Question about Kitchen Ranges
Does anyone have any idea how to obtain a basic VW Transporter T4 2.5tdi(year 2000) handbook that covers basics like tyre pressures and how to change lights and tyres when you get a puncture. The workshop manual is too detailed.
  • Kreesha Fletcher
    Kreesha Fletcher May 11, 2010
    chris07551: Thanks for lowering the bar here on FixYa. I guess you feel like they deserve that treatment? You've misspelled pressure by the way - how would you like to be judged on that? Should I assume you are an idiot just because you misspelled a word?
  • 1,543 Answers
Try posting under another topic. Don't know too many kitchen range service personel will be able to help you very much.
Posted on Sep 24, 2008
    Master:
  • 726 Answers
Have to be a ******* not to no how to change a tyre and the presurre and y is it kitchen
Posted on Oct 06, 2008
Tyre pressure 255 35 20 on vw transporter 1.9tdi Tyre pressure on vw transporter 255 35 20
The "Tire" pressure I written on the side of the tire, it doesn't matter what size it is. Different manufacturers and tire ply have different PSI
Mar 04, 2015 | Volkswagen Transporter Cars & Trucks
How done reset tyre persure light on vw cc 4 motion
i would check all the tyre pressures and then vw says to press the "SET" button to store the new pressure and the light should go out, if light stays on will have to be inspected by VW dealer
May 10, 2014 | Volkswagen Passat Cars & Trucks
Vw transporter steering gator replacement
front tyre off
undo the steering link (track rod) from front tyre hub.
take the outer track road off and you are on the gaitor.
replace gaitor ad refit.
Jan 28, 2014 | 2001 Citroen Xsara Picasso
Tyre Pressures: The Handbook for my April 2002 reg. V70 Estate gives two tyre pressures for both the front and the rear tyres, but I am getting misleading advice about which is the correct one to use. At...
Hello, any pressure in between is fine, these are recommended pressures, i personally look at tyre wear when putting pressure, if its wearing on the outsides it means it has not enough pressure, if it wears in the middle it has too much pressure, as a general guide 32psi is used at most tyre shops, extra 100kg does not make much differance to a 2 ton vehicle, otherwise you would be changing tyre pressure every time you fill up your fuel tank!!!!
Mar 07, 2011 | 2001 Volvo V70
VW Transporter 1993
drive in reverse for a month or so
or option 2 take it to salvage and turn it into the next batch of coke cans
there is no giving back milage just rolling back but this is an eligal practice and it is never a good idea to mislead somone by going to a salvage yard and purchasing a new computer from same year make and model to change the milage count
or if analog it is not sugested to change your dash just to apear to have less milage
Jan 10, 2010 | 1993 Volkswagen Eurovan
I want to know the tyre pressure front and rear daytona 1200
Yup nice question. For any vehicle accurate tyre pressure will give you better tyre life, low running cost, etc. Here is a chart for car tyres click here.
For bikes i havent found any chart. basically in india rear tyres having 100/90 18inch maximum tyre pressure is 32psi. front tyre having 2.75P or 80/90 18 inch uses 24 psi pressure. and do check your tyre pressure twice a month.
Dec 12, 2009 | 1995 Triumph Daytona 1200
Dash warning light has come up on my vw eos, looks kinda like a horsehoe with an exclamation mark, any ideas?
if yellow this is most likely your tyre inflation indicator warning.
this means that one or more of your tyres has defated or inflated outside expected limits (do not worry)
1. check your tyre pressures are correct.
2. switch on the engine and let light come on.
3. press and hold the reset button with the same horseshoe icon which is situated near your gear lever in the middle console after several seconds the light should go and and your tyre pressure warning system is reset and ready for any change in prssure. if this does not work consult your nearest certified VW dealer they will be happy to assist.
Sep 16, 2009 | 2008 Volkswagen Eos
Dont know the tyre pressure for my vw transporter 2003 1.9 tdi
There should be a recommend tire pressure sticker on the drivers door by the latch, may be one in the glove box. There is also a maximum inflation rating on the tire it self but that's not what the vehicle recommended for a comfort ride. The one on the tire is it maximum pressure that should not be exceeded. Good luck and hope this helps.
Jul 01, 2009 | 2005 Volkswagen Microbus
Dont know the tyre pressure for my vw transporter t4 2.5 tdi
Way too low. I have the same vehicle. Pressure should be at least 55psi all round, depending on load.
Mar 10, 2009 | 2005 Volkswagen Microbus
Tyres and pressures
220kpa (kilopascal) = 32 psi 30 bar = 435 psi Cool that would be worth watching from a distance. but I suspect it should be 30 kpa which is the same as 0.30 bar which would be 4 psi also worth checking the tyre manufacturers the handbook pressures are for OEM tyres, other tyres may have a slightly different recommendation,,,
Nov 10, 2008 | 2004 Moto Guzzi Nevada 750 Club
Kitchen Ranges Logo
233 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
