Question about Mitsubishi CS-40503 TV
Mitsubishi Model CR3515R White Gray lines cause picture inversion.
I have a Mitsubishi Model CR3515R539823. It has developed multiple white/gray lines half way through the picture. The lines cause an inversion of the picture. After about 30 minutes the picture stabilizes except for the very top of the picture tube, about 1/2" stills remains inverted..
  • 55 Answers
Your having trouble with the vertical sync/deflection circuitry. Probably a driver since it clears up after it gets warm. Could be as simple as a cold solder joint but it's not something you can do yourself unless your a tv repairman.
Posted on Jan 17, 2009
I'm looking to purchase a used car. I've been doing online research and saw this webpage http://www.usedcarsmells.com . They talk about exhaust color and smells. Is it true that you could tell a lot about...
Yes this is correct, you can get important information from the colour of smoke from the exhaust:
Blue/Gray Smoke: Blue/gray exhaust smoke is an indication of oil burning in the combustion chamber. These are possible symptoms and causes:
Valve Seals: Leaking valve seals will cause blue/gray smoke at startup because oil leaks past the seals into the cylinder after the engine shuts down.
Valve Guides: Excessive clearance between the valve stem and the valve guide allows oil to leak past the gap into the cylinder.
Piston Rings: Worn or damaged piston rings will cause blow-by resulting in blue/gray smoke.
Worn Cylinder Walls: Worn cylinder walls cause blow-by resulting in blue/gray smoke.
PCV System: A stuck closed PCV valve will cause excessive crankcase pressure resulting in blue/gray smoke.
Black Smoke: Black exhaust smoke is an indication of a rich fuel condition. These are possible causes:
Fuel Injectors: A leaking or dripping fuel injector will cause a rich fuel condition.
Fuel Pressure Regulator: A stuck closed fuel pressure regulator will cause a rich fuel condition.
Fuel Return: A restricted fuel return line will cause a rich fuel condition.
White/Gray Smoke: White exhaust smoke is an indication that coolant is burning in the combustion chamber. These are possible causes:
Cylinder Head: A crack in the cylinder head (around the coolant jacket) will cause coolant to enter the combustion chamber.
Engine Block: A crack in the deck of an engine block near the coolant jacket will cause coolant to enter the combustion chamber.
Head Gasket: A damaged or blown head gasket will cause coolant to enter the combustion chamber resulting in white/gray smoke coming from the tailpipe.
Jan 17, 2015 | Cars & Trucks
How do i install a new radio i dont know what colors are what for a 2002 galant
MITSUBISHI / GALANT / 2002 / Audio
Radio 12v red/white + radio harness
Radio Ground (chassis)
Radio Ignition blue + radio harness
Radio Illumination green/white + radio harness
Factory Amp Turn-on
Power Antenna N/A
LF Speaker +/- white/blue - black/blue +,- radio harness or amp
Notes: The amplifier is under the passenger seat.
RF Speaker +/- white/red - black/red +,- radio harness or amp
LR Speaker +/- yellow/blue - gray/blue +,- radio harness or amp
RR Speaker +/- yellow/red - gray/red +,- radio harness or amp
Mar 16, 2011 | 2002 Mitsubishi Galant
Hello, I would like my pictures to have a white background. When I take the picture on a white background the background ends up looking gray. I am taking pictures of baby clothing and I want the clothing...
Exposure meters are designed on the premise that the scene is an average, middle gray, in brightness. If you take a picture of a white dog playing in the snow, the camera will try to make the picture come out middle gray (a gray dog playing in gray snow). If you take a picture of a black cat sitting on black asphalt, the camera will try to make the picture come out middle gray (a gray cat sitting on gray ground).
If the white background is dominating the scene, the camera will reduce exposure to try to make the entire scene come out middle gray. The solution is to meter on something else. Move in close and fill the frame with the subject, press the AE-LOCK button, then move back, compose the picture, and take the shot. For full details, refer to the "Shooting with the exposure locked --- AE-LOCK" section in the manual (page 52 in my copy).
If you're taking a lot of pictures, you might want to switch to Manual mode and set the exposure accordingly.
Dec 29, 2010 | Sony Cyber-Shot DSC-F717 Digital Camera
I have a f350 crew cab 1997 5.8 and while drivin and after take off the truck loses power and shakes then stops seems like only when accelerating this happens.
Hello! There are two sensors that will cause this problem both can be tested...If you have a volt meter...If not, let me know...
#1 is the Throttle Positioning Sensor (TPS)...A black round device that is bolted to the throttle body with a three wire connector...Wire colors are...Gray/White...Brown/White...And Gray/Red...Using two safety pins plug them into the rear of the in place connector on the Gray/White...And Brown/White...Place + probe of meter set to read 5 volts on the Gray/White...And - probe on Brown/White...Start engine...At idle must read less than 1 volt (.85)...As you slowly increase throttle meter must rise smoothly to 4 volts at open throttle...If voltage jumps or acts erratic the sensor is defective...
#2 is the Manifold Absolute Pressure (MAP) sensor...Also mounted to throttle body...Three wire connector with the following wire colors...Light Green/Blue...Gray/Red...And Brown/White...Using the same technique...Pin the rear of the connector on the Light Green/Blue...And the Brown/White...Place + probe on Light Green/Blue and - probe on Brown/White...Turn key to on (don't start)...Record reading...Move Light Green/Blue probe with safety pin and push it into the Gray/Red wire...Record reading....Also check the vacuum line which is connected to the Map Send results...
Cost...TPS=$55............MAP=$95
Guru.................Saailer
Aug 27, 2010 | 1997 Ford F350 Crew Cab
Need radio wiring diagram for 2001 mitsubishi eclipse
CHeck HERE the 2001 diagram.
Hope helps (remember rated this).
Jul 05, 2010 | 2001 Mitsubishi Eclipse Spyder
I take pictures of white puppies on the same table in the same room.. some of the lighting is fine, some dark could it be the sandisk..??
Most likely it's the camera. Almost all cameras are designed to meter the scene as a medium gray. If you photograph white puppies in the snow, the camera will try to make the whole picture come out a medium gray, leading to gray puppies in gray snow. If you photograph black puppies in a coal bin, the camera will again try to make the whole picture come out a medium gray, leading to gray puppies in gray coal.
For this reason most cameras provide some means of adjusting the exposure. Since you didn't specify the make and model of your camera, I can't tell you exactly how to do it. Please look in the manual under "Exposure Compensation."
Jul 02, 2010 | SanDisk ULTRA II 4GB Compact Flash Card...
Panasonic CT-27L8SG displays gray screen and white hoizontal line
Is it still under warranty?
If not I would find a good TV Service Shop and have them check out the power supply as there more than likely a 'Capacitor' much like a battery that is going bad.
Blessings,
A/V Media Guy
Nov 22, 2009 | Panasonic CT-27SL14 27" TV
Gray screen with horizontal lines accross it
sounds like you may have a bad ic it probley is a surface mount on the bottom of the board it could couse this problem would need to take to a shop to repair. The ic probley is numbered ic101 on board.
Mar 01, 2009 | Sanyo DS32224 TV
A series (10) vertical lines on print outs
See Charge roller my be dirty or Catriges PCU Units
Jan 22, 2009 | Ricoh CL3000E Laser Printer
Baseball fan
Here's the wiring: black from box to black from fan; red from box to black with white line from fan; copper from box to green from fan; white from box to white AND gray from fan. Hope this helps.
Jan 17, 2009 | Hunter (25417) Ceiling Fan
Televison & Video Logo
74 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
