Washing Machines Logo
Anonymous Posted on Oct 27, 2011
Washer will not spin at all no code . will drain and tumble back and forth,when it comes time to spin it turns off.
brian soufane
Level 3:
President:
  • Master 693 Answers
  • Posted on Oct 27, 2011
brian soufane
Master
Level 3:
President:
Answers
693
Questions
Helped
511592
Points
4903
A washing machine is basically a big tub that repeatedly fills with water and then drains, spins to wring clothes dry, and has a device for stirring things up-- either an agitator in the middle of a top-load machine or a rolling drum in the case of a front-loader.
The four cycles that every washer performs are fill, wash, drain, and spin. Though these functions are pretty basic, a number of things can go wrong with them.
There are a number of problems that you can fix quite simply; some issues, however, are better left in the hands of an appliance repairperson.Problems that commonly occur with a clothes washer are discussed in depth below.If your washer doesn't run, be sure it's plugged in and that the receptacle works (the circuit hasn't overloaded). Before working on the washing machine, be sure to unplug it.
To prevent problems, follow good maintenance procedures. Use the right amount of detergent for your washer and your water hardness, make sure the machine is level, and don't overload it for the cycle chosen.
Washing Machine Does Not Fill
If the washer doesn't fill, the water inlet screens may be blocked. Clean or replace them. (Check your owner's manual for the location of the screens; they're often located at one end of the supply hoses, or you may have to remove a panel to access them.) Other reasons for not filling may be that either the timer or temperature selector is broken--both of these are repairs for an appliance repairperson.
Washer Does Not Spin
If your washer doesn't spin, check to see if the clothes have jammed or are unbalanced in the drum before calling a repairperson. Unbalanced clothes will also cause a w
asher to shudder or "walk." If straightening out the load doesn't stop the washer from shaking, look at the feet underneath and be sure they are properly adjusted to keep the washer sitting level on the floor (you just turn them to move them up or down).
Clothes Are Wet After Spin Cycle
If your clothes remain wet after your washer's spin cycle, perform the following diagnostics:
1) Lift the lid during the spin cycle. If the tub is not spinning, you may have a damaged motor coupler. Call a repairperson to replace this part.
2) If the tub is spinning, recheck the load to make sure it is balanced. If you are certain the load is balanced but your clothes are still wet, you may need to call a repairperson to replace a damaged motor pulley, tub bearing, belt, or clutch.
3) You can also follow the troubleshooting steps outlined in "Washing Machine Doesn't Drain." You may have a problem with your drain hose or pump.
My Haier portable washing machine wont do spin cycle
If resetting the washer doesn’t work, the limit switch may be stuck. The sensor for a unbalanced load is a limit switch. The switch should snap back into standby position when the wash tub comes to a stop. Sometimes the switch will stay stuck. Move the barrel by hand back and forth until it hits the inner walls of washer. It may knock the switch back in place.
Whirlpool WFW9050XW Washer Front Load
Disconnect your mains from the wall and clean out your filter.
Pl click if helped.
Model fwt645rhso will agitate but won't drain out, on spin cycle washer spins one way, stops goes back the other way, but water will not drain out. Does not rapidly spin on final cycle. Any...
There's an auxiliary switch in the door lock.switch assembly that is activated at the end of the wash cycle for the machine to advance to the spin cycle. The machine will NEVER advance to the spin cycle unless the auxiliary switch is activated as a safety feature to prevent the door from opening during a high-speed spin cycle that may result in physical injury. The drum tumbles back and forth while the machine control checks the auxiliary if activated but since it's not, the control will not command the motor speed control to spin the drum at high speed. These symptoms may indicate a faulty door lock/switch assembly and may need replacement. Click on the links below for the detailed troubleshooting instructions and replacement of the door lock/switch assembly.
Electrolux and Frigidaire Washers Door Lock/Switch Assembly Troubleshooting
Replacing the Door Lock/Switch Assembly on Electrolux and Frigidaire Washers
Kenmore Front Loading Washer - the spider arm broke and we had to change the entire tub assy which was done and the machine now works perfectly as for the washing and tumbling. The tub spins, tumbles back...
It is the brain of the washer that decides when the spin takes place and how fast - the brain knows how fast the motor is spinning because there is a speed sensor, probably on the rear end of the motor shaft.
There might be bad connections to the speed sensor or it might be broken but if that and the wiring is ok the fault is probably with the controller/brain, though it is possible the brain refuses to do a high speed spin because for some reason it might (mistakenly?) think there is still too much water in the tub.
1helpful
Drain pump keeps running
Probable motor control board problem.
don't buy a GE anything!
4helpful
2answers
GE washer (WHDRR418GWW)(14 MO. OLD)HAS STOPPED AGITATING.WHERE TO LOOK? WHAT TO TRY?
My washer would fill/drain ok but would not agitate or spin. I unplugged the washer and listened for the motor to click. When the motor clicked I plugged the washer back in. Then I opened and closed the lid 10 times. I turned the washer to the drain/spin position and turned it on. The belt moved back and forth several times and then went into a fast spin.
2answers
Kenmore 44092500 Won't complete spin cycle
AllExperts.com gave me the answer I needed at no cost.
Kenmore 44042 - No spin cycle
The front load washers are supported by springs on the top and shocks on the bottom.  More than likely you broke a spring on the top or cracked one of the shock mounts which causes and unbalanced load all the time.  Will it go through a spin cycle with no clothes is it?
Top Washing Machines Experts
john h
