Question about EliteGroup L7VMM2 Motherboard
L7VMM2 shuts down
My L7VMM2 shutsdown & re-starts from time to time.
Have already installed updated driver but problem persists.
  • 781 Answers
I think you have overheating problems
Check all fans are working and vanes are clean including power supply one
Check heat sink on CPU that the vanes etc are clean and clear of dust and fluff
Give case a vacuum out including all vent holes also the ones on inside case of power supply
see how you go this problem is usually the cause of persistent reboot
Posted on Sep 24, 2008
When i shut down my computer it starts to install new updates always starts with 1 of 10. it then shutsdown and when i turn on it shows the update failed when status checked?
it is trying to update,but,the update failed,there may be something wrong with your computer,if it gives a code,write it down you will need it,go here and read about it, http://www.bing.com/search?FORM=UP97DF&PC=UP97&q=why+my+updates+fail
May 14, 2015 | Computers & Internet
When im typing on my keyboard it shutsdown my computer. For Example: I press the enter key and all the open programs close and the computer just shuts down. then im typing in an adress bar and get done...
It can be virus problem. Try to go in 'Safe mode with networking' (press few times F8 when computer start to get menu options). Download ESET (Nod32) Online Scanner:
http://go.eset.com/us/online-scanner
Scan your computer with repair option on.
After that update your Windows. If you can't do that from Microsoft, you can use AutoPatcher.exe utility:
http://www.autopatcher.com/downloads/
I don't think it is keyboard problem.
You have free AVG good antivirus for homeusers.
Aug 25, 2011 | Computers & Internet
My psp hangs for a minute and shuts down when i load PES 2010 or any game
ok I see that when you put a game on your psp it shutsdown..YOU can try to hack IT!! as this creates new FILEs to your system!! that you will probably need ORR if its already hacked and has custome firmware than UPDATe all the way or very low.. that could and CAN help your problem NOTE if its hacked than you can turn it off HOLD THE R button than turn it on select advance OR configure i dont remeber and click ON UMD, NEEDED if its on M33 driver than change it. i hope this helped you..!!
Aug 31, 2010 | Sony Video Game Consoles & Games
Everytime i play games or play a video it shutsdown
update the video drivers and then uninstall and reinstall the games and check for the issue.
If the issue persists I hope the video card of the notebook does not support the games.
Jun 13, 2010 | HP Pavilion dv1000 Notebook
Fan doesn't shut off ever
I just did a BIOS update on my sisters computer presario f700 and noticed that the update said it would fix some problem with the fan. The update is on Compaq's website under software and drivers. Maybe that would help.
Feb 13, 2010 | Compaq Presario 700 470024-192 Notebook
My toshiba satellite A45-S150 laptop windows shut down
You can download any/all the Windows XP device drivers for your model laptop from the Toshiba WEB site from their download page.
Make sure you enter the model of your laptop so you can get the correct drivers.
Use this link :-.
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp#
Apr 15, 2009 | Toshiba Satellite A45-S150 Notebook
GeForce6100SM-M Intermitently Shutsdown
if there is a problem with one of the devices connections , or one of the devices chips are failing it will cause a shut down to protect the rest of the circutry.
try disconnecting all but cd/dvd drive to see if this happens , then only plug the sata or other ide including the power.
if a virus is in bios , resetting the clr bios and removing the battery on the motherboard can remove it
if the local area network is causing the shut down you would have data transfer problems or slow communications,
and there could also be a problem on the board
Oct 15, 2008 | EliteGroup ECS GeForce6100SM-M (1.0)...
I need L7VMM2 installer
You can download the following drivers for your motherboard:
VIA8233 Codec Sound Driver for L7VMM2 Windows 2000/XP Download
Modem driver for L7VMM2 Windows 2000/XP Download
VIA VT8233X LAN Driver for L7VMM2 Windows 98/ME/2000/XP Download
IDE driver for L7VMM2 Windows 98/ME/2000/XP Download
If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating under my solution. I would be very grateful for your show of appreciation.
Should you have any further questions, please feel free to post them here.
Thank you for using FIXYA!
Cheers!
IrishDruid
VIA8233 Codec Sound Driver for L7VMM2 Windows 2000/XP arsim.gifDownload
Apr 28, 2008 | EliteGroup L7VMM2 Motherboard
MacBook wont run from battery
Apple does have a battery recall/fixing procedure on certain macbooks and macbook pros.
The battery of a MacBook or MacBook Pro computer may:
  • Appear to have no charge (zero percent)
  • Be unable to power the computer by itself; the computer might work only when it is connected to the MagSafe power adaptor, which only shows a green LED
  • Appear with a black "X" icon on the menu bar
  1. Shut down, then remove and reinstall the battery. Test for the issue(s) again.
  2. Connect the MagSafe power adaptor (if you haven't already) and see if the behavior continues.
  3. If the issue(s) persist, download and install the Mac OS X 10.4.9 Update.
  4. If the issue(s) persist, Download and install Battery Update 1.2.
If, after installing the Mac OS X 10.4.9 Update and Battery Update 1.2, a black "X" still appears in the menu bar, contact apple by calling 1-800-MY-APPLE (1-800-692-7753)
Dec 06, 2007 | Computers & Internet
EliteGroup L7VMM2 Motherboard Logo
80 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
