Question about JVC Televison & Video
I have an intermittant problem on the hdmi channel of my LT-37DS6FJ. It occasionally loses the signal and the screen turns blue. The only way to overcome the problem is to swtich off the TV and restart it. ANy suggestions as to what it could be and how to cure it?
  • dave297 Sep 29, 2008
    Thanks Dan - At least I know where to start now!
    rgds
    Dave297
  • 4,234 Answers
This is a problem that is not likely to be resolved remotely. That being said, here are a few possibilities:
1) The video switching chip inside the set is defective and sensitive to heat.
2) The voltage regulator that controls the power to the chip is defective. (in essence turning off the chip)
3) The microprocessor that controls the whole set is getting confused (for whatever reason) and switching to another input stream without any indication to the user.
4) The dialogue over the HDMI tells the set that there is no video being sent/
The best thing to do here is to look for a pattern of when this occurs. FOr example, does this occur only after the set has been on for a while or is it immediate? Are other inputs effected in the same way or just the HDMI?
Keep us posted.
Dan
Posted on Sep 24, 2008
How do I get Amazon Fire TV resolution set so I get more than a blue screen?
Select the input channel for your Fire TV - Turn on your TV and select the input channel for the HDMI port you used to connect your Fire TV. You should then see a loading screen with the Amazon Fire TV logo 4.
Jul 04, 2017 | TV Box Televison & Video
My vizio is blinking back and forth from the blue no signal screen to the actual hdmi input screen which is connected to a cable box. What is going on?
Have you tried a different HDMI input? (If available.) You may be able to test the cable box of PS4 using component cables to confirm that all but the HDMI is not working. You may try pushing or holding the HDMI cables to see if you can make the problem better or worse to identify a possible flakey HDMI socket.
Jan 03, 2015 | Vizio 26 Class Edge Lit Razor LED LCD HDTV...
I have the same issue with my new LG 47lv5500. I too have time warner settings of 1080i but the sound on hd channels comes and goes. Picture is fine. When I switch back to non hd channels the sound is also...
That tv HDMI hub output for the HD tv signal are could be a bad HDMI cable should tries it with another new HDMI cable.If still have the same problems tries it with another HDMI tv hub hook up.That tv HDMI tv hub the one u using now might have a intermittent shorting like lose or dries solders joints that why sound come an goes.
Aug 25, 2011 | LG 47 47LV5500 47 LCD TV
I use the Denon avr 881 receiver I just realized that it loses sound for jus a second or two then returns like nothing happend also when the sound leaves the signal: lock light blinks thanks please help.
lock light blink looks like input signal gone intermittently, I guess it maybe HDMI version compailable problem, suggest to manage to find new firmware to improve it.
Mar 28, 2011 | Denon AVR-881 5.1 Channels Receiver
I need to know what cables to get to make it true HD. Also I wanted to know why I can't receive local channels.
go to menu then tuning,set from cable to air,for local channel.you can't get true HD for cable because cable is an analog signal
Sep 07, 2010 | Televison & Video
2My Mitsubishi WD52725 displays a blue screen suggesting to check my inputs and says signal is invalid..checked all the connections and all is good there..any suggestions? Thanks in advance, Nick
What is your input source and which input cable type? If the source is a PC using a VGA cable, what resolution is the computer sending? 480x640. 800x600, 1024x768, 720x1280 (EIA standard) all at 60Hz are known to work but other modes might not.
If you are using a PC to the HDMI port, it will not work. The only HDMI ports that can connect to a computer will be listed as HDMI/DVI and this TV doesn't have that type of HDMI port.
If you are using any other input source, check try another source or channel. (One of my TVs intermittently finds a digital channel 25-9 and gives that message. We have no clue what station is being found but all the other channels are fine.)
I hope this helps.
Aug 04, 2010 | Mitsubishi WD-52725 52". Rear Projection...
VIZIO LCD VX20L, intermittant video/audio with Blue screen message "No Signal"
If the tuner is bad, changing the mainboard should fix the problem.
May 18, 2009 | Vizio VX20L 20 in. LCD TV
Sony bravia intermittent sound
Yep, same problem with mine. After many trial fixes, I discovered that it's the HDMI connection. I tried two different new HDMI cables in two of HDMI ports on the TV, but still got intermittent sound. The only way I solved it was going to component cables (RGB) with a separate audio cable. Works great now. Other Web sites say that HDMI connections do not always electronically "handshake" well between devices. Not sure how this HDMI problem can be permanently fixed, but using the component connection works fine.
Feb 20, 2008 | Sony BRAVIA KDL52XBR2 Television
LG LCD HDTV 'NO SIGNAL'
To fix the problem, try turning off the TV and unplugging it from the outlet. Once unplugged, push the power button and hold it down for 1 minute. Then turn the TV back on and rescan for channels.
If the problem persists, contact LG customer service immediately as there is a problem with the memory card. The device is unable to retain scanned channels for immediate feedback.
All LG LCD automatically comes with a 1 year manufacturing warranty. You would have to provide proof of purchase to show when it was purchased. Hope this helps. The Guru
LG customer service: http://www.lg.com/us/support/index.jsp
Dec 07, 2007 | LG 42LC2D 42 in. LCD HDTV
Televison & Video Logo
101 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
