Question about Car Audio & Video
I have a 'Eurovox' car radio/cassette with 'Land Rover' on the front, but the two plugs do not match up with my Range Rover. So I would like to know how to, (after removing the plugs), wire it in. These numbers on the security code card - Model: 6330R. s/n: 2680093948. These numbers on the radio itself - Model: 6330 DE. s/n: 268009394 B. I do hope you can help. Thankyou, Martin. Email: lipton444@hotmail.com Phone: (03) 5828 5284.
  • lipton444 Oct 03, 2008
    Thankyou for this information. I'm not sure that I follow it all, but I shall give it a go. There are no plugs in the Range Rover so I have to hard wire it in. Thanks for your help.
    Scholar:
  • 121 Answers
You can remove the plugs and wire nut the wires together the plugs are just for convenience. You will need to read the wiring diagrams of both to know which wire goes where.
Posted on Oct 03, 2008
  • 171 Answers
What year,\ and model is the Lamd Rover?
What year and model is the Range Rover?
I have the wiring diagrams available at this sitem you will need the above information.
go to http://www.wirediagram.com/landrover.htm
Posted on Sep 24, 2008
  • 1 more comment
  • Todd Gale
    Todd Gale Sep 24, 2008
    Land Rover Wiring Harness
  • Todd Gale
    just wired my 6330 into my sons first car so can help out.
    _____________________________
    > white/black stripe, | white
    > green/black stripe, | green
    > purple, | red
    > grey(on its own) -- (LOCK LUG SIDE)
    > black, | orange
    > yellow/black stripe, | yellow
    > blue/backstripe, | blue
    >______________________________
    Using above format:
    FRONT right | FRONT right
    FRONT left | FRONT left
    12V + | 12V + connected to ignition switch
    auto antenna (I didn't use this)
    EARTH | (don't know name but used on some car
    phones to turn volum down when phone rings-not needed)
    BACK right | BACK right
    BACK left | BACK left
    As a matter of convention the speaker wires that have the thin black
    stripe are used to make sure all the speakers are connected to the
    same polarity, and this way they are all in sync. On some speakers
    (low end of market) it also shows the "earth" wire for the speaker.
    The purple 12 volt wire is connected to a voltage source that is
    always on, as this is what maintains the radios memory (radio station
    settings and clock) and makes the LED on the front flash as a security
    warning.
    If you want the radio to work without having to have the ignition
    switch on, then simply run the two wires together to your fused active
    12 volt supply.
    To make sure the radio is OK I connect the purple and black wire to
    the 12 volt and earth respectively and make sure the LED comes on.
    When the red wire is cionnected then the screen lights up etc and you
    can put the security code etc in.
    Don't run the radio without any speakers connected as you may wreck
    the output circuit and this is expensive.
    The antenna plugs into the socket at the rear right hand side.
  • Todd Gale
    Todd Gale Oct 03, 2008
    Please rate this solution.
  • 691 Answers
If you leave the original plugs connected to the radio unit you will be able to get an adapter from a motor store. In the UK Halfords keep most types, in the US I don't know what similar stores you have but i would imagine Radio Shack or similar will keep the type you need. Take the radio unit with you so they can see the connectors on the unit - they will probablky be ISO fittings and then they will be able to advise the Range Rover fitting.
If they do not have a suitable adaptor, ask them to identifiy the connectors on the radio unit (DIN, ISO etc) and then ask your local Landrover/Range Rover dealer if they can supply an adaptor for you.
Hope this clears your problem, please mark the post as Fixya.
Wiring diagram for the radio on 2004 range rover HSE with harmon garden sound
I believe the radio in the Range Rover is wired DIN standard which is used with some minor variations on the majority of European cars across Europe.
I think there are three multiway plugs plus antenna. One plug provides four pairs of speaker wires, one plug carries all the power requirements and the third plug provides a bunch of wires for the steering mounted remote control.
Sorry but I don't have a diagram to hand but you shouldn't have much bother finding one.
Feb 04, 2015 | 2004 Land Rover Range Rover
How to get code and unlock lanrover 1997 casseetee.
tahe out the radio call the dealer and tell him the numbers in the back of the radio will give it to you they night ask the vin number
Dec 01, 2012 | 1997 Land Rover Discovery
My 2005 Range Rover radio stopped working and the on/ off button blinks and now the screen just comes on and the logo Range Rover stays on
Sounds like your anti-theft is locked, if you do not know the code you can check with the dealer all he needs is the vin
Aug 08, 2010 | 2005 Land Rover Range Rover
Need a code for radio (eurovox) in 99 freelander thanks
G'day mate, from experience the only people with the codes are land rover if this is the case the dealer will have access to the database for the code given teh correct details , also try in the handbook if it was written in there in the back or near the instructions for putting it in , hope this helps
Apr 07, 2010 | 2002 Land Rover Freelander
Changed heads due h/gasket ,tried to start engine however started but bad misfiring shaking etc checked leads now what ?
Hello; Sounds like firing order is incorrect. Recheck plug wires for proper cylinder match. The firing order is usually casted on the intake manifold.. Let me know, ok?
Six cylinders :153624
v-8 18436572,- 1546278 etc.
4 cyl -1342
GOOD LUCK
May 06, 2009 | 1996 Land Rover Range Rover
Radio screen doesn't show but plays
There is a problem inside the radio and a specialist needs to strip and repair if possible.Check with your dealer if they know someone to do this.
Dec 02, 2008 | 2004 Land Rover Range Rover
1995 Range Rover Land Rover Questions
the back windshield is the front windshield one just pull it front or back not up all down
hope is helps
Jamie
Oct 05, 2008 | 2004 Land Rover Range Rover
Car Audio & Video Logo
458 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
