SMTP server to use with Sharp fax machines (UX-B800SE and UX-D1200SE)Posted by...
<a href="http://www.smtp2go.com/blog/smtp-server-to-use-with-sharp-fax-machines-ux-b800se-and-ux-d1200se/">SMTP server to use with Sharp fax machines (UX-B800SE and UX-D1200SE)</a>
<span>Posted by <a href="http://www.smtp2go.com/blog/author/admin/">mi6</a> on </span>August 19, 2009 - 4:06 am
<span>Filed under <a href="http://www.smtp2go.com/blog/category/uncategorized/">Uncategorized</a></span>
Some Sharp fax machines require a certain type of SMTP server in order to be able to send emails. SMTP2Go provides an SMTP server that authenticates senders based on their 'from' email address, meaning that it works with fax machines that are unable to send an SMTP username or password.<br />
Two examples of SMTP setup procedures for popular Sharp fax machines are below:<br />
Sharp UX-B800SE and UX-D1200SE Broadband Fax SMTP setup
In the 'Network Settings' area, enter smtp2go.com as the SMTP server, and <b>UNCHECK</b> the box 'POP before SMTP'. Try entering either port 2525, 25, or 587 as the outgoing SMTP port. Then, make sure you are sending 'from' an email address that is registered with SMTP2Go.<br />
See a sample screenshot from the UX-B800SE fax below (click on it to enlarge):<br />
<br />
<p><a href="http://www.smtp2go.com/blog/wp-content/uploads/2009/08/sharp_fax_ux-b800se_smtp_setup.gif"><img src="sharp_fax_ux-b800se_smtp_setup_small.jpg" /></a><br />
Please note that Gmail's SMTP server doesn't work, as it not only requires a username/password, but it also requires that SSL/TLS is used.<br />
Please note: some fax machines may still have a problem sending - if this is the case, use the IP address of 207.58.142.213 instead of smtp2go.com as the SMTP server.<br />
SHARETHIS.addEntry({ title: "SMTP server to use with Sharp fax machines (UX-B800SE and UX-D1200SE)", url: "http://www.smtp2go.com/blog/smtp-server-to-use-with-sharp-fax-machines-ux-b800se-and-ux-d1200se/" });
<span><a><span>ShareThis</span></a></span><br />
