Question about Canon imageRUNNER 5570 Copier
IR 5570 Error code
I keep getting the error sode E000840-0001 when i fire the copier up
  • 2 more comments
  • Johnny Coro
    Johnny Coro Sep 24, 2008
    i keep getting the error sode E000840-0001 when i fire the copier up
  • Johnny Coro
    thank you.
  • Berihu Nurhusien Nov 25, 2008
    Yes, I encounter the problem E000840-001. would you help me?
  • kinnardikon May 05, 2009
    In the morning when I come in the printer on the network shows offline. So I have to restart the copier every morning. Any suggestions?
Subject:E840 Indicated in response to damage on the Fixing Roller Trust StopDetails:<Problem>Damage to the Fixing Roller Thrust Stop leads to the indication of error code E840. At times, it can also indicatecode E001/E004.<Cause>The strength of the Fixing Roller Thrust Stop [1] is not adequate and over time, it tends to show damage, failingto prevent the Fixing Roller from moving to and from. Or, the damaged stop can fall to the Shutter DriveAssembly to cause the shutter to malfunction, also resulting in an error.
<Factory Measure>Modify the method used to shape the fixing roller thrust stop to increase its durability.
Servicing Work:If any of the foregoing symptoms is noted, or in the course of a service visit, replace the existing Fixing RollerThrust Stop with its new type.
Posted on Feb 19, 2012
Home position error the fuser shutter.could be a cracked fuser roller.if not will need an upper fuser assy
Posted on Sep 24, 2008
Canon ir 400 error code 051
I m E220 Error how to clear the error of Ir 400
Jul 29, 2011 | Canon imageRUNNER 400S Copier
E0025 error code in machine ir 6570
check the toner bottle.place it properly and lock properly if still error code appears check bttle drive assembly and motor.
Jan 04, 2011 | Canon imageRUNNER 5570 Copier
Canon ir 5055 has an error e000004-0010. how di I fix this?
This is a fixing error code - there is too much temperature difference detected by the thermistors. Mostly a error reset will take care of the problem. You have to get into service mode first. Press the additional function key, then press the 2 & 8 keys at the same time, then the additional function key again. Then copier, function, clear, err, then OK. This clears the error code from the copier. Then power cycle the copier and the copier should be operational. If this doesn't work then you will have to have a technician fix it. DO NOT keep resetting the code. There is something wrong with the copier that needs to be taken care before major damage is done to the copier. Good Luck
Dec 08, 2010 | Canon imageRUNNER 5570 Copier
Have a canon ir-5570 w/ error E00000-0010 will not allow me to reset code Any ideas? Tried the reset procedure of ad.funct 2 & * adfunc will not go into mode
press ad.funct. then press 2 & 8 keys at the same time,
then press ad. funct. , copier display shows setup mode go to (function)
tab and press clear error.
Aug 20, 2009 | Canon imageRUNNER 5570 Copier
Error code E000025-00001
there is a toner feed motor over currente detection error, there is a toner botle motor connection detection error.
1- check the connector for any fault in connection.
2- replace the motor
Mar 19, 2009 | Canon imageRUNNER 5570 Copier
Canon imageRUNNER 5570 Copier Logo
3,045 people viewed this question
old marine
old marine
