Question about Packard Bell iMedia 6826 (P481000502) PC Desktop
Display problem hi i am using a Packard Bell imedia 5068 with MS xp pro. it was working fine for the past year..now at start up i get one beep after five seconds i get a second single beep..then it starts to load..i can see the microsoft xp logo and the blue line runinng along the bottom loading..then when its finished loading the screen is black i can see my mouse crusier thats it.. and it wont respond to anything keyboard or mouse...also at start up i get the option to start up normal or last know good config..safe mode and or networking..i have tried the start up normal and last know configuration..but it is still the same,,i have tried a different monitor and the problem is the same..this machine has a second network card i tried taking this out and conecting to the port on the mother board but its still the same..i thougt it might be a controller problem but i cant find a controller on the packard bell site...and if it is a controller problem ..how do i install it if i cant see the screen? hope you can help me with this one...thanking you...anthony gannon
  • Kenny Wilson May 11, 2010
    What service pack do you have? Also, do you mean a video card or a network card?
  • Packard Bell Master
  • 787 Answers
You don't have a display problem, you have a hard drive problem.
It is probably a file system corruption.
Insert the Windows XP install disk into your CD drive and boot to it. At the first setup screen, press R to repair windows from the recovery console. Once the recovery console loads, type
chkdsk /r and then press Enter. Once this finishes, remove the CD and reboot. With any luck, you will be able to boot successfully, if not, come back and give details about what happens.
Posted on Mar 06, 2017
sandrew
  • 2961 Answers
SOURCE: Packard Bell Easynote L4
This is either the hardrive that has failed or windows cannot find the c:\ boot volume. You will need to start your pc up with your xp cd in and and when it's installed all the set up files press 'R' for repair, this will overwrite all the system files, without deleteing any of your saved files and programmes.
Posted on Mar 12, 2007
McIndia
  • 131 Answers
SOURCE: Cant take apart packard bell imedia to install pci card
when disassembling server chasis, you will have to release the front panel first, only then you can remove the side panel
Posted on Jan 05, 2008
  • 81 Answers
SOURCE: Hi, I wonder someone could
Hi.
Even i once had this problem.
There are two solution.
First remove the ram and wipe it then fit it again.
If this doesn't help then get the system formatted.
Hope this will help you (By the way it did helped me)
Regards
Faraz
Posted on Oct 13, 2008
Bassplyr1
  • 77 Answers
SOURCE: packard bell imedia alt-col2 just keeps beeping on and off
Find out what's making the noise first. It's either your fan or your hard drive. Check to make sure the noise your're hearing isn't your fan cutting into one of your wiring harnesses. That could be why you have the video problems. If it's your hard drive making the noise, that means it's on it's way out and you should immediately back up your files on disk and replace the drive before you lose everything.
Posted on Jul 15, 2009
  • 2668 Answers
SOURCE: when switched on, my packard bell imedia 1508/2 pc
Have a look here
http://www.computerhope.com/beep.htm
Posted on Jun 16, 2010
Imedia 1414
would upgrade to better board first jim
Mar 20, 2014 | Packard Bell Computers & Internet
I have a Packard Bell Imedia desktop not sure of the model. It was working fine until recently, I switched on my pc and after the boot screen "NTLDR is missing Alt Ctrl Del" message appeared....
Remove the hard disk and attach it to an USB hard drive adapter and then connect it into the USB port of a working computer. This computer will detect the hard drive as an external storage device, then you can open the various folders and files to copy your files to this computer or burn your data to a CD/DVD disc or USB flash drive.
Return you hard disk back to your Packard Bell so you can reinstall Windows.
Aug 10, 2011 | Packard Bell iMedia 6826 (P481000502) PC...
Packard bell imedia 5068
Ubuntu requires high graphic memory on your computer. It could install on some components but it doesn't work on whole installation process. If you are having a desktop machine, add graphic/video card to the motherboard so that Ubuntu will finally be installed in your computer.
Thanks
Jun 20, 2009 | Packard Bell iMedia 6826 (P481000502) PC...
I cant get sound on my packard bell top
Tell me when did your speakers work fine?
Make sure the speakers are turned on and not set on mute.
Open control panel - click sound option - make sure options are not greyed out here.. if they are then you need to install the sound drivers...
Let me know your computer model number hope that i can paste the link to download the driver..
Thanks..
Mar 27, 2009 | Packard Bell iMedia 6826 (P481000502) PC...
Have disabled vga adaptor:s have no screen now
you have disabled the vga adapter of your system
now start your system in a safe mode by pressing f8 continuosly during the booting, then restore your computer to the back date
Sep 25, 2008 | Packard Bell Easy One Silver 2120 Notebook
Packard bell dest pot lost the facturies setting
have you tryed a diffrent screen? as i had similer problem didnt like crt screens only uses lcd
Jul 03, 2008 | Packard Bell iMedia 6826 (P481000502) PC...
Packard Bell iMedia 6826 (P481000502) PC Desktop Logo
83 people viewed this question
Top Packard Bell Computers & Internet Experts
Alun Cox
carey w mason
carey w mason
Are you a Packard Bell Computer and Internet Expert? Answer questions, earn points and help others
