Question about Cameras
Have installed fujifinepix software but the save image wizard does not appear
  • 797 Answers
You may need to reinstall the software and drivers for your camera.
If that does not work, consider buying and using a card reader which would eliminate the need to have any drivers for the camera, because it is not necessary to connect the camera.
If you have more than one camera, it may make sense to use a card reader instead of installing software for each camera, including drivers.
Posted on Sep 24, 2008
  • Dave Lundmark
    Dave Lundmark Sep 24, 2008
    Reinstall the software and drivers for your camera.
    You may have to download the latest software and drivers for your operating system.
    Using a card reader simplifies the steps taken in down load.
    The new card readers appear as mass storage in the view of drives.
    Most new card readers I have used need no drivers, because the operating system includes these as built in.
Have mx510/512 canon printer/scanner/fax with new windows 10 computer. How do I scan documents or photo into my pc? no scan option when I open canon utility...
Step Connect the all-in-one printer to your computer through the provided USB power cable. Install all drivers that came with the Canon product. Without the drivers the computer is unable to import scanned images to your system.
Step Power on the printer and lift the cover on the top of the scanner bed. Position the image face down on the scanner glass, positioned in the corner when a green arrow points. Close the lid to secure the image.
Step Click the "Start" button, then choose "All Programs," "Accessories" and select "Scanner and Camera Wizard." This is a pre-installed application found on all Windows based computers.
Step Choose the "Scan" option, then select the connected Canon all-in-one printer and click "Scan" again. The image is scanned into your computer with a display of the picture on the screen.
Step Click "File" in the upper left corner of the desktop, followed by "Save." A save window appears on the screen. Title the image, choose a location to save the file to and click "OK." The image file now saves to your computer.
Aug 27, 2017 | Canon Office Equipment & Supplies
Tip
How to Run Software.
Before you run any new software. Close out all programs running.. Insert the Software into the CD-ROM .It will prompt you to click Run or Save this Software .Click Run .Again it will ask you to Run this Software .Click Run and follow the prompts on the screen.The installation Wizard will appear when its time to install this Software. Be sure you Re-Start your computer after installing new Software
on Jan 30, 2011 | Samsung Modem Configuration Software...
When I connect my A350 camere to the laptop the `save images wizard' does not appear. How do I access it?
Just reinstall the Fuji software again. Or even better uninstall it first and than install it again. Without the correct software and the correct driver it won't work.
When you forgot to install the software please do this before you connect the camera.
Feb 21, 2015 | Fuji FinePix A350 Digital Camera
Free software paperport
Sir/Madam
PaperPort installs a PaperPort Black and White Image driver and a PaperPort Color Image driver. These drivers allow you to import documents onto the PaperPort desktop via the print feature.
If one or both of the drivers are missing, follow the steps listed below to run the PaperPort repair program. This program will re-install the drivers:
  1. Open the Control Panel.
2.Open "Add or Remove Programs".
3.Locate and select PaperPort. Click the "Change" button.
4.When the PaperPort InstallShield wizard appears click NEXT.
5.Select "Repair" and click NEXT.
6.Click "Install" to begin the repair process.
7.When the installation is completed a window stating "InstallShield Wizard Completed" will appear. Click FINISH.
8 The repair process is now complete and the drivers will now be installed.
If your question was not answered, please Go To Below URL for Brother Printer Troubleshoot,
OR
If You Still Need Assistance Then Follow US For On :
Brother Printer Support
Feb 03, 2014 | Brother MFC-290C Printer
How do I scan to the computer?
The exact steps to scan will depend on what software you're using. Windows itself has a "Scanner and Camera Wizard" that you can use. Most scanners come with software that gets installed along with the necessary drivers when you run the installation CD. (You do have a properly installed scanner connected, right?)
In general, the steps in scanning are:
  1. Place the item to be scanned on the scanner.
  2. Start the scan software.
  3. Do a preview scan.
  4. Select any scanning options and the scan area as applicable.
  5. Scan the item.
  6. Tell the software to save the image if it's not automatically saved for you.
The fine details will vary, but that's basically all there is to scanning.
Nov 28, 2010 | Computers & Internet
How do i send a scanned item to email
If your scanner software does not have a direct function to do this, you might want a) to get a new scanner (they are cheap nowdays) with a software pack that offers an integration with your favorite email software; b) or you might need to add a few helper-apps to assist you with this task. I use b), and I use Picasa. Here how it works.
1) Install Picasa first (if not installed yet)
2) When saving your scanned images note the default folder where the scanner saves these images.
3) Make sure that Picasa monitors the folder where images (2) are saved.
4) While scanning you can have the Picasa running, then you'll see real-time how your images pops-up in Picasa
5) Scan an image and save it with a default name in the default folder
6) Just scanned image will appear in the Picasa automatically- select this image or images and email them with your favorite email client, you van use gmail right from Picasa, or have your Outlook be integrated with Picasa - your choice.
If you have a gmail account you can publish your images to your gmail personal web photo album and send a link to your friends instead of an image.
Now you can email scanned images and your images are orginized.
Aug 19, 2010 | Computers & Internet
How can I save a scan to my computer? I just got a printer/scanner and there are no Save, or Save As options in the HP scan software?? Help!!!
I would like to know the following, please get back to me
* HP Printer model
* Operating System
* Is the HP Software installed..
as a work around you can perform the steps below to save a scan in the computer.
Try to scan using one of the two methods below:
1. Scanning from Microsoft Paint:
Click Start, click All Programs, click Accessories, and then click Paint.
Click File and then click From Scanner or Camera.
If this option is not available, Please let me know.
If more than one image source is connected, select the
HP all-in-one product and click Next. The scanning software will appear.
Preview the image by selecting Preview, or click "Scan" to scan the image directly into Paint.
The image will open in paint for editing and/or saving.
2. Using Windows Image Acquisition (WIA)
Verify that the all-in-one product power is turned on and the printer cable is properly connected.
Click Start.
Click Control panel.
Click Scanner and Camera Wizard.
Follow the Scanner and Camera Wizard instructions to scan images to the computer.
May 20, 2010 | HP Office Equipment & Supplies
Scan will not work
Step one: Make sure that the Digital Imaging Monitor is ready The Digital Imaging Monitor must be running in order for the Scan To function to work. The Digital Imaging Monitor icon (c01387841.gif ) normally appears in the Notification area at the lower-right corner of the computer screen. The monitor is ready when a check mark appears on the icon after you start the computer. If the Digital Imaging Monitor is in the system tray, skip to 'Step two: Populate the Destination List.' If the Digital Imaging Monitor does not appear in the system tray, follow these steps.
  1. Click Start , and then click Run .
  2. In the Open text box, type msconfig , and then click OK .
  3. In the System Configuration Utility window, click the Startup tab.
  4. Search the list for HP Digital Imaging Monitor . If HP Digital Imaging Monitor is not on the list, the driver was not correctly installed or a custom install was used. You need to reinstall the software. Click here to go to Step three: Uninstall and reinstall the software .
  5. Select the HP Digital Imaging Monitor check box.
  6. Click Apply , and then click Close .
  7. Click Restart to restart the computer.
Step two: Populate the destination list The destination list must be populated in order for the Scan To function to work. Follow these steps to fill out the destination list.
  1. Open HP Solution Center with one of the following methods.
    • On the Windows desktop, double-click the HP Solution Center icon (c01425508.gif ).
    • On the taskbar, click Start , click All Programs , click HP , and then click HP Solution Center .
    If more than one HP device is installed, click the tab for the All-in-One product.
  2. Click Settings .
  3. Click Scan Settings and Preferences .
  4. Click Scan to... Setup .
  5. Click the Destination List tab. NOTE: Depending on the computer performance, it can take several minutes for the Front Panel Destination List to populate after you turn on the printer or computer.
  6. Click each program to include on the Scan To list.
  7. Click the Add arrow.
  8. Click OK .
  9. Scan a document using the Scan To button on the front panel.
    • If the scan fails, try to scan using the HP Solution Center Scan button.
    • If the scan still fails, continue to 'Step three: Uninstall and reinstall the software.'
Step three: Uninstall and reinstall the software Uninstall the software
  1. Unplug the USB cable connecting the product to the computer. CAUTION: Do not reconnect the USB cable until the on-screen instructions prompt you when you reinstall.
  2. Click Start , click Control Panel , and then double-click Add or Remove Programs .
  3. In the list of installed programs, click the HP product, and then click Remove .
  4. Follow the on-screen instructions to complete the software removal. NOTE: If asked to remove shared files, click No . Other programs that use these files might not work if you delete the files.
  1. Turn the product on.
  2. Open a new window to browse to the Select Software and Drivers page:
    1. Right-click this link, Select Software and Drivers , and then click Open in New Window .
    2. If prompted, type your product number. You might also need to click it in a list of similar products.
    3. Click your operating system. (If you do not know, click Start, right-click My Computer on the menu, and then click Properties .) The Select Software and Drivers page opens.
  3. Click the Full Feature Software and Drivers option.
  4. Click Download only . This option allows you to install the software at any time after the download completes.
  5. Click Save , and then browse to the location on your computer where you want to save the file.
  6. Click Save . The software downloads to your computer.
  7. When the download is complete and you are ready to install the files, click Open Folder , and then click the downloaded file. The file name ends in .exe
  8. You can accept the default location to save the files. Click Next , and then wait while the installer extracts the files to prepare for installation.
  9. When the Install Wizard starts, follow the on-screen instructions to install the software. Important : If you choose a Custom type of installation (available for some products), make sure to install HP Imaging Device Functions so that you can scan from the printer. The Recommended installation type installs this feature automatically.
  10. After successful installation, scan a document
May 08, 2009 | HP Photosmart 3110 All-In-One InkJet...
Finepix viewer
The simple answer for all digital camera users that have installed the supplied software is
Remove it.
Windows can do the job mach better.
The windows camera/scanner wizard asking you what to do- you tell it it does it simple huh!
Dec 19, 2007 | Fuji FinePix 2650 Digital Camera
Program error
Sounds like you need to reset all associations. Try this fix from Adobe: CLICK HERE.
Oct 25, 2007 | Adobe Photoshop 7.0 for PC
Cameras Logo
53 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
