Zanussi 24 in. DE6544 Built-in Dishwasher
Problem for Zanussi 24 in. DE6544 Built-in Dishwasher
Failure to start cycle
By kerls65 on Sep 24, 2008
the cycle starts and then the selector light and the top light on the side panel flash continually
Solution #1
posted on Sep 24, 2008
Not Rated)
namizhka
Rank: Wiz
Rating: 83%, 66 votes
WHAT IS THE EXACT BRAND/MODEL AND NUMBER OF YOUR APPLIANCE...?
DID YOU TRY TO RESET THE UNIT, BY UNPLUGGING IT FOR A WHILE INTO THE POWER OUTLET...?
Solution #2
Not Rated)
libra_eng
Rank: Wiz
Rating: 82%, 338 votes
dear,
read its manual carefully i supposed it contain the solution. if you dont have here is a link to it
or check it by the way. may be its a little bit more detailed than u have.
http://safemanuals.com/user-guide-instructions-owner-manual/ZANUSSI/DE6544-_E
regards,
dont rate it until u satisfied
Solution #3
Not Rated)
naguu
Rank: Guru
Rating: 85%, 195 votes
Please reset the unit once by unplugging the power cable of the device.
and also mail me the brand name and the type of your device, so that i can give you the exact solution.
This is often the electronic control card, or motor relay, but it is often worth unplugging and reseting any component connector plugs and sockets, as they can work loose, and low-level electronic sensors rely on good connections. Pay particular attention to any plug and socket that looks corroded, burnt, brown, or otherwise discolored compared with the rest. High resistance contacts can create intermittent faults, and cause high current parts of the machine to stop working (e.g. heating elements, or motors) Pull off any suspect plug/socket, and clean the contacts with a small file or emery board . Try above steps hopefully it should work. Thank you........
Comments:
Sep 24, 2008
- If you have any queries regarding the machine please click on the below link or copy the URL and paste it in your web browser.
http://www.diyfaq.org.uk/electrical/washing_machine_faq.htm
Thank you.......
Solution #4
Not Rated)
jonniewalker
Rank: Guru
Rating: 88%, 598 votes
  • Test the timer motor
  • Test the thermostat
  • Test the heating element
  • Comments:
    Sep 24, 2008
    - Before testing the timer motor, unplug the dishwasher or shut off the power at the fuse boxor breaker panel to avoid an electrical shock hazard. The timer motor regulates the length of time power is routed to each component. If the timer motor does not function properly, it can result in a wide range of problems. Common symptoms include sticking in a cycle, cycle times problem or failure of the dishwasher to start at all.
    window.google_render_ad(); To service the timer motor, it is necessary to access the control panel in the door. Access varies by model; on some models you can remove just the control panel on others you must remove the interior or exterior panel of the door.
    Popular Solutions for Zanussi 24 in. DE6544 Built-in
    Questions and Unsolved Problems for Zanussi 24 in. DE6544 Built-in
    Do you recommend Zanussi 24 in. DE6544 Built-in Dishwasher?
    Answer
    Answer
    my dishlex 200 is stuck on the eco cycle. Tried resetting by pressing both start/program buttons,... (More)
    Answer
    Dishwasher,zanussi DW 905, not using rinse aid, and it shows. Adjusting dose control makes no... (More)
    Answer
    I have exactly the same problem on my Zanussi DE6544 as one previously posted by eimusi on 6 Aug 09... (More)
    Answer
    Answer
    how do you access the door micro switch, in order to replace it.
    Describe your problem:
    Select a Category:
    Ask our Experts
    Solve Your Problem Now!
    Chat Live with an Expert
    Chat Now
    Browse popular Problems
    More Common Problems
    Most Common Problems for:
    For Zanussi 24 in. DE6544 Built-in...:
    Top Dishwasher Experts
    Rank: Guru Guru
    Solutions: 3922
    Experience: 30 yrs exp home bldg, plumbing, wiring, framing, design & spring water usage. Problem solving.
    Ask Me
    Find more Dishwasher Experts
    Top Dishwasher Repair
    (423) 303-3783
    Dishwasher parts delivered overnight nationwide....
     Appliance Parts Pros.com
    (800) 905-9505
    A&E Factory Service is a nationwide leader in...
    A&E factory service
    Chat Now
    X
    Continue
    When the original poster rates a solution that was given to his own problem, that rating is locked!
    X
    Are you sure the solution content is Inappropriate?
    Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
    Insert Link
    Insert Image
    Insert You-Tube clip
    Insert List
    Insert List
    Spell Check
    What is this?
    Select
