I have 2 .pdf files. One named test.pdf the other test(2).pdf. When I open test(2).pdf it actually opens the test.pdf file not the (2). Why would that be. I am using adobe 7 professional. When i try this in adobe 8 it opens fine. Please help
  • 781 Answers
1. try renaming the files with 2 complete different names - hightlight the icon, press f2 and change the name. (if you the extension pdf in the name, make sure you only change the part of the name that is to the left of the ".pdf" and leave the ".pdf" part unchanged otherwise you maybe damaging the file for good. then try again.
2. reinstall adobe.
Posted on Sep 24, 2008
SOURCE:
Hyperlink other document in excel button
The easy way (but labor intensive) is to put the file names in a column (can be any name you want or the pdf file name), right click on a cell, hit insert hyperlink, and in the address field at bottom, put in the file pdf file name. You would have to do this for each of your 100 files.
If you want to automate it, create a column with the directory path name, a 2nd column with the full file names, a 3rd column where you concatenate the two previous columns to create the full path, and then use the hyperlink command to provide the link:
Folder name Filename Concatenated LINK ../excel/ file1.pdf ../excel/file1.pdf file1.pdf ../excel/ file2.pdf ../excel/file2.pdf file2.pdf ../excel/ file3.pdf ../excel/file3.pdf file3.pdf
Here are the formulas behind this:
A B C D Folder name Filename Concatenated LINK ../excel/ file1.pdf =CONCATENATE(A2,B2) =HYPERLINK((C2),B2)
../excel/ file2.pdf =CONCATENATE(A3,B3) =HYPERLINK((C3),B3)
../excel/ file3.pdf =CONCATENATE(A4,B4) =HYPERLINK((C4),B4)
This should work like a charm and the other advantage is that excel won't rename your path locally depending on weather a file is open or not).
Feb 21, 2014 | Microsoft Excel for PC
When I finish a newsletter on Printmaster Platinum 18.1, I want to save it as a pdf file and when I click on that it says "cannot print file". I don't want to print; I want to save it so I...
When you print to a PDF file, it does not actually print the file, it prints TO A file. You then will be presented a save file as screen and you should select you location for saving files, give it a name and save it. It then is a PDF. If you click on it, it will open in PDF reader. That is how a PDF works.
Aug 31, 2011 | Toshiba Computers & Internet
A try download a particular pdf file but each time after i download it, i get this reply when i try open it 'pdf file damaged and cannot be repaired' what exactly is d cause?
May be the file is actually damaged, or may be your PDF Reader is actually damaged.
First try to download the PDF file from different source(s) and then try opening that file.
If it doesn't work, go for different PDF Readers. Like you may try the Adobe Reader or Foxit Reader to open that file.
1. Download Adobe Reader 10.0 here
2. Download Foxit Reader 4.3 here
Dec 12, 2010 | Computers & Internet
I cannott open any of my documents which are filed as Adobe pdf files. Can you help? This problem has only just occurred. E verything was working O.K. prior to the installation of BT Brodband this...
may help to indicate what happens when you try to open pdf files however, try to clear browsing history and cookies and make sure you have the latest acrobat reader installed and check that your PDF files are associated and set to be opened by default using acrobat reader
Dec 04, 2010 | Computers & Internet
Hi, I cannot print a pdf file or that kind of attachment. Only Word can print. Adobe error shows up and want to shut down the program for protection. I never had the problem before. Just started.
Is it a file that you created in pdf format, or is it one that you have had emailed or attempting to open from another source? Some pdf files have protection put on them by the file originator to avoid the file being changed/printed. Here are some tips to try to get them to print for you.
  1. Open your computer's Internet browser.
  2. 2
    Type www.a-pdf.com/security/a-pdf-rr.exe in the browser's URL box to access the PDF restriction converter "A-PDF Restrictions Remover."
  3. 3
    Press the "Enter" or "Return" key. Your Internet browser will access the site's PDF converter file. A dialog box will appear on your screen--"Opening a-pdf-rr.exe."
  4. 4
    Click "Open" or "Run" to download and set up the program directly. Click "Save" or "Save As" to save the program's setup file on your computer for running later--use this option if you using a slow connection like dial-up. The program will download and set up on your computer if you selected the "Open" or "Run" option.
    If saving the file to your computer, navigate to the directory where you want to save the file to. Select the "Desktop" if you have a hard time locating downloaded files on your system.
    You do not have to access the A-PDF Restrictions Remover website again once the file starts downloading or saving to your computer.
  5. 5
    Double click on the "a-pdf-rr.exe" icon to open the program, if you selected the "Save" or "Save As" option.
  6. 6
    Click "Run" when prompted with the "Open File -- Security Warning."
  7. 7
    Click "Next." Click on the circle by the wording "I accept the agreement." Click "Next."
  8. 8
    Select the directory where you want to save the "A-PDF Restrictions Remover" file. The default is your "C:\Program Files\A-PDF Restrictions Remover" folder. Click "Next."
  9. 9
    Click "Next," "Install" and then "Finish." A-PDF Restrictions Remover will start automatically.
  10. 10
    Navigate to the directory where the protected PDF file is located.
  11. 11
    Right-click on the PDF file name. Select "Remove Restrict & Save As."
  12. 12
    Select a location to save the converted PDF file to. Click "Save." If you want to change the PDF file's name, enter a new name in the box next to the wording "File name." The protected PDF is now converted to a unprotected one.
  13. 13
    Double-click on the converted file to open it.
  14. 14
    Select "File," "Print" and then "OK" to print the unprotected, converted PDF file.
  15. Printing a Protected PDF By Taking a "Screen Shot"
  16. 1
    Open the protected PDF file2
  17. Press the "Alt" and "PrtScrn" keys together. The PrtScrn key is located on the upper right-hand side of your keyboard, if using a desktop computer keyboard. If using a laptop, the PrtScrn key is located above the "F10" function key.
  18. 3
    Open your computer's word processing program by clicking on the program's icon on your system's "Desktop" or from the "All Programs" menu.
  19. 4
    Press "CTRL" and "V" keys together to paste the screenshot into a blank document.
    If using a Mac, click "Edit," "Paste" from the main toolbar at the top of your word processing program.
  20. 5
    Click "File," "Print" and then "OK" to print the PDF screenshot. If the protected PDF file contains more than one page, press the "PgDn" key and repeat steps 2 through 5.
Oct 29, 2010 | Canon FAXPHONE L80 Laser
Hello! I have lost my PDF file password, I wonder how I can get it back
PDF Password Remover is an amazing and professional software to remove the use/open password and restrictions (owner password) on printing, editing and copying from your PDF files.
Feb 02, 2010 | Adobe Computers & Internet
Lock pc drives
Hi
1. Click “Start”, “Run,” and then type cmd. When the command prompt opens type “CD C:\Test” (replace “Test” with the name of the folder you want to hide.)
2. Now type “attrib file +s +h” and replace “file” with the name of the actual file name you would like to hide.
3. Now, go back to C:\Test and look for your file or folder, it’s not there! You cannot find it through simply browsing around, through the command prompt, or even if you click “Show Hidden Files and Folders”.
4. To find the folder and it’s contents again simply go back to the command prompt, type “CD C:\Test” (of course, again replacing “Test” with the name of the folder,) and then type “attrib filename -s -h”. You should now be able to find your file again
Thanks
Smith
Aug 16, 2009 | Computers & Internet
HOW TO LOCK PC DRIVES
You will solve your problem
Thanks
Apr 13, 2009 | Compaq Presario s4020wm (DK214AR#ABA) PC...
I want to edit docs in version 8, when save the pdf as text opens in notepad and formatting is trashed is there any way we can set that to open in word with formatting intact
You will lose a lot of document format if you open a pdf file in word. I suggest that you use an appropriate pdf editor, like Adobe Acrobat full. It has all the features that you need to edit, create pdf files, also export doc files to pdf
Mar 05, 2008 | Computers & Internet
Computers & Internet Logo
73 people viewed this question
Alun Cox
