Question about Panasonic SC-AK75 Shelf System
Panasonic SC-AK750 Mini hifi
Thanks for the information about
Panasonic SC-AK750 Mini System that shows F61 on the screen before it switches off.
Is the problem repairable? How could it be repaired.I would like to know what will be done before I take it to the tech guys.
Thanks
  • 1 more comment
  • mal123wain Sep 25, 2008
    Thanks.
    This is very helpful.
  • mal123wain Feb 18, 2009
    Yes I can confirm of the AM antenna that the generic one is alright I have compared with SC-ak750 with an Aiwa, they look the same. The FM antenna tips look a little different but the receiving end on the hi-fi looks the same so I assume the generic one should be alright.
  • Anonymous Mar 17, 2014
    Have a problem with the usb playback where anything plugged into it plays back with a real bad fuzz but all other modes work fine
I just acquired an SC-AK750 which doesn't have either an FM or AM antenna. Can I use generic antennas from **** Smiths or similar. Also, I know the unit is second hand - how old is it? Thanks for your help.... Di
Posted on Feb 06, 2009
  • 4,234 Answers
The problem is usually either the amp-pac or a regulator. If the problem is the amp-pac, expect to pay around $90 or so for the part alone. The regulator is much less. Yes the unit is repairable, but get an estimate on the cost as some of the newer units may be close to that cost as a replacement.
Dan
Posted on Sep 24, 2008
I require a user manual for a panasonic SA AK 750 stereo system
Hi pjwivell ..
Are you sure that it SA AK 750?
well here is a here for SC AK750
download the manual and try if it works for you..
http://www2.panasonic.com/consumer-electronics/support/Audio/Home-Theater/Mini-Systems/model.SC-AK750
please give me update if you had any success... thanks
Jun 27, 2011 | Audio Players & Recorders
F61 will not come on
F61 is an error code that shows amplifier output chip is defective and need to be replaced in Panasonic SC-AK640 unit.
Amplifier output chip replacement requires soldering work and local repair shop will do this job as it is not user level repair.
Hope these info will help you.
Let me know if you have additional question.
Thanks.
Feb 10, 2011 | Panasonic SC-AK640 Shelf System
AFTER A FEW SECONDS MY SYSTEM SHUT DOWN AND SHOWS ME F61 ON THE SCREEM
  1. AFTER A FEW SECONDS MY SISTEM SHUT DOWN AND SHOW ME F61 ON THE SCREEN
Oct 25, 2010 | Panasonic SC-AK300 CD Shelf System
Panasonic SC-HT995 locked
check the fan, if its dusty clean it then run the player. If it works, your in luck. If the fans are moving and f61 still shows up, the D-amp IC is shortened ( inside you will see IC 5000/IC5200 / IC 5300, these needs to be replaced) its the one by the big cooling fins (behind the rear fan)
Nov 11, 2009 | Panasonic SC-HT995W System
I have Panasonic SC-AK750 Mini System and of late it keeps showing F61 on the screen before it switches off. do you know what it is
The F61 indicates protect mode. This means that a problem was detected inside and the unit shuts down to prevent further damage. This is usually the output amp pac or the regulator IC. The amp is attached to the heat sink in the rear of hte unit and should be marked RSNxxx.
Dan
Sep 11, 2008 | Panasonic Audio Players & Recorders
F61 Error
take off your fan on the back and clean it this fixed mine
Sep 05, 2008 | Audio Players & Recorders
Error
The audio amplifier IC are damaged.
Aug 20, 2008 | Panasonic SC-AK17 Shelf System
295 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
