Question about Whirlpool Washing Machines
Whirlpool aqualine 1100 AWM1866. The drum fills with water but the program gets no further. Drum doesn't turn even when the programme is moved on manually
  • 101 Answers
SOURCE: zanussi washing machine wont spin
check the drain hole when you start the machine if the water is coming back out , if yes that means your dump valve is bad.
Posted on Apr 23, 2008
  • 17 Answers
SOURCE: Drum will not turn.
Sounds like you've got something stuck in between the drum and tub the best way to check is through the heater at the rear of the machine. Could also be the motor or drum bearings have seized if its the drum bearings there's usually brown oil coming from the back of the drum. Take the belt off to see if either the drum or motor can be turned manualy. hope this helps.
Posted on Dec 22, 2008
  • 850 Answers
SOURCE: The drum is stuck - it will not move
overloaded & unballanced has mabe pulled drum away from the rear bearing!
& jammed iself!
only way now is to disconnect power & water & undo cabinet to inspect it!
Cheers rob.
Posted on Jul 28, 2009
  • 4 Answers
SOURCE: how to repair a F 11 fault on a DYSON CR01 flow check
f11 fault code is a problem with the main power board (could be blown fuse) or a blown board check the fuse the board is behind the back plate in the bottem right corner (looking from the back of the machine.(!unplug before you take apart!)
Posted on Sep 17, 2009
  • 57 Answers
SOURCE: The drum doesn;t turn during wash or spin cycle
Kindly remove the back panel of the unit and check whether the belt is properly fixed if it is ok means check the wire connection if everything is fine. kindly check the motor humming sound once the water is filled if you find the humming sound means kindly replace the motor
Posted on May 18, 2010
My Estate washer ETW4400WQ1 will fill with water then run for about 2 minutes then stops. I can let it sit for about 20 minutes and go back to it and then turn it on and it will run for about 2 minute
this sounds as if the drive motor for the drum to rotate has some sort of obstruction to it's turning freely , unplug unit then remove the lower back panel , locate drive motor ther on bottom (round thing) see how difficult it is to rotate the drive belt one complete drum rotation with your hand , if drum does not turn freely then i suggest looking further for a missing drum roller or maybe a forign object getting caught down in drum lip seal
Feb 10, 2015 | Whirlpool Estate TAWS750PQ 27-Inch Washer
Whirlpool 6th sense washing machine
All washing machines have a water level sensor, this can be a tube into the drum that leads up to a switch normally attached to the inside higher up, what happens is the tube gets clogged up with muck and gives a false reading, which needs cleaning out.
Another problem may be your input valve normally a sngle cold water input, the valve can get clogged with limescale and its just slow to switch off even when the power is off. The default is a closed position.
Try switching the machine off at the plug as soon as it finishes, if it starts filling up its the input valve, these can be under twenty pounds on popular auction websites.
May 11, 2014 | Whirlpool Washing Machines
Fills with water correctly, will not go to next cycle
Hi ,, ok lets try some fault finding,,, try putting the washing machine on a no or low temp programme like wool,, or even the fill empty spin , see if it moves then,, if the programmer moves through then spins, i would assume the thermostat is broken,, if it moves through but does not spin , it may be the heating element,, if it does not move at all in any programme i would assume the programmer has a problem
Nov 14, 2013 | Whirlpool Washing Machines
Water continues to fill into the washer drum on the spin cycle.
Hi
You could have a stuck solenoid valve
Try this: Set the water temp on cold. Turn on only the hot water.
Does hot water try and fill the drum?
If so then there is a problem with the hot solenoid.
Next set the water on hot. Turn on only the cold water. Does cold water try and fill the drum ?
If so then there is a problem with the cold solenoid.
Jan 05, 2011 | Whirlpool LTE6234D Top Load Stacked...
May 18, 2010 | Whirlpool LHW0050PQ Front Load Washer
How to repair a F 11 fault on a DYSON CR01 flow check
May 29, 2009 | Dyson Flowcheck CRO1 Front Load Washer
Rotating programme unit stops mid cycle, all programmes
according to that i think the problem come from timer after you fix this problem pleas donot select your program during conncting electrical power thankyou
May 27, 2009 | Whirlpool AWM5145/2 Front Load Washer
Washing Machines Logo
605 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
