PLEASE DON'T FORGET TO RATE!!!!
After removing the cooling fan assembly, remove the water pump pulley-4.3L engine
Location the water pump pulley bolts-2.2L engine
If the pulley turns when you try to loosen the bolts, attach sockets and ratchets to two of the bolts, insert a pry bar to hold the pulley in place and loosen the bolts-2.2L engine
Once all the bolts are unfastened, remove the water pump pulley-2.2L engine
Disconnect all hoses attached to the water pump assembly-4.3L engine
Unfasten and remove the water pump retaining bolts-4.3L engine
The water pump is retained by four bolts-2.2L engine
Remove the water pump from the vehicle-4.3L engine
Removing the water pump from the engine block-2.2L engine
Use a scraper to clean the old gasket material from the water pump ...
... and the water pump-to-engine mating surface
