I cant find the fuse that operate my wipers i dont have a owners manual
Use a test light with the circuits turned on as some fuse won`t show being good unless the circuit is on to send power through the fuse.if the fuses are good then run a separate ground wire to the wiper motor and make sure you have a good connection at both ends.if it starts to work then you will have to connect a ground wire to the wiper motor.if it doesn`t work then you can tap the motor with a small hammer with it turned on if it starts to work then the motor will have to be replaced as there is an internal problem with it,
