Question about Canon PIXMA iP3300 InkJet Photo Printer
Printer pulling to the rght
I have a canon ip3300,the paper feeder feeds the paper down and than the paper pulls to the right.I read that its the rollers but how do I fix it or clean the rollers or maybe replace if there's no other options.
  • Anonymous Nov 19, 2008
    I have the same problem, but I don't print labels. It also doesn't feed thru the printer and the ink is all on one line?
Do you print labels with this printer? It seems like someting is either stuck to the roller or jamed in the paper path.
Posted on Nov 10, 2008
Paper transport works not properly, 3 flashes orange LED
First make sure the printers well connected and the power supply properly plugged.
  • Remove any previously loaded paper.
  • Check out the printers Auto sheet feeder/front feeder for any paper jams and remove manually any visible stuck papers.
  • Turn the printer off and on.This also helps in automatically removing any stuck papers that may not be manually removed.
  • Make sure there is no foreign objects in the Auto sheet feeder.
  • Make sure you load a fair amount of plain papers in the feeder,that is,reduce by half the amount you feed into the feeder.
  • In case the printers rear cover had been removed,fit it properly by pressing it firmly until it fully fits into the rear of the printer.
Hope this helps.Thanks!
Please rate this answer.
Oct 26, 2011 | Canon PIXMA iP3300 InkJet Photo Printer
The printer keeps telling me it's out of paper, which it isn't
1> Open the sheet feeder cover and pull out the paper support.
Set paper, aligning the right edge of the paper to the cover guide with the paper's print side facing up.
Pinch and slide the paper guide to the paper's left side.
Note: Make sure to set paper lengthwise. Setting Credit Card sized paper long-side down by mistake may cause a paper jam.
Pull down the paper output tray supporting with both hands.
Pull out the extension completely.
Ensure that the Power lamp and the Auto Sheet Feeder lamp light.
Note: If the Cassette lamp lights, press the Paper Feed switch to light the Auto Sheet Feeder lamp.
If the Auto Sheet Feeder lamp does not light even after pressing the Paper Feed switch, Paper Source in the printer driver may be set to the setting other than Paper Feed Switch.
Nov 11, 2010 | Canon PIXMA iP4200 InkJet Photo Printer
Canon ip3300 paper feed not working properly
There is a small switch on the bottom left on the front of the printer that was selecting envelope feed instead of paper feed. Changing this fixed the problem.
Jan 14, 2010 | Canon PIXMA iP3300 InkJet Photo Printer
When I try to print only one side of the paper is pulled down
Probably you have a object which blocks paper from left side on feeder.Look carefully using flashlight in the feeder.If you don't see anything the printer must be disassembled.
Nov 27, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Canon mx300 printer feeder pulls unevenly causing paper jam
the left side of the printer pulls the paper causing the printer to jam when trying to print
Apr 03, 2009 | Canon PIXMA MX300 All-in-One Printer
Paper feed on Canon i 350n ink jet printer
If the paper is lodged too far into the printer and can't be removed:
Press the power button to turn the printer off.
Pull firmly on the paper to remove it. If you can't reach the paper because it is too far in, raise the front cover and remove the paper from the front of the printer.
Close the front cover.
Press the power button to turn the printer back on.
Resend your document to print.
Ensure that:
The paper is a recommended paper for inkjet printers.
You do not force the paper down into the printer when you load it. For example, if you are loading letter or A4 size paper, the top edge of the paper should extend above the top of the sheet feeder.
The printer is on a flat, level surface.
The left paper guide is against the side of the paper.
You do not load too much paper in the sheet feeder. Depending on the thickness of your paper, the sheet feeder can hold up to 100 sheets of paper.
The left paper guide does not cause the paper to bend in the sheet feeder.
Your printer feeds regular paper as expected. If regular paper feeds without causing problems, load the envelopes vertically against the right side of the sheet feeder. Make sure the paper guide is against the side of the envelopes.
Envelopes or the appropriate specialty papers are selected in the printer driver.
You are using a paper or envelope size supported by your printer.
May 13, 2008 | Canon i350 InkJet Printer
Jammed paper
Ensure that:
Apr 28, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
Paper feed problem
Sound like something foreign is in paper path
Dec 24, 2007 | Canon PIXMA MP600 all-In-One InkJet...
Paper Jam Error
check the paper feed section of the printer. it may be item stuck in the paper path. causing the paper jam senor to stay on. also it know for these printer to have a waste in full. this will stop all workings of the printer. as these printer only have small waste ink pad in them. Need to know if the printer is flashing just green or if it flashing green led then a orange one.
Sep 23, 2007 | Canon PIXMA iP90 InkJet Printer
Canon PIXMA  iP3300 InkJet Photo Printer Logo
121 people viewed this question
old marine
old marine
