Question about Nikon Coolpix 5700 Digital Camera
Nikon Coolpix 5700
SB blinking and can not take pic. Help! been a good camera so far.
  • tubesaft7891 Oct 06, 2008
    thanks, works great.
  • jan11354 Nov 10, 2008
    My 5700 developed the same problem, and I fixed it the same way, ie, turn off the flash.  Also, if you get into the menu's and save this setting as 1, 2 or 3, the camera will remember to turn off the flash and everything works, sometimes even the flash.  Otherwise, a wonderful camera, and to protect yourself, buy the metal lens shade - it protects the extended lens from bumps and breakage.
Your flash doesnt work to use the camera turn off the flash also you can get an external flash for less than it takes for them to fix it good luck
Posted on Oct 03, 2008
Nikon SB 600 speedlight stuck on camera shoe
You simply dangerous with a camera you should return it too Nikon and ask for forgiveness they should help you.
goodluck
Jun 14, 2013 | Nikon Speedlight SB-600 TTL Flash
All of a sudden my sb-400 won't fire. i have changed the batteries numerous times and the red ready light is on but when i take a pic the auto flash pops up and the speedlight won't fire.
HI, I have a SB-400 with cracked housing, and hope to find a broken one to replace my part. Any offer is very much appreciated if you are interested of selling yours! Sincerely, Samantha (utwicky at gmail dot com)
May 14, 2011 | Nikon SB-400 Flash
Does not take good indoor far away pics. Does it not have a strong flash?
How far is "far away"? It's a compact camera---don't expect its small flash to light up a gymnasium or an auditorium. In fact, it won't light up the far end of a banquet table.
May 25, 2010 | FUJIFILM FinePix Z70 Z71 Digital Camera
Hi! I just got an SB-900 flashlight to go with my
Personally, I'd go with Manual on the camera so as to have complete control over both aperture and shutter speed, and iTTL on the flash. Bear in mind that a single SB-900 isn't going to light up an entire basketball court or wherever you might be photographing. If the pics are too dark, it's most likely that the subjects are too far away.
If you take a picture of a chair in the middle of your living room, does that come out too dark?
Dec 28, 2009 | Nikon D60 Digital Camera
Need to find a photo capacitor for a sb-600 flash
http://www.jamicon.com/capacitor.html
you may use 680uF-1000 but 350-400Volt.
Check Voltage,be carefull!!!!!
in you system voltage exeed nominal level 330V! may be 350-360V-result die capacitor.
For normal use capacitor on 330v good maximum voltage wil be ~280V.
sorry for my english)
Best regards,AlexOn
Sep 03, 2009 | Nikon Speedlight SB-600 TTL Flash
Camera flash problem (Nikon)
ok,
try to set the menu item for Auto FP to ON (it works in P,S, A, and M modes only) that will activate the Highspeed Sync when you are using the SB-600 flash unit, set the flash mode so the indicator shows the off position (the line thru the lightning bolt symbol) on the top inidcator menu in the its next to the red eye redution icon that will keep the built-in flash off even if you need it in low light. hope that works for you.
randy320sgi
Jan 07, 2009 | Nikon Cameras
Will the Nikon SB600 speedlight work with the Nikon D60 Camera. All the instructions mention all the other Nikon camera's but not the D60. Will the auto flsh modes work with the auto modes of the camera
Yes. The SB-600 instructions don't mention the D60 because the SB-600 came out before the D60 existed. Bear in mind that the D60 does not have a commander mode so you can't use the SB-600 as a slave.
Basically, as far as the SB-600 instructions are concerned, just pretend that you have a D40.
Oct 01, 2008 | Nikon Cameras
Drivers
I need these drivers too!
Dec 09, 2007 | Concord Camera 3346z Digital Camera
Nikon SB - 800 LCD Defect
Impact has damaged the LCD assembly .
IF you want it repaired contact the email address below
Berrie Smith Camera Repair
bbmw@bellsouth.net
Oct 29, 2007 | Nikon Speedlight SB-800 TTL Flash
Speedlight SB-600 Display flashing.
My SB 600 is doing the exact same thing. I used Nikon's online support service and this is the response I got: "I would try doing the 2 button reset on the flash and then see if that helps. Also disconnect any battery packs you may have connected especially if its a third party battery pack. If none of the above work then please service the speedlight" Sounds like they don't know what it is, either. I tried the reset to no avail. I'm not sure I want to send it in to have it fixed, since it does seem to be working. But you're right, it's annoying.
May 17, 2007 | Nikon Speedlight SB-600 TTL Flash
Nikon Coolpix 5700 Digital Camera Logo
118 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
