Question about MT&V (MTV-AUTO) 6.5" TFT In-Dash Color TV Monitor Car Video Player
Tv antenna how do i wire up my tv antenna in my car for my in dash dvd player
  • 360 Answers
What type of dvd player is it? does it have an internal tv tunner?
Posted on Sep 24, 2008
The radio works and plays fine but if i put a dvd or cd in no volume the dvd does play though just no volume
Are you running the audio through an amplifier? If so, it sounds like you are using the blue wire (power antenna remote turn on) instead of the blue/white wire (amplifier remote turn on). The power antenna remote turn on turns off when leaving tuner mode, turning the amp off.
Nov 07, 2012 | XO Vision X341BT 7-Inch In-Dash Touch...
How do i take the dvd safety feature off so i can drive with the dvd player on..
There is a wire that you are supposed to hook up to your emergency brake or another source to let it know your are parked. That same wire usually relies on a ground. I just grounded mine to a good ground under the dash and it worked great. Hope this helps and good luck!
Jul 10, 2010 | T-View TView (DVD170TV) Motorized 7"...
Need wiring diagram for DVD PLAYER ASSY DL-06LS-M1
i'm trying to hook up a dvd player to my lcd tv.i can play a movie through the tv but i cant record tv on to the dvd player.i only have antenna tv can you please solve this problem for me.
Jan 15, 2010 | Akai LCT3201TD 32 in. LCD Television
It don't play audio through cd or dvd
are you running audio through an amp? if you are, you are probably using the power antenna remote wire instead of the amp remote wire.
Nov 16, 2009 | Audiovox VM9512 Car DVD Player
Kenwood KVT-512 iphone compatibility
Just ignore the airplane mode prompt and if your wiring is correct everything should work.
With my BMW I had to connect both the solid blue (pwr ant) wire and the blue with white stripe (p conn) to the solid blue wire from the factory harness.
It isn't obvious that either of these are needed as the KVT-512 has it's own power supply but the way most factory power amps are installed the power from the KVT-512 is not used and the car manufacturers power amp needs to be turned on.
If you are listening to the radio the pwr ant wire will turn on the power amp, this didn't seem obvious because the BMW doesn't have a power antenna. And when you are using the DVD player or the iPod connection you need the P Conn wire to turn on the car power amp as the ant pwr is disabled because you are no longer using the radio and Kenwood assumes you will not need the antenna so no power to this lead.
Solder all three wires together and you should have sound all the time.
Jul 01, 2009 | Kenwood KVT-512 Car DVD Player
I have a vcr/dvd hooked up to my present tv with a antanna. How do i hook up the digital converter. so thatI still could use vcr. Thank You
It depends on brand of converter. In Radioshack they have one with AV-in ports (for $56 (-$40 coupon = $16). So TV signal going trough antenna and DVD/VCR going trough AV-in of converter to the same antenna of TV. Or you will have to hook up the CONVERTER - ANTENNA IN VCR/DVD - Antenna OUT VCR/DVD - ANTENNA IN TV. And you will use the remote of converter to switch the channels.
Good Luck
Jan 10, 2009 | Philips Magnavox DVD/VCR Dual Player
On the Back of the DVD Player there are probably two blue wires. One is for the amp turn on and the other is the power antenna wire. Whats happening is when you turn the radio on the blue used for the power antenna is trigger and puts out a 12vlt signal to push the power antenna up.. So when you look at your factor car sure the wires are correct..on one wire is gonna be for the amp turn on and the power antenna. use the amp turn on the to a different wire that is connected to the factory amp. You can get a diagram from your dealership. With the correct wires in the right positon, you will get sound out of your vehicles speakers.
Oct 25, 2008 | Car Audio & Video
MT&V (MTV-AUTO) 6.5" TFT In-Dash Color TV Monitor Car Video Player Logo
139 people viewed this question
Top MT&V Car Audio & Video Experts
xxxxxx xxx
Are you a MT&V Car Audio and Video Expert? Answer questions, earn points and help others
