Question about GPS
Navlink gps how do i put music or pics onto my navlink gps ??
Just copy all your songs and videos on a sd card and your navlink should be able to play them i did this and i have no problems with it
Posted on Oct 28, 2008
I love my Navlink GPS but it now fails to work when plugged into lighter socket. If it is switched off, it charges, but it doesn't charge when switched on: thus, while operating, the battery runs out.
It sounds like the battery in the unit is beginning to go, it will have to e sent in for repair. But try giving it a quick firmware update using Garmins WebUpdater it could possibly fix your issue.
Dec 09, 2010 | Garmin nuvi 750 GPS Receiver
I`d like to use the mp3 on my GPS but don`t know how to put music or pics on
You need a standard SD digital memory card (not the newer HC high capacity cards as Magellan does not guarantee compatibility although I did get one to work that was a micro SD card with the full SD adapter). You will need to put your mp3 music files from your PC onto the SD card just as you would your mp3 player; insert the SD card into an SD slot on your computer, laptop or USB adapter and copy the files to the card. After files are saved, put the card into the slot on the right side of the Maestro and then refer to the User Manual (http://www.magellangps.com/support/product.asp) page 64 to see how to play the music. You can play through radio speakers or by using headphones/ear buds with a USB connector.
Oct 11, 2009 | Magellan Maestro 4350 GPS Receiver
Got no sound on my navlink gps
reset it. if that dont work go to reset in menu
Jul 15, 2009 | GPS
How do you download music to your gps
You do not download music to the GPS, put music files onto a SD card and then put that card into the GPS. You have to remove the Map SD card to do this so you cannot play music and use the GPS at the same time.
Jun 23, 2009 | Nextar X3B GPS Navigation System
2 navlinks with the same problem
Hey Guys
Found a patch that fixes this issue
Applied it to both my Navlinks and both are working fine now
Attached is the link
http://www.navsupport.net/gps/quickfix/index.html
hope this helps anyone else
Jun 20, 2009 | GPS
NAVLINK NO GPS SIGNALand sometimes shows grey signal strength which means not strong enough to receive, help needed to fix this problem. tthanks
Happened to me recently,  showing grey signal bars but never locked (turn blue) so I was quite frustrated by it as I've only used the system a few times.  I have chased up a few suggestions from the web & the one I tried work.   Some suggested using Sirfdemo to reset the GPS receiver to NMEA mode as they could accidentally go into SIRF mode if the device is left active but has no view of the sky for an extended period (can easily happen if you left the unit in standby mode and placed the GPS in the glovebox).   The other solution is to remove the battery for anywhere from 24 hours to 7 days so that the SiRF chip capacitor will reset itself ...this is the solution I tried -  I left my unit without the battery for about 5 to 6 days and it came back to life again,  I've read some people left their GPS (albeit not Navlink) off for 4 days but still didn't work but retried again for 7 days and it worked.  Remember, once you place the battery back in I think the capacitor is charged up again so if it was not left off long enough you'll have to start counting from day 1 again.   All the best.  Jono
Jun 16, 2009 | GPS
Need instructions on puttin photo onto PSP
first, you need to plug the psp into a computer.using the computer, go to the mem stick and find the file MUSIC. if there isnt one, then create one. place your music in that folder.
for pics, go to the mem sick and find/create the file PICTURE.
place pics there
note:make sure the MUSIC and PICTURE folders are in caps
Jan 26, 2009 | Sony PlayStation Portable (PSP) Slim...
Navlink gps says receiver cannot be found
my boyfriend had the same problem and as like everyone else u cant contact betterstore(ebay/oztion seller, who is also same person running navlink site).
when we had this problem my boyfriend contacted a different seller brashimports on ebay (03 9523 8899 or u can try www.brashimports.com.au) and bought a new software card off him and it fixed the problem, and now we just had another problem with our navlink as the screen has turned white and we rang him and he said screen is stuffed and so now i have to send him a pic of the screen out of the unit to see if its the same and if its the same as his screens hes gonna help us with that too, he was a lifesaver for us hopefully he can help some of you other people having problems with the navlink units as my boyriend was ready to use a hammer on it both times.
Jan 08, 2009 | GPS
My navlink gps says "not find navigation software"
If you haven't already fixed this; try going into, settings, navsetup, - this should give a Path of navigation software line, this line should read: '\StorageCard\iGO8\iGO8.exe' click on file icon at end of the path window "select storage card, select iGO8.exe, select tick to apply then exit.
This works for mine but I assume that if an alternative software is shown in the path window you must choose an approppriate .exe file in the storage card files.
Oct 28, 2008 | GPS
To download
The manual is helpful isn't it?
Your music and pictures need to be installed onto a SD memory card. Take an empty card and copy the MP3 or pictures onto the card. Install the card into the GPS. Use the correct player (for pics or MP3) and see if it detects the music on the memory card.
It seems like it works the same way if you were to put music or photos onto a Palm. It may need a special folder on the card to read the photos or MP3s. I would put it into the GPS first, let the GPS format it, and see if it creates folders for them.
Jun 17, 2008 | Fine Digital FineDrive 350 GPS Receiver
GPS Logo
200 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
