Question about Whirlpool Dryers
I have an upright washer dryer unit from whirlpool which is about 4 years old. The model number is YLTE623DQ3. The dryer is not heating up. I performed all of the trouble shooting as per instructions. I believe the element is probably gone. Is this hard to change and how much would a new element cost.
  • 943 Answers
Hi thanks for the question the heater is part # 3387750 and no its not hard to change the bottom panel comes off and the heater is on the right did you check to see if you had 240 volts coming in thanks the appliance doc
Posted on Sep 24, 2008
How much is this Model worth? 6 years old?
Worth Not much as life expectancy on most new appliance is 4 years or less ,it called plan obsolescence or made to fail as economy is based on consumerism not quality
Aug 20, 2014 | Whirlpool Duet Front Loading Dryer Rack...
My 4 1/2 year old electric Whirlpool dryer runs
If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Apr 26, 2010 | Whirlpool WED5100SQ Front-Load Electric...
Unresponsive control panel- Whirlpool duet dryer 4 years old
This advise is for Kenmore Elite and Whirlpool Duet front loader washers and dryers with a Control Lock problem.
This may or may not be an indication of a serious problem. In the majority of the cases, this is a simple operator error. Nearly all these model appliances have some sort of Control Lock feature on the front panel now. This is a designed safety feature that is used to prevent small children from manipulating the controls. The controls can be easily locked or unlocked by pressing and holding the following button on the front panel:
Whirlpool Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Whirlpool Duet Dryer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Kenmore Elite Washer - Press and hold the DRAIN/SPIN button for 3 seconds.
Kenmore Elite Dryer - Press and hold the AUTO DRY LEVEL button for 3 seconds.
These instructions may not be all inclusive for all Kenmore and Whirlpool models, but they are the most common. Chances are, if you have a Control Lock feature, the instructions will be printed on the front panel adjacent to the button that is required to lock or unlock the controls.
NOTE: These instructions may also work for newer model Maytag, Hotpoint, Admiral and Fridgidaire model front loaders as well. Refer to your owner's manual or front panel for instructions pertaining to your sepcific model.
If the Control Lock feature will not lock or unlock the appliance, unplugging the unit for AT LEAST 30 minutes is recommended in order to reset the main control board. In many cases this is all that is required to correct momentary glitches.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.&&&^^^
Nov 03, 2009 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Whirlpool dryer not heating up
It does not have a pilot. It uses a glow bar ignition system. You probably have a bad glow bar if it is not heating at all part number 279311
Apr 06, 2009 | Whirlpool LGR3624JQ Gas Dryer
My dryer will run but won't heat
you either need a new heating element or limit switches
Nov 02, 2008 | Whirlpool LER8648P Electric Dryer
Dryer no longer heats up on my Kenmore 417.94812301 laundry stacked unit
On your dryer the common problems found is either you lost some of your electrical power (check your fuse box) or you need a new heater #131475300 about $100 for the part.
Jul 28, 2008 | Kenmore 98702 Stacked Washer/Dryer
Whirlpool Combo Washer Dryer LTG6234AW2 - Dryer wont heat
Go to: RepairClinic.com
There you can troubleshoot
you appliance.
You'll need make & model #.
Jul 19, 2008 | Whirlpool LGR3624JQ Gas Dryer
Dryers Logo
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
