Question about Palm Treo 755p Smartphone
Treo 755p Getting Stuck During HotSync
My treo 755p is getting stuck while trying to hotsync....it's always during the point of the datebook...I've uninstalled the software and reloaded...I've tried unchecking the datebook from the hotsync list, letting it sync and then rechecking the datebook...soft reset....nothing. I am trying everything to prevent a hard reset....any suggestions?? Please help!
  • 1 more comment
  • laureldavila Sep 24, 2008
    Nope, have tried another computer with no luck :( And yes, after I unchecked the datebook it was able to sync just fine....my datebook is what i live by....I really need to fix this...I am trying everything to avoid a hard reset... any other suggestions??
  • captverizon Oct 05, 2008
    palm frozen trying to synch connected to computer it synchs with problems then frezzes in z"cleaning up" mode.
  • Anonymous Feb 28, 2009
    I am having the same problem, and everything else synchs, but when I try to do the datebook alone, even then it freezes and I have to cancel the process and then restart the computer. I'm using Windows XP. Did you fix your problem??? Does anyone know how to fix this problem??? I'd even uninstall the Palm software on my pc and have all information taken from the phone to the pc, if needed, but would want to know that the problem will not reappear. Also, I don't know how to do the uninstall. HELP!
  • 59 Answers
If you have another computer you could try installing the software on that to see if the Treo will sync.
This would determine if it's a computer problem or if it's your Treo.
When you unchecked the datebook to sync after uninstall/reinstalling, was it able to sync then?
I have had other palms get hung up to a certain point during the sync, but uninstalled the program or disabled it from syncing like you tried and it usually works.
Posted on Sep 24, 2008
  • Eduard Vander Smitte
    Eduard Vander Smitte Sep 24, 2008
    This is what I found elsewhere-
    Get a trial of TealScan and run the scan functions to see if you have
    any corrupt data. If so, hit "Info" at the bottom and then hit "fix."
    Then try to hotsync again. DBFixit is another app that will do this,
    but not in trial mode.
    Someone solved their problem this way with that -
    The problem is solved. I've scanned calendar by trial version of
    dbfixit, it found 3 BLOB errors, then I went to each found date and
    deleted wrong records in original palm desktop. Then synced again. Now
    it syncs w/o freezing on datebook in the second palm desktop.
    So if somebody is having this problem I would suggest to scan it with
    DbFixit, write down dates where are any errors, manualy modify that
    dates and scan again.
Suddenly when I try to sync the Treo with the MAc(OS10.6.2) I get the following message: The application "HotSync Manager" could not be launched because of a shared library error: "" I had been...
You will most likely have to reinstall Palm Desktop because either a Shared Library is always in use or it's missing. A reinstall should help.
Feb 05, 2010 | Palm Treo 755p Smartphone
How do you hard reset on palm treo 755
Hard resets on a 755p are described in the user's guide as removing the battery (with the phone off, and screen off), and then pressing the Navigator-UP button and holding until you insert the battery again, and you see the Orangle PALM logo displayed, where you can release your Nav-UP button. This does not work.
You need to hold down on the red power button, until the Orangle PLAM logo shows up, release it, and you will see a question like "do you want erase all of your data?" , press the Nav-UP button, and it will now do a clean hard reset.
Now, on the backup folder.
If you do not change user-names, and your PALM Hotsync setting for 'Backup' is set to 'Desktop overwrites handheld' you will get everything back when you HotSync. Therefore, if you delete the problem App's from your Backup folder (ie C:\palm\755p\backup, where 755p = your HotSync name) and you change to the settings on 'Backup' to 'Desktop overwrites Handheld' - then when you hotsync, you'll get the app's you want back, and not the ones you do not.
I hope this makes sense.
Sep 18, 2009 | Palm Treo 755p Smartphone
Treo 7550 - Recovery from crash without Palm Desktop Sync
no u must always hotsync every weekend, he will loose his data completly!!
srry
May 11, 2009 | Palm Treo 755p Smartphone
Volume will not adjust on Treo 755p
This may resolve the problem. My Treo 755 stopped hotsync some time ago and then I noticed that the volume control side buttons had no effect. On suggestion from this site, I removed the battery for several minutes and then reinstalled it and the phone has returned to normal activity, hotsync-ing the first time and volume buttons working fine.
Jan 08, 2009 | Palm Treo 755p Smartphone
Treo Palm 755 Treo Smartphone sycronization software
Here is the link for the latest version of Palm Desktop and Hotsync Manager:
http://kb.palmone.com/SRVS/CGI-BIN/WEBCGI.EXE?New,kb=PalmSupportKB,t=ooccase,case=obj(32859)
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Jan 07, 2009 | Palm Treo 755p Smartphone
I cant get my treo 755p to sync with my vista laptop.
Download the latest version of the Palm Desktop and Hotsync manager from here:
Thanks, Joe
Palm 755p Treo does no sync all contacts--missing contacts on Palm
Ive had this same promblem. I had to uninstall Palm desktop and Hotsync Manager and reinstall a different one that I got from the internet.
trweekes
Aug 22, 2008 | Palm Treo 755p Smartphone
My treo 755p gets 8 color boxes when I restart it
I got the 8 color boxes as well. It kept trying to Hotsync when I didnt even have it plugged up. I had to bring it to the store and buy a new one.
Are they selling the iphone 3G's for alltel?
Jun 11, 2008 | Palm Treo 755p Smartphone
Selected com port not available
Please un-install and re-install the software,, that should fix the problem,
Jun 09, 2008 | Palm Treo 755p Smartphone
Treo 755p phone audio stops working
try doing a hard reset just make sure you hotsync first so you can backup all your information. Always keep in mind the software you have loaded write it down and the website you got them from along with any registration codes. when doing a hard reset you will lose all the information and programs on the phone basically it will take you back to the way you first bought it.
How to Hard Reset a Treo 755 To perform a hard reset/clean wipe of a Treo 755, do the following:
1. Remove the battery cover from the back of the device.
2. Press and hold the power (red phone) button.
3. While holding the red power button remove and replace the battery from the device.
4. When you see the "Access Powered" screen on the device take you finger off of the power button. At this point, you'll be prompted to erase the device by pressing up on the directional pad.
Good Luck I hope this helps with your problem
May 27, 2008 | Palm Treo 755p Smartphone
Palm Treo 755p Smartphone Logo
882 people viewed this question
Top Palm Computers & Internet Experts
Michael Vincent Cruz
ray gallant
Raj Patel
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
