim intLength as Integer
    Dim y as Integer
    Dim arrOut( ) as String
    Dim TempLetter as String
    intLength=len(text1.text)
    ReDim arrOut(intLength)
    Randomize
    dim boolDone as boolean ' flag to track unfilled positions
    Write a loop that gets each letter from text1, then choose a random number from 1 to intLength
    Get the existing letter, then put it into a different position in the arrOut, based on the random number. If something is in that position, try again:
    for y=1 to intLength
    tempLetter = mid(text1.text,y,1)
    boolDone=false
    do while boolDone=false
    r =CInt(Int((y * Rnd()) + 1)) 'Get random # from 1 to length
    if arrOut(r) ="" then 'see if spot has been used
    arrOut(r) = tempLetter
    boolDone = true
    end if
    loop
    next 'get next letter in text1
    text2.text=join(arrOut,"") ' concatenate arrOut, no delimiter.
    Hope that helps.
    Jul 16, 2008 | Computers & Internet
    RIM BlackBerry  Pearl  8100 Logo
    32 people viewed this question
    Top RIM Computers & Internet Experts
    Computer Repairing
    Computer Repairing
    David
    Martin Murray
    Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
