Question about Car Audio & Video
The volume or maybe the speakers in my 2002 hyundai sonata stopped working. Radio still comes on but no sound. What can I do.
  • 125 Answers
If you happen to have a speaker available, try to test the stereo. plug in a speaker and see if it works. otherwise, i don't really like this method but, it does work... unlug your factory speaker and plug a 9v battery to the speaker, if you hear a little popping/wizzing sound, the speaker works and it's the head unit.
also, check to see if the radio has an amp. sometimes the radio will be operational, but the amp isn't and that is the problem. and the easy solution is to replace the radio with an after market of choice. factory radio's that are purchased seperately are rather expensive.
Posted on Sep 24, 2008
The dial on radio volume not working
sounds like the radio volume is bad, and no volume from radio Time for a new radio. Good-Day!
May 17, 2014 | 2011 Hyundai Elantra
How to fix 2002 Hyundai Sonata Car radio
When you disconnect your battery and then reconnect it again, it disables the radio. This is an anti-theft protection for your car radio.
The enable your radio the activation code is in your vehicle owner's manual. If you do not have this code you need to go to your vehicle manufacturer's service centre and get them to enter this code for you.
Sep 17, 2012 | Hyundai 2002 Sonata Radio
Radio Fuse Blows Out
LOOSE EARTH IN SPEAKER WIRING
Feb 27, 2010 | 2002 Hyundai Santa Fe
Radio Reset for 2006 Hyundai Sonata
doubtful probably burnt up a component in radio thats why when jumping a vehicle u turn off all accessories so when something gets crossed it doesnt short it out usually will blow a couple of fuses
Feb 10, 2010 | 2006 Hyundai Sonata
How to remove radio from 2001 sonata
The trim snaps in, no screws! I have used a hook type screwdriver, the kind used to install springs... I carefully insert the tool between the lower left corner of the radio and the bezel. Rotate the tool 90 degrees toward the bezel and pull straight out. Id say it comes off with maybe 15 pounds of pulling force. The radio is screwed in with brackets. You'll see once the bezel is off. **Keep in mind that many Optimas use an external amp located between the right rear door and wheel well. Also, some use 2 ohm speakers, all the way around. You may need to change all of it to upgrade your sound system2_bing.gif, I did**. Good luck!
Jan 15, 2010 | 2001 Hyundai Sonata
2000 Sonata - Radio quit working
you need to go to the Hyundai service center they can reset the radio I believe this is a security feature, you may be able to call the service center to find out the procedure to reset the radio, it is the original right ?
Apr 07, 2009 | 2000 Hyundai Sonata
Stereo problem with hyundai sonata 2000 after dead battery
After verifying all the connections to the radio are good (power and ground, antenna, speakers, etc), the audio unit has an internal malfunction. Solution: Replace the audio unit.
Mar 21, 2009 | 2000 Hyundai Sonata
Need diagram for wiring radio for 1997 Hyundai Sonata
1997 Hyundai Sonata Car Stereo Radio Wiring Diagram
Car Radio Constant 12V+ Wire: Red
Car Radio Switched 12V+ Wire: White/Green
Car Radio Ground Wire: Black
Car Radio Illumination Wire: N/A
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger: N/A
Car Stereo Amp Trigger Wire: N/A
Front Speakers Size: 4′
Front Speakers Location: Dash
Left Front Speaker Positive Wire (+): Brown/White
Left Front Speaker Negative Wire (-): Black/White
Right Front Speaker Positive Wire (+): Brown/Yellow
Right Front Speaker Negative Wire (-): Black/Yellow
Rear Speakers Size: 6 1/2′
Rear Speakers Location: Door
Left Rear Speaker Positive Wire (+): Brown/Red
Left Rear Speaker Negative Wire (-): Black/Red
Right Rear Speaker Positive Wire (+): Brown/White
Right Rear Speaker Negative Wire (-): Black/Whi
Mar 20, 2009 | 1997 Hyundai Sonata
04 sonata stereo wireing diagram
Battery ORANGE (+) RADIO HARNESS
Accesory YELLOW (+) RADIO HARNESS
Ground BLACK (-) RADIO HARNESS
LF Speaker (+) BROWN/WHITE
LF Speaker (-) BLACK/WHITE
RF Speaker (+) BROWN/YELLOW
RF Speaker (-) BLACK/YELLOW
LR Speaker (+) BROWN/RED
LR Speaker (-) BLACK/RED
RR Speaker (+) BROWN/WHITE
RR Speaker (-) BLACK/WHITE
Jan 01, 2009 | 2007 Hyundai Sonata Limited Sedan
Car Audio & Video Logo
131 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
