-   can't change resolution,screen is black
-   kapsel69
Jan 30, 2009
-   How do you change the screen resolution if you can't see anything?
-   kflewis22
Jan 10, 2009
-   How can I change the resolution when i CANT see anything on the screen!!! -   Guest
Dec 30, 2008
-   When I turn on the computer, after the windows loading screen, the monitor goes blank and says Out of Range. I tried to start in safe mode and all that but cannot get into windows. I can't get into windows to set the resolution lower, what can I do?
-   Guest
The out of range message indicates that the video signal is detected but that the monitor can not sync to it. This can be becasue the resoution is too high or too low. Try changing the resolution downward first. If this has just shown up, then there is a problem within the monitor that is mistakenly being reported as an out of range condition.
Disable ur video card in safe mode,,,restart then enable vid card then right click on vid card in hardware mgr slect scan for changes.....worked 4 me BOL
I have samsung syncmaster 932 mw tv monitor.I have it for only 15 months.When I switch it on it is...
(More)
I have samsung syncmaster 932 mw tv monitor.I have it for only 15 months.When I switch it on it is working for 2 seconds and is getting dark then.So it isn't possible to see anything on it.
Every photo I pull up on the monitor is squashed. Things that should look tall -- like a glass of...
(More)
Every photo I pull up on the monitor is squashed. Things that should look tall -- like a glass of water -- turn out looking short and wide. The disk that came with this is the definition of useless, and I really need to know how to fix this.
