Question about HTC Advantage X7500 Smartphone
HTC Advantage keeps switching off during a call!!!
I have a HTC advantage phone that weirdly just cancels the call if i don't press a button it like goes to sleep I have worked out its needs to know that I am on a call every 55secs I have to hit a button otherwise it cuts off for a phone that cost me £850.00 this really really sucks !
If I cannot sort this out its going up for sale - I cannot believe it Blackberry rules just now seriously ... Listen other High tech HTC X7500 owners dont' suffer in silience speak out these phones are odd!!!!
  • ilil Jan 18, 2009
    exactly the same problem mate!
    Scholar:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 52 Answers
My phone's screen turns off while I'm on the phone if I don't put in any input. That doesn't turn off the call... however, I've noticed bugs on my phone as well. Perhaps you could tell me which OS you're running on it, and which programs you've installed since you had the phone. If it's done this since day 1, it may be one problem, if it's done it only recently, it may be another.
I would recommend going into your settings, turning off all auto sleeps as well as disabling the auto shut off blacklight after a certain time. Set all settings to make sure the phone only sleeps when you tell it to (aka pressing the sleep button).
If that doesn't work, try deleting some appllications you installed (in your settings, remove programs.) Start with ones which are only related to your phone's phone.... get it? ;)
If that doesn't work, there are other solutions but they involve more work (ie hard reset). READ CAREFULLY HERE Just as a note, to do a hard reset (erase everything and start again) press and hold the volume down button and then press the reset button on the back while still holding the volume down.
WARNING  this will delete all personal information, programs that you installed yourself, and contact information.  ALSO Anything on the Microdrive (8GB) will not be erased, ONLY the things on the device itself.
Good luck, I hope that helps you. If not, well, post some more details and I'll try to help.
Caid.
Posted on Dec 21, 2008
When im playing my music i lock my phone and the music stops, can i make it keep playing?
Just check the options on your media player. or try installing different players which suite to your requirement.
Mar 07, 2011 | HTC Advantage X7500 Smartphone
Where i must buy and haw much ?
Hello , purchase from here ,
http://shop.ebay.com/i.html?_nkw=HTC+Advantage+X7510+Smartphone&_armrs=1&_from=&_ipg=#
Jan 11, 2011 | HTC Advantage X7510 Smartphone
HOW DO YOU SET UP THE ET220 TIMER IT WILL NOT WORK
Solution posted at:
http://www.fixya.com/support/t1329823-first_alert_timer_et220
1. Set time: Rotate dial (PM indicated by PM light) Stop at current time. Press Time set button.
2. Rotate dial to desired ON time; press & hold On/off button, rotate dial to OFF time, release On/off button
3. To Cancel the time. Press & Hold on/off and rotate one cycle to erase.
And will have to reset time (1)
You can also take advantage of fixya phone support.
Fixya expert will walk you through the steps for a price.
Dec 23, 2010 | First Alert 24 Hour Timers - 2 For The...
How to unlock HTC advantage 7500, forgotten the password
You may try default phone and security code to remove it
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
Sep 19, 2010 | HTC Advantage X7500 Smartphone
How do you use an advantage controller
The Nes Advantage is one of those weird controllers. It is set up to function as a dual controller.. Kind of.
You have two plugs for player 1 and player 2 on the controller (If you are wanting to just use it for a 1 player game only one has to be plugged in - Not sure on the layout because both plugs are not labeled).
There is a player select button on the controller that can be set to first or second player. Set it to 1 and enjoy the stick.
If it is not responding you will have to switch the plug to the other.
Feb 14, 2010 | Nintendo Video Game Consoles & Games
Unlocking protected password dopod U1000 (HTC advantage X7500)
Pak Agus, You was try to ask puk pin to your provider ? Please, you try to call your provider to ask puk pin.
Regard, Ngajio
Feb 21, 2009 | HTC Advantage X7500 Smartphone
I have a htc x 7500 advantage i ve installed a new windows on it after doing that my phone doesn t recive any GSM signal what can i do to fix it? where can i get the software for the phone application?...
You can connect to the Internet through Wi-Fi, GPRS, Dial-up, or Work connections(such as VPN and proxy connections). If you are encountering problems :
.Open the Comm Manager and make sure Flight Mode (or Airplane Mode) is turned off.
.Make sure the connection method settings are correct before accessing the Internet.
.Make sure the connections have been activated (e.g. Bluetooth, Wi-Fi etc.).
Jan 26, 2009 | HTC Advantage X7500 Smartphone
How do I reset my Advantage X7500 password?
To do a hard reset (everything erased off the device) just press and hold the volume down (on the upper left) while pressing the small reset button on the back of the device. This will bring it back to factory details, but you will lose everything that isn't on the hard drive.
Caid.
Dec 02, 2008 | HTC Advantage X7500 Smartphone
Reloading tom tom on to htc advantage x7500
I recommend going to xda-forums and looking around there. I know you can find it there, I just don't know exactly where it is. There is a special forum just for the x7500 there, it's listed as the Athena.
Google xda-developers to begin your search, and good hope to you on that.
Caid.
Nov 13, 2008 | HTC Advantage X7500 Smartphone
Lock code
HTC X7500/7501-(ATHENA/ADVANTAGE/Dopod U1000/T.Mobile AMEO)
Slide the Volume slider down and at the same time, use the stylus to press the RESET button at the back of your
device. After a brief period of time, two choices will appear on-screen. Press the CENTER OK button to perform the
hard reset. (Otherwise, if any, press the CAMERA button to exit.)
or try with this link...
http://www.efsoft.it/resetdev.htm
Jun 09, 2008 | HTC Advantage X7500 Smartphone
HTC Advantage X7500 Smartphone Logo
137 people viewed this question
Top HTC Computers & Internet Experts
SANJEEV KUMAR SURI
SANJEEV KUMAR SURI
Tom Chichester
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
