Question about Hotpoint TDL15 Electric Dryer
Hotpoint tumble drier TDL52S
The belt on my tumble drier has broken.
It looks like a lot of srews to take the back off!
I've source a new belt and orderd it, the website say this is a tight fit and needs stretching and I'll need to get the new belt over the drum and onto the motor shaft.
Is there an easy way? Or a workshop manual which descrines how to do this?
Cheers
Ian
  • 67 Answers
You dont need to take the back off. to get inside, first remove the panel on the bottom of the front, that will allow you to remove the front panel and you will be able to get inside the dryer. as far as stretching the belt, i have never heard of that. there is a belt tensioner that holds the belt tight though. good luck!
Posted on Oct 28, 2008
How do I replace the belt on my hotpoint futura tumble dryer?
I can't answer your question exactly but in my experience tumble drier belts are not particularly complicated to replace but the process is fairly time-consuming and involved as in order to slip the new belt over the drum an almost complete strip-down of the cabinet is needed.
It is a route-march of removing screws and plastic trim until something important falls off. The task then becomes rather more a thorough interior clean and a changing of felt bearings than merely replacing the belt. The belts last so long that by the time they need replacing the other things are also ready for attention.
Apr 29, 2016 | Hotpoint Dryers
Hotpoint tcym 750c tumble dryer serial number tcym750c6p. The wires attached to the timer control and start button have disconnected does anyone know how they go back on?
images for Hotpoint tcym 750c tumble dryer wiring
Hotpoint TCYM 750C Style - YouTube
? 3:07
https://www.youtube.com/watch?v=RjQMN6U4PdE
Oct 8, 2012 - Uploaded by Missing Sleep
Hotpoint TCYM 750C Style. Missing Sleep ... How to replacetumble dryer belt Hotpoint, Indesit, Ariston, Creda, Proline etc - Duration: 9:36. by ...
Hotpoint tcym 750c tumble dryer serial number tcym750c6p ...
www.fixya.com/.../t25992053-hotpoint_tcym_750c_tumble_dryer_seria...
48 mins ago - SOURCE: Reconnect wiring on a Hotpoint VTD00 tumble dryer. most electric dryers have a wiring schematic on the back or inside on the back ...
Dec 03, 2015 | Hotpoint Dryers
How to get the lid of Hotpoint tumble drier Model PCF780
Usually the lids are released by a putty knife in the corners, releasing a catch.
Dec 01, 2013 | YouTube Videos
Drum not turning
Hotpoint tumble dryer not turning? How to replace a hotpoint tumble dryer belt
This video will show you how to replace a tumble dryer belt in your appliance
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question. 9 rib stretch tumble dryer drive belt Contitech 144001958 9PHE 1860 How...
Nov 12, 2013 | Hotpoint TVF770 Tumble Dryer
My hotpoint aquarius tumble drier is making a very lound griding sound as it turns. What can it be and can it be repaired by myself? the drier is over 8years old is it time for a new one?
This is the plastic "wheel" on the motor that drags the drive belt to spin the dryer. you will need to push back into place with something thin. under the right hand side of the dryer there will be a grill under the motor. look for a black plastic "wheel" and move it away from the casing with something that can fit through the grill.
May 16, 2010 | Dryers
The belt is broken on my creda tvr2 tumble drier and i dont know where to get to it to replace it
If you are in the U/K, then got www.hotpoint.co.uk, and follow the links.
Please rate my solution.
Thanks.
Nov 01, 2009 | Dryers
The tumble inside stoped turning.
You have a broken belt on your drier. Take the back of your drier off and youll see the problem.
Good Luck
Dave
Aug 11, 2009 | Kenmore 77032 Dryer
How do i fit a drive belt on a hotpoint tumble drier
Hi, To fit the belt to your dryer you will need to remove the top of the appliance by removing the screws at the rear. Pull of the timer/control knob. Look inside the top of the t/dryer behind the control panel you will see little plastic stems which are attached to the facia panel. You need to knock these out to remove the facia. Once this is off then you can remove the the top 3 screws and the bottom 3 screws the front panel will now come off for you to place the belt on the drum and over the motor spindle. Becareful as the t/dryer will be very loose and will twist. it is easier to lay the appilance down on its back to stop everything falling about. Now you can put it back together in the reverse order....
Good luck.............
Jan 26, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Replace a new belt to tumble dryer hotpoint vdtoo
belt broken, removed back panel to access drum and pulleys. How do I get the new belt around the drum?
May 03, 2008 | Hotpoint Dryers
Broken belt on hotpoint vtd65 tumble dryer
turn the macine aroun you wiil see3screws on the top holding the lid on remove these and take the top off there are 3or4screwes on the top in front of machine remove these lay the macine back at45degres and on the bottom of machine you will find 4more screws remove these and the front will come off place new belt over the drum and with a small crow bar linked through the belt and under the drive apply a lot of down presure to get it on to drive this is realy hard and you mey think the belt is to small it is not make sure u align drum in to front door or machine this is very simple then re assemble and away you go approx time45to hours work
Dec 06, 2007 | Dryers
Hotpoint TDL15 Electric Dryer Logo
250 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
