Question about Palm Treo 755p Smartphone
Constent reboot - flashing Access Powered
No access to phone or any other options. Tried holding button down with battery re-install but said no when asked about deleting data. Any other options?
Thank you
Bob
robert.mckay@pw.utc.com
  • 5 more comments
  • ama328 Oct 17, 2008
    I tried to hard reset but all I am getting after the confirmation to reset is the Access Powered screen and it does nothing after that.
  • Anonymous Nov 01, 2008
    Same problem, but the Hard-reboot does nothing. It asks to delete all data, then reboots in a loop.
  • Anonymous Mar 12, 2009
    my treo doesn't reboot it has a flashing " accessed power" screen.
  • kfisk209 Mar 21, 2009
    my phone doesnt stop rebooting.i cant do anything with the phone.it is jsut constantly rebooting.PISSING ME OFF
  • jodi1972 Apr 02, 2009
    My palm is stuck on the screen where you tap it with the stylus to calibrate the screen. It goes from corner to corner. thats it. wont proceed to powering on the phone. HELP!
    Ours is driving us nuts! we have reset it over and over and now its stuck on the screen where u tap the targets with the stylus. it wont go past there....
  • mashiii22 Apr 15, 2009
    My phone constantly has the same problem of turning itself on and off. This is the 2nd time I've had to do a Hard/Master Reset on this phone. The problems just keep coming back. There doesn't seem to be an end to this aside from getting a brand new phone, however with economy the way it is I feel hesitant to splurge. So if there are any other suggestions please post I'd really appreciate it.
There is a soft/warm reset which bypassed the loop without losing your data.  press the up key and reinstall your battery.  do not let go until the palm screen fully loads. when fully reloaded let go.  sounds a little confusing but the palm website has step by step instructions.
Posted on Apr 10, 2009
    Problem Solver:
  • 7 Answers
There are multiple reasons for the phone to go into an endless loop.
Fix #1 - Soft Reset - Take out the battery. On the back of your phone, pop the cover off, remove battery, place battery back in and it will show each screen once and power on normally.
Fix #2 - Hard Reset - To do a hard reset, hold the power button while you replace the battery and then release it when the Palm logo appears.
Fix #3 - Hammer
As for the corrupted data from your contacts, try PDB database repair.
Posted on Apr 11, 2009
No, you have to delete the data. I had the same issue and the only way to get out of the loop was to reset the phone completely and restore a backup.
I use NVBackup to save everything to my SD. It was a simple matter to reload and so far so good. I suspect it might have been the several calls I received over the Airave while at home. Will keep an eye on it and see what happens.
Posted on Oct 12, 2008
The hard reset does solved the problem but if I synchronize my contacts etc.. from my pc, the phone has the same problem again.
so the phone does work after a hard reset but when u sync it messup the phone again. I suspect some files is corrupting the phone or something. I had to export the vcard (contacts) then open it on my second computer with a clean palm desktop installation then sync the phone. I wonder why this problem is widespread.
How do I root my 1100 Vodafone
  1. Switch off your phone.
  2. Press and hold Power + Volume UP buttons to boot into stock recovery.
    ? Once in recovery mode, use Volume buttons to navigate up & down between options and Power button to select an option.
  3. Select language for recovery (if asked) then proceed to set write protect off:
    1. Change it to Set write protect off.? A message will pop-up saying "Write protect is off after reboot", choose cancel.
    2. Reboot phone.
  4. Download and install the Kingroot .apk file from the link above.
    ? If you get a prompt to "Allow Google to regularly check device activity for security problems..", make sure you DECLINE it.
  5. Once installed, open Kingroot app and press the "Start root" button to begin the rooting process.
  6. During the process you might repeated warnings by Google to check device activity, DECLINE it like you previously did in Step 1.
  7. If the process finishes successfully, then congratulations! You're rooted.
    ? To verify root access, download the root checker app Play Store.
Jun 04, 2017 | Vodafone Cell Phones
Nokia 820 screen is frozen
Is the screen frozen on an app? If yes, have you tried to reboot the phone? If holding down the power button for 12 seconds doesn't bring up an option to 'slide down to power off', try pressing the volume down button and the power button at the same time, and hold them for 12 seconds. If that doesn't reboot the phone, you should be able to remove the back and take the battery out, count to 12, and replace the battery to reboot it.
Jul 27, 2016 | Nokia Cell Phones
My Samsung Galaxy Infuse won't turn on or charge.... it just keeps flashing the Samsung screen and then the Roger's screen. Is it my phone, or my battery that needs fixing?
Have you tried a hard reboot? Hold down the power button, don't click on anything on that screen that pops up, just keep holding the button down until it reboots on it's own.....
Jan 26, 2015 | Samsung Galaxy S 4G Cell Phone
Tablets wont boot up just shows arnova on screen and shuts down
I had same problem looping startup just showing Aenova screen, i tried the pin thing ended up doing a factory reset IT WORKED WAHEY!!
How can I do a Factory Reset on my tablet? If your tablet freezes often or if you get error messages during the start up of your tablet, you can use the recovery mode to reset your tablet to its factory settings, removing all installed applications as well as any data or content.
Your tablet must be up to date with the latest firmware - downloadable from the downloads area of this website.
To access Recovery mode on the ARNOVA 10bG3
To access to the recovery mode:
1. Hold down the volume button + and press the ON/OFF button.
2. Once the boot logo ARNOVA is displayed, release the volume button +.
The ANDROID green robot is displayed.
3. Once the ANDROID green robot is displayed, press simultaneously the volume button + and the ON/OFF button.
The Android system recovery screen is displayed.
a. Use the volume buttons to navigate
b. Use the ON/OFF button to select an option
To restore the default parameters of your tablet:
1. In the Android system recovery, select Wipe data/factory reset;
2. Select Yes -delete all user data.
3. Select Reboot system now.
Your tablet reboots. Redefine your parameters through the wizard.
Your tablet is restored to its default settings.
To access Recovery mode on the ARNOVA 9G3
1. Hold down the Home button and press the ON/OFF button.
2. Once the ARNOVA boot logo is displayed, release the Home button.
To access Recovery mode on the ARNOVA 8cG3/8bG3
1. Hold down the volume button - and press the ON/OFF button.
2. Once the boot logo ARNOVA is displayed, release the volume button -.
Sep 16, 2012 | Tablets & eReaders
I just powered on my Droid 2, but it isn't loading correctly. It has been on for over half an hour, but the screen is still showing just the droid "red eye" thingy. What do I do?
Sounds like its bricked. You can try to do a factory reset. 1. Turn Droid 2 Off by pulling battery.
2. Press 'X' on the physical keyboard and then Press and HOLD Power button until the Exclamation Point/Android picture shows(after motorola symbol).
3. To access menu options Press the "Search" button depicted by the Magnifying glass on the Keyboard and the menu items will show up.
4. Use the Volume Down key and select the "wipe data/factory reset "option with the Camera button all on side.
5. After thats finished, reboot the phone
Feb 18, 2011 | Motorola Mobility Droid (2 GB) Cell Phone
Hello, have a Palm 755p Treo screen just keeps flashing
Fix #3 - Hammer
Apr 09, 2009 | Palm Treo 755p Smartphone
When I install my battery I get the Access Powered then Palm.
I have a Treo 700wx with very similar problem that I solved by starting a hard reset by holding down red button while inserting the battery... keep button down until the message comes asking if you are sure you want to do a hard reset.... I hit the space bar to abort it and IT STARTED UP normally ... worth a try... good luck.
Nov 18, 2008 | Palm Treo 755p Smartphone
Nothing happens on my dash
First make sure your phone is fully charged. Then check...
It may be the storage card - if you take the storage card out it will boot up and you can put it back in. - pain in the a## but it may work. Or Try taking the SIM card out, boot it up, turn it off, replace the card, and turn it on again.
Last resort is a hard reboot. If you did a hard reboot and nothing happened then you did not do it successfully. To do a hard reboot.
- with the phone powered off
- press the two soft keys, yes the left and right soft keys which are the two dash keys labeled - -
- while keeping it pressed, press the power button down
- keep the power button pressed down for 1 - 2 seconds and then release the power button while still holding down the two soft keys. Keep holding down the soft keys until a black screen appears and prompts appear
- now release the soft keys and follow prompts
- if you dont see the black screen with the reset option, pull the battery out, reinsert it and repeat the above steps
- when you see the black screen with the reset option, press the Send button to confirm the reset.
Apr 03, 2008 | T-Mobile Dash Smartphone
Can't reset
Batteries:
Make sure to replace the "battery backup" too the little lithium ion battery
Try Adjusting contrast:
Hold down "[2nd]" key press up or down arrow repeatedly to lighten or darken contrast.
First attempt reseting:
Step 1: Remove all the batteries
Step 2: Hold "Clear" key down
Step 3: Still holding "Clear" key reinstall batteries
Step 4: Still holding "Clear" key press "On" key until home screen is displayed.
Second shot reseting:
remove all batteries including lithium ion (backup battery), wait 3 hours and reinstall batteries.
Third Shot reseting:
Step 1: Remove a battery
Step 2: Hold down "DEL" key reinstall battery
Step 3: Possible msg pops up saying "Waiting ... Please install software" IGNORE msg and take out battery again
Step 4: Reinstall battery do not hold down "DEL" key
reseting will cause the handheld to loose all of its stored memory.
Hope that helps!
Jan 23, 2008 | Texas Instruments TI-83 Plus Calculator
Palm Treo 755p Smartphone Logo
737 people viewed this question
Top Palm Computers & Internet Experts
Michael Vincent Cruz
ray gallant
Raj Patel
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
