Question about Intel Computers & Internet
Sound card i install new windows xp sb2 @no sound output but it gives me this device is working properly
  • 75 Answers
Check whether u installed sound driver....
Posted on Sep 24, 2008
Appears to be installed properly but doesn't record
When you first connect the turntable, Windows XP (and Mac OSX) will often select the "USB Audio Codec" as the audio input and output for your entire system. Since your turntable does not have speakers, audio will not be heard from your programs until you tell Windows not to use the turntable as an output device. Here's how to change these settings so that your internal sound card will always be used for playback whether or not your ION TTUSB is connected via USB:
    For Windows:
  1. On the bottom left of your screen, select the "Start" menu.
  2. Select "Settings" then "Control Panel".
  3. In the window that opens, select the "Sounds and Audio Devices" icon. (If you don't see a choice called "Sounds and Audio Devices," choose the "Switch to Classic View" option in the panel on the left of the window, and the "Sounds and Audio Devices" icon should become available in the list on the left.
  4. Select the "Audio" Tab at the top of the "Sounds and Audio Devices" control panel window.
  5. Under "Sound Playback," choose your internal sound card as the default device. This varies by computer but should not be set to "USB Audio Codec" or "Microsoft Sound Mapper".
  6. Under "Sound Recording," select "USB Audio Codec" for your default device.
  7. Check the box titled "Use only default devices".
  8. Click "Apply"...then "OK".
    For Mac:
  1. Open your Hard Disk.
  2. Open your "Applications" folder.
  3. In the "Applications" folder, open the "Utilities" folder.
  4. In the "Utilities" folder, open the "Audio MIDI Setup".
  5. In the "Audio MIDI Setup" under Audio Devices, set:
    • "Default Input" to "USB Audio Codec"
    • "Default Output" to "Built In Audio"
    • "System Output" to "Built in Audio"
Now, all programs, including Audacity, will only use your internal sound card for audio output.
Dec 26, 2007 | ION Audio iTTUSB Turntable
Sound card not working after XP install
Does the icon come up in the tray if so check
to see if it is not muted
Go into device manager/propersties and see if
it lists any problem,if it says everything is working
properly remove it and let it check for changes in
device manger when it reisstalls see if that works
Dec 03, 2007 | Toshiba Satellite A105 Notebook
I am trying to run the "my amazing human body" cd-rom game. it says the sound software is not installed right or not working properly. we bought it new and worked once and now it wont. we have xp...
XP should be able to run it because they're backwards compatible with all Windows 98 software. Check your sound card in the Device Manager and verify the device and its' driver are installed. If not, re-install the driver for your sound card.
Oct 30, 2010 | Dk Multimedia Computers & Internet
My sound card is not work on windows vista home premium. previously i have xp on my system and sound card was waorking well. now i have installed vista and and it prompts that no output device is...
1. you will have to use the "compatibility mode" to get the sound card to work that is if it worked in Windows XP it will have to be set up in Windows XP
Here is the knowledge base article for follow:
http://support.microsoft.com/kb/927386
2. copy/paste into the url
3. sometime the drivers for you sound card are not compatible for the new Operating system (Vista) and will need an update or you will have to purchase a new sound card that is compatible.
Jul 09, 2010 | Yamaha SW 1000XG Sound Card
Install a new sound device
You probably need to install a device driver for your sound card if Windows does not support it by default. You should have a CD for the audio card which contains a driver, otherwise you can download it from the manufacturer's support site.
Here are some more steps on how to troubleshoot sound in XP.
Jules
May 15, 2009 | Echo Indigo Stereo Output Device for...
Winamp radio, once I select PLAY it returns with DirectSound driver fault.I have windows XP thank you
The way that we were able to fix the problem was by rolling our sound card driver back to the previous version and then we installed the latest driver for the sound card. Here are some detailed steps you can follow:
  • Roll the driver back to it's previous version (only tested with Windows XP)
    • Right-click on 'My Computer' and choose 'Properties'
    • Click the 'Hardware' tab
    • Click on 'Device Manager'
    • Find 'Sound, video and game controllers' and click the plus sign next to it to expand it
    • Find your sound card and double-click it, this will bring up it's Properties
    • Click the 'Driver' tab
    • Click on the 'Roll Back Driver' button. If there is a driver backed up for your device it will roll back to that driver, otherwise a message tells you that 'No driver files have been backed up for this device'.
      • If there is not a backed up driver for your sound card you may want to just click the 'Uninstall' button to completely remove the current driver that is giving you problems.
  • Install the latest driver from your sound card manufacturer's website
    • Find the manufacturers website and look for a drivers/downloads area
    • Download the most recent driver available for your sound card
    • Follow the instructions from your manufacturer as to how to install the new driver
  • Reboot your computer to make sure it loads the new driver
  • Try to play your MP3 or other audio file in Winamp
If these steps do not fix your problem then there are some additional steps you can take. Some computers have more than one sound card in them. If this is the case then it is possible that the default sound card has somehow been changed. To make sure windows is using the right sound card go to the 'Control Panel' and double-click the 'Sounds and Audio Devices' entry. Click on the 'Audio' tab and in the Sound playback area make sure the Default device is set to your preferred sound card. You could also try using a different sound card in your system if all else fails.
If you are still having trouble with this error you can press 'Ctrl+P' while in Winamp to bring up the Winamp preferences. Go to the 'Plug-ins' section and click on 'Output'. Trying changing the output from DirectSound output to WaveOut output and then close the preferences and close Winamp. Open Winamp again and see if it works now.
Jun 26, 2008 | Audio Players & Recorders
Bad direct drivers.
Dear sir,
I ahve problem like My laptop is C700 series of compaq(C772TU) I ahve changed it OS from vista to XP and now there is no audio output whenever I try to play a song it gives msg like " Please installproper device or select another device in configuration Error code: 88780078"
please suggest me proper solution
Mar 22, 2008 | Computers & Internet
Problem with Windows XP recognizing Creative Sound Card
It sounds like a software problem. Though you did the right thing by entering the bios & disabling the onboard sound. That should have been enough. Did you uninstall the old intergrated sound drivers before adding the 24bit card? Just about all the drivers & upgrades for your 4600 through Dell is Creative software & thats why your having a tough time. I would put everything back to how it was. Re-enable the intergrated sound & reboot! Run system restore & check that every thing is running right!! Look at this dell web site for the sound drivers you have at this link:
http://support.dell.com/support/downloads/driverslist.aspx?c=us&cs=19&l=en&s=dhs&ServiceTag=&SystemID=DIM_P4_4600&os=WW1&osl=en&catid=&impid=
If you must, install a upgrade for your intergrated sound. Just so you can uninstall it after a reboot. Re disable the sound in the bios. Do not install your new card yet. While back in windows device manager you should be missing a PCI device. Shut down install the new sound card. Hopefully windows will want the drivers & all runs fine. If still no it could be a bad card (i know what your thinking but it's possible). The only thing left is the regestry is using the wrong PCI device.
Dec 26, 2007 | Creative Labs Sound Blaster Live! 5.1...
Sound problem
Windows XP questions and answers CH000647, How do I install Microsoft Windows XP. CH000661, How to clear Microsoft Windows ... CH000857, How do I play a sound or music file in Windows?
Installing a computer sound card. Use this software to install the card into the computer. Sound card drivers can be found on our sound card driver page. If you do not know the manufacturer.
Device Manager information and help CODE 24 - Device not Found, This device is either missing or not working properly. Verify you have the latest driver installed for your device.
Good Luck, Please dont for get to Vote/Thank You.
Dec 22, 2007 | Toshiba Satellite 4300 Notebook
Computers & Internet Logo
32 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
