Question about Sharp Aquos LC-42D62U 42 in. LCD HDTV
OSD Display won't go away on my screen.
I have a Compaq monitor. The OSD display is "stuck" on the screen. I have tried holding down menu, exit, rebooting, etc. but it will always come back, or one of the choices will load (such as contrast, degausse, etc.) Is there someway to disable this? I hate to buy a new monitor just for this problem.
  • 1 more comment
  • Anonymous Oct 22, 2008
    hi,i have the same problem with my pc,osd main controls keeps flashing saying it is locked then flashing saying it is unlocked,its driving me mad,have you found a solution yet....thanks
  • nikom_18 Dec 11, 2008
    Menu selection on the monitor wont go away. simply flashes, and I have tried turning off the computer, rebooting, holding down menu button and nothing seems to work.
  • mattpima Mar 15, 2009
    reply i have the same problem with my monitor a viewsonic vx924 i have not figured it out yet either
5 Suggested Answers
SOURCE: How to get response to Menu choices
try turning tv off and on to reset the controls
or see if you can scroll to reset option
Posted on Jan 10, 2008
  • 8457 Answers
SOURCE: power light blinking green and cannot turn off or display anythin
power inverter board is dead.
need a new one.
Posted on Sep 14, 2009
  • 834 Answers
SOURCE: audio on all, no video
your av board has failed very espesive repair
Posted on Sep 16, 2009
  • 210 Answers
SOURCE: Sharp AQUOS 65" LCD, No Picture Menu Access
change picture mode from (STANDARD)or other modes and put tv in CUSTOM then you will be able to change the contrast
make sure all cables are in
Posted on Dec 15, 2009
Monitor display says OSD Lockout /no signal input how to fix this?
This document pertains to LCD monitors .
One of the following messages appears on the screen (over the items being displayed).
OSD Lockout
OSD Lock-out
... or similar message.
This message occurs when the Menu button on the front panel is pressed for more than 10 seconds. OSD lockout prevents the OSD menu from opening on the screen when a button is accidentally pressed.
NOTE: The button may be different and the procedure might vary on some monitors. Please check your monitor User Guide to find the exact procedure if this procedure does not work.
To remove the OSD Lockout message, release the Menu button (if something was pressing against it), and press and hold the Menu button again for about 10 seconds - until the message goes away. If the OSD Lockout message does not go away, the button may be stuck or the hardware behind the button might have become defective.
Aug 31, 2013 | Dell Computers & Internet
Osd volume control won't go away
bad switch i monitor.
fix switch
or new monitor.
its just a switch, it closes and OSD pops. on demand by said switch, OSD is a timing processor in the display that has the OSD code in it , "program"
Mar 25, 2017 | HP Computers & Internet
My HP 1730 monitor is showing "OSD Lock Out" message. How can I remove this msg?
The following site has step by step instructions on steps you can try:
I'll paste them below: All computer monitors, whether they are LCD or CRT style, have a built-in feature called the on screen display (OSD) lock out that prevents users from viewing any images on the monitor. If your computer screen has accidentally been set to the OSD lock out setting, there are several different ways you can remove the lock out, depending on the make and model of your particular computer monitor.
1 Power your computer completely off and then remove the monitor cable from the port on the back side of the computer case. Reattach the cable and make sure the pins are correctly screwed in all of the way. Power the computer back on and check to see if the OSD lock out message is still being displayed.
2 Check the manual that came with your computer or monitor and locate the troubleshooting section if you are still receiving the OSD lock out message. Find the OSD lock out heading and read the method that your particular model of monitor uses to remove the lock out. Follow the instructions to remove the lock out.
3 Attempt generic lock out removal procedures if you no longer have the manual that came with your monitor. Press and hold the "Menu" button located at the bottom end of your monitor for 15 seconds and wait to see if the OSD lock out message disappears.
4 Press the "Menu" button again if the lock out message remains on the screen. Use the arrow buttons to navigate through the main menu options. Highlight the "Settings" or "OSD Menu" option and then hit the Menu key again to access the new list of settings.
5 Scroll down to the "OSD Lock" heading. Use the arrow keys to change the setting to "No." Hit the Menu key again to return to the main menu. Scroll over to the "Exit" setting and then hit the Menu key a final time to exit the menu setting and remove the OSD lock out.
Mar 01, 2011 | HP 1730 LCD Monitor
"OSD LOCKED" box on my screen
The OSD can be enabled or disabled by pressing and holding the Menu button on the front panel for 10 seconds. If the OSD is locked, the warning message OSD Lock displays for ten seconds.
* If the OSD is locked, press and hold the Menu button for 10 seconds to unlock the OSD.
* If the OSD is unlocked, press and hold the Menu button for 10 seconds to lock the OSD.
OSD stands for "On Screen Display." It is an onscreen configuration menu included with various monitors. When you press the MENU button or one of the other buttons on the front or side of a monitor, the onscreen display may appear. The OSD typically includes monitor calibration options, such as brightness, contrast, and color adjustments. Some OSDs may also include horizontal and vertical position controls as well as tilt and keystone adjustments.
If you can't make adjustments to the monitor settings using the OSD interface, the onscreen display may be locked. You may also see the phrase "OSD Locked" appear when you try to change the settings. Some monitors include an option within the menu called "OSD Lock", which you can turn on or off. If this option is available, simply turn OSD Lock off and you will be able to make adjustments to the settings.
If your monitor does not include the "OSD Lock" option, you may be able to unlock the OSD by pressing and holding the MENU button on the front or side of the monitor for several seconds. If you try this method, be patient! It may take up to 15 seconds for the OSD to unlock.
Dec 07, 2010 | Dell Computers & Internet
Unable to adjust the settings for brightness and contrast .
To adjust the display settings:
1. Press the flywheel control. The main menu appears.
The current display settings appear across the top of the main menu.
2. Rotate the flywheel to highlight an option. The name of the
highlighted option appears in the center of the menu.
3. Press the flywheel control to select the highlighted option, then
rotate the flywheel to adjust it.
Some options can only be enabled or disabled. There are also some
options that contain additional menus.
4. Repeat Steps 2 and 3 until you have made all your changes.
5. Rotate the flywheel control until Exit is highlighted, then press
it to exit the OSD control system.
Contrast increases or decreases display image contrast.
Brightness increases or decreases display image brightness.
Horizontal Size increases or decreases the width of the display image.
Horizontal Position moves display image to the left or right side of
the screen.
Vertical Size increases or decreases the height of the display image.
Vertical Position moves display image to the top or bottom of the
Pincushion curves the sides of the display image inward or outward.
Trapezoid increases or decreases the trapezoid distortion of the
display image.
Degauss removes magnetic discoloration from the display image.
Recall returns most options to the original factory default settings
if the monitor is currently using a preset video mode. (See the “Video
modes” section in this guide for information about the factory preset
Advanced Option opens the Advanced Option menu. Color opens the Color
Manager menu.
Language changes the display language for the OSD control system.
User displays information about the monitor’s preset modes.
OSD Manager moves the OSD control window on the screen.
Exit closes OSD control system.
Jun 21, 2010 | Gateway EV 910 19" CRT Monitor
The OSD screen is up and won`t dissengage(after trying the 10 second hold down) , also the video display say`s switch the cable leads , I don`t understand. The menu,+,-, auto buttons won`t work. What might...
try powering off your monitor and disconnect the cable at both ends. switch the ends if that doesn't work try another cable.then turn the monitor back on see if the osd menu went away.
Mar 23, 2010 | HP RY117AA w2408 24" Widescreen LCD
Osd locked
Unplug the monitor from under the screen. Leave it off for a min. If OSD returns, it's a bad monitor. Maybe a button is stuck ?
Jun 13, 2009 | Gateway FPD2275W LCD Monitor
Compaq FP 7317 LCD Monitor
Check the buttons on your monitor for possible shorts. Sometimes pressing a sequence of buttons while turning the monitor on will lock the OSD.
Aug 02, 2007 | Compaq FP 7317 17" LCD Monitor
Sharp Aquos LC-42D62U 42 in. LCD HDTV Logo
718 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
