I can#t access the guideplus
I have a satellite receiver connected to a CRT tv via a scart loop through a Pioneer DVR-545HX-S DVD/HDD-Recorder. Recently, this 160GB recorder (purchased in Jan '07) won't allow me to make programmed timer recordings - when I try to access the guideplus manual timer recording screen, all controls become locked and I have to restart (by pressing standby button for 5 seconds). I tried disconnecting the power for 24 hrs but this didn't correct the fault. Would optimizing the HDD fix the problem? (I haven't received any onscreen messages [as stated in recorder manual] suggesting this option.) All other functions are operating normally - I can make unprogrammed recordings. I also note that almost from the beginning. the time, date and titles of my programmed recordings tended to move about or become corrupted. But I could always access and edit the recording information until now.
  • 3 more comments
  • dermot1971 Sep 25, 2008
    A FixYa expert suggested optimizing the HDD.
    I tried this but it didn't work.
    I think I maybe dealing with a software fault rather than a hardware mechanical malfunction.
  • dermot1971 Sep 26, 2008
    If it is a software(firmware) programming fault, then how or where do I fix it?
    The firmware update software on the Pioneer website does not address my problem
  • dermot1971 Oct 03, 2008
    Resetting the recorded solved the problem.
    While the advice received from the FixYa experts didn't address my problem directly, it did supply me with more information about problems experienced with my recorder model.
    Eventually, the problem was solved by resetting my recorder.
  • 19,396 Answers
Go to the hard disk setup menu.
Chose initiolized HDD, same as picture below.
Sometimes this can fix the problem.
Regarding the firmware, I do not think there is any firmware update available for download for this unit.
I did not find any download for your product.
Often, the image disk is distributed only to qualified repairers.
Posted on Sep 26, 2008
  • 171 Answers
Perform an EPG setup.
You can select this option going to:
1) HOME MENU
2) GUIDE+
3) Go to SETUP
4) BASIC SETUP
5) Follow the installation menu on the screen.
Enter the postal code and country and switch the unit in standby. After two minutes the host scan will start and EPG is displayed at your display. When the EPG indication has disappeared from your display, switch on the unit and verify if you have the channel list in your EPG menu (HOME MENU -- GUIDE+). If so, return the unit in standby and wait until the next day for receiving all EPG data. If this is not working as indicated, return your unit to your dealer or contact the customer service department to get it to an Authorized Service Centre
  • 3 more comments
  • Todd Gale
    Todd Gale Sep 26, 2008
  • Todd Gale
    How can I do a reset of Guideplus+?
    Enter the basic setup menu of the Guideplus+ and change your country. Return to your normal TV screen to enable your system to do a refresh of the Guideplus+ data by erasing all previous information.
    Then, enter the Guideplus+ menu again to check if the Guideplus+ data have been erased and go to the Guideplus+ setup menu where you reinsert the correct settings.
    Be aware that it might take a day before all data are completely restored.
    You can also reset the recorder to its factory settings.
    Make sure that the recorder is on, use the front panel buttons and empty the disc tray. Press and hold STOP and press simultaneously on the STANDBY/ON button. Now the recorder turns off with all settings reset.
  • Todd Gale
    Todd Gale Oct 03, 2008
    Please rate this solution.
  • Todd Gale
    Please change you vote to reflect toddg provided this solution, and not welcomejee as we get monitored and votes counts for the individual that in fact posted the correct solution, which in this case was toddg/ Thank you for your help in correcting this error.
  • Todd Gale
    We kindly ask that you revise your vote to reflect toddg provided this solution, and not welcomejee. In order to provide fair and correct scoring, it was toddg that provided the solution for resetting the unit and seeing as that, in fact, was the correct solution, we would like him to get credit for the solution provided. Please take a moment to correct this error. Your votes are very important to us and we appreciate when the correct individual is credited with providing the correct solution. Thank you in advance for your understanding and for taking the tme to correct this error and for using FixYa.
  • 10,594 Answers
Please go to Pioneer Support and see 3 firmware updates for you model DVR-545HX
Above said web page also describes procedure how to update firmware.
Hope this info will help you to resolve problem.
" Firmware History File Model: DVR-545HX Ver 2.19 The update improves recording from a connected external receiver and prevents, in some exceptional cases, the unit from displaying the message "content is copy protected" when recording unprotected content. Ver 2.20 The update improves: - copying a title from HDD to DVD+R or DVD+RW in certain copy modes (real time copying in MN29 and MN30). - recording audio of a scrambled program from an external decoder when scanning HDD titles or pausing HDD titles. Ver 2.21 The update improves that some DVD's are not completely loaded (Disc eject and Playback is not possible)"
    Brigadier General:
  • 6,966 Answers
If all else appear normal, then it would seem to be a firmware/software glitch and flashing/updating the firmware may be required. Procedures for performing this may be found here. The actual update file may be found here.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
  • Louie  Role
    Louie Role Sep 26, 2008
    Perhaps I was unclear in my initial post.
    Your unit is a Pioneer DVR-545HX-S. Your last post was "...software(firmware) ... how or where..."
    how or where - pls click on this link, http://www.pioneer.eu/eur/content/suppor..., it is the step by step procedures for DVR-545HX-S Software Update.
    Cheers.
  • 1,879 Answers
Time & Date becomes corrupted ? Yes It is a software (firmware) fault.
Posted on Sep 25, 2008
  • monk3ybidzness
    monk3ybidzness Sep 26, 2008
    Firmware update for DVD players ? Ask their repair center cause there's no way you can connect it to a computer like an iPod to update it's firmware.
    You don't want to have it sent to a repair center ? Get a new one.
    President:
  • 1,952 Answers
It is quiet and also has a timeshift function. It tuned in the TV stations available and labelled them correctly. It allows timer recordings and the manual was really easy to understand in regards to set up and how to record to HDD, edit it, and burn to DVD.
It also has a DV input and USB input located on the front of the unit to allow transfer from these sources as well as standard video connector too.It also allows you to access the HDD easily so if it needed to be replaced (or upgraded in size) you could do so easily.
Posted on Sep 24, 2008
    Genius:
  • 1,011 Answers
Dear,
did u change any setting as it was configured before. if yes  then get that back
regards,
dont rate it until satisfied
  • SALMAN NASEER Sep 24, 2008
    dear,
    check this link for further details
    http://www.avforums.com/forums/archive/i...
    regards,
    Master:
  • 726 Answers
You have to optimize the hdd to rearect the problem it works for me when i had that set up
Can I record programmes with a Sky box as the input source? I do not have a tv aerial, just a sky dish.
No, it can only record from its own tuners via an aerial, not from a scart connection..
Aug 07, 2015 | Humax PVR9300T HD DVR
Will it work with analogue TV using scart and without old free view box
Depends what is on the satellite receiver. If there is a SCART connection, you can put it in your TV. As soon as the satellite receiver only has a HDMI, you can't connect them.
Be aware, that even digital receivers for analog TV receivers, with both, SCART and HDMI often not forward digital signals, because of copyright restrictions. Not even not copyrighted content.
Mar 02, 2015 | Televison & Video
Why can I not get the menu setup on my screen for the sunluxy dvr
Hi you don't say how you have it connected . But if you have it connected by scart take out the scart lead and try a different one it could be the scart lead is faulty or if you have HDMI socket on your DVR try connection that way that's if you have HDMI on the TV let me know how you get on
Nov 24, 2014 | Televison & Video
Does the pioneer dvr-720H-s connect to digitial tv?
The pioneer dvr-720H-S doesn't have a digital tuner. It has a PAL and a SECAM tuner (the European version). You'll need a digital to analog converter or a cable/satellite receiver to provide a signal for the unit to record the digital channels.
The specification list for the DVR-702H-S is available here: http://www.pioneer.eu/eur/products/archive/DVR-720H-S/index.html .
I wish that I had better news for you. Note: the most common D-T-A converters have SD output.
(I know in the UK the digital format is DVB-T2 for FreeView)
Jul 22, 2012 | Televison & Video
Can irecord on my dvr 220 pioneer from my new freeview tv
Yes you can do this. You just need to make sure that the TV outputs its picture on the scart lead that you have connected to the Pioneer unit, and you need to set the Pioneer unit to record from that scart input. Once this is done, it will be able to record whatever you have on the screen. Be aware though, if you turn off the TV it stops outputting its picture to the recorder, and if you change channel, it changes what what the recorder see's too. I hope this helps you. :)
Jul 20, 2010 | Pioneer DVR-220 DVD Recorder
How to set up Archos DVR Station but unsure how
Hi awillis98 this is Mike Houston of DISH Network, with the Archos DVRstation there will be a USB connection from the device to the DISH Networkreceiver, one the DISH receiver has recognized the external hard drive you willsee pop-ups on the screen that will walk you through the steps to configureyour Archos device. I will send a link to help with the setup for the externalhard drive. http://www.dishnetwork.com/SupportSection/setup-ehd
Apr 21, 2009 | DISH Network ViP622 DVR DTV Receiver /...
Can i plug in a scart item into the dvr and use it to record?
neither of this sagem's two (analoge) scart connections can be selected as a (digital) recording input. so, no it cannot be used to record the output of a cctv camera.
Apr 05, 2009 | Televison & Video
Pioneer 503mxe cant wire it up
To connect as you describe you will need a tuner card as the 503MXE is a monitor rather than a receiver. Otherwise the only option is to connect a scart to the 5xBNC connectors (Input 2) but you will need to be sure that your digi box outputs RGB over scart. If you have the optional video card (PDA 5002) fitted then you can connect via the s-video connection (Input 3) assuming your digi box has an s-video output.
Dec 14, 2008 | Pioneer PureVision PDP-503MXE 50 in....
Reception upgrade or what ?
Older sets are fitted with analogue tuners which can't handle digital signals. The only way round the problem is if the TV can be used as a monitor via a scart input. The external freesat or digital set top box contain digital tuners which can then display the required digital information on the TV. These external units have scart output sockets at the back, specifically for this purpose. So it's a scart lead from your external digital device to the scart input socket at the back of the TV. The remote control for your external box is then used to select the required programmes
Oct 24, 2008 | Panasonic Televison & Video
How to connect DVR 1600 to LCD HD TV or ATT uverse recorder
has to be scarts, your reciver (sky, cable ect ect) to your dvd recorder, from that to the tv, all scarts, might help, regards mark
Feb 01, 2008 | Cyberhome DVR 1600 DVD Recorder
Televison & Video Logo
173 people viewed this question
Top Televison & Video Experts
Electro Med Services...
