Question about Breville CBL10 BlendMaster Classic Work Top Blender
Rubber gears where blender jug connects to base are burnt out. Has anyone changed them? Know where I can get new 'gears' in Australia? Many Thanks, Dunstan
  • Anonymous Oct 26, 2008
    We have exactly the same problem and our blender has been out of action for several months. My wife has just asked me to locate the necessary spare parts and get it working again. However, I'm not sure where to get the parts in the UK. Any suggestions would be gratefully received.
SOURCE: top part of base broke off
This just happened to me too, and I think I just fixed it.  First you have to get a replacement part called the "blender coupling" (I got mine online from Goodmans for $3.99).  I also replaced the square drive and slinger (two parts come together for $2.99)-that's the little part that sticks up and attaches to the pitcher.
Unscrew the bottom four screws of the base where the rubber feet are.  Remove the rubber skirt to reveal four screws that hold the motor in.  They are way in there so you'll need a long screw driver.  Remove the motor and unscrew the old coupling.  Mine had not been replaced since my grandmother bought this blender who knows when, so the coupling was really stuck.  I did not have a tool narrow enough to get a good grip to apply enough torque to remove the coupling so I had to try a few other tricks.  If your blender is the same, remove the bottom nut, fan blade and two washers.  This gave enough of a rod to grip to get the old coupling off.  (I also had to use some WD40, and heat and cool the coupling a few times to break the old seal).
Good luck!  Hope that helps!
Posted on Jan 20, 2008
  • 109 Answers
SOURCE: Replacement glass jug?
I will buy the blade set from you? I will return....
Posted on Feb 22, 2008
SOURCE: Blender base gear knobs broke off
http://www.fixya.com/support/t509590-kitchenaid_ks85_coupling_drive
Reports the same problem and a couple of solutions.
Posted on Sep 26, 2008
bunnydawg
  • 5158 Answers
SOURCE: Lost Seal for Blender
I would suggest you contact the company at
http://www.breville.com.au/ (click on "what's on your mind") and let them know the problem... they should be able to direct you to a UK parts source or help you in some other way.
Posted on Mar 23, 2009
cactus bob
  • 267 Answers
SOURCE: blender blade not turning, rotating piece on base not connected
this is getting more and more common there is a part between the motor and the drive gear that snaps for no reason . its job is to snap if the blades jam as a "fuse" to save your house from a overheating ,jammed motor . the problem is there are no parts to buy to fix this . if its new take it back to where you bought it . otherwise shipping it 2 ways for repair to the factory is sometimes as much or more as a new blender ........ i would recomend you do one of two things : go to a goodwill or other type shop and get a nice vintage blender , it will last forever ! or move up to a vita mix . its costly but it will realy last you ... this new made in china junk is just bad news even when it has the kitchen aid name on it . its still the same junk ..... good luck........ Please if this answer helped , please rate this 3 or 4 stars . and keep me in the paid answer department . A 1 or 2 may knock me down into the unpaid ranks. Thanks Cactus Bob .
Posted on Mar 24, 2009
The jug part is stuck on motor , how can I separate the two parts ?
Brute Force, but make sure you are turning the top anticlockwise. Have two people with dishwashing rubber gloves for grip. One holds the base one the worktop and the other turns.
Apr 14, 2016 | VillaWare Blvllaz05h 2 Litre Jug Blender...
I have been given a Kenwood BL300 blender. After using it to make breadcrumbs, I undid it somehow and now I can't get it back together. Can't remember if the blade goes straight into the base or the jug,...
You need to unfasten the white base from the clear jug, then the rotating blade will sit inside the white base, with the blade facing upwards. The white rubber flange goes in next. Then screw the assembled base back into the clear jug. The jug should then fit on to the stand.
Dec 08, 2010 | Kenwood BL300 SingleSpeed Blender
Broken glass goblet
This place has spare parts in the U.S.
http://www.abtecparts.com/index.htm
They deliver worldwide. I am in Australia and just ordered the rubber ring and on the list there was the glass jug.
Nov 02, 2009 | Krups Blenders
Broken glass jug on kitchenaid blender model 5ksb2aer4
Look at the underside of the blade shaft. The metal wing nut on the end of the shaft secures the blade assembly to cream coloured plastic blade base. The wing nut also transmits the drive from the rubber coupling on your blender to the blade shaft. The wing nut has a LEFT HAND thread.
The left hand thread ensures the blade assembly does not unscrew during normal blender use.
Firstly disassemble the blender blade assembly. Place a folded tea towel over the blades and hold the blades firmly. If you do not use a tea towel you may cut yourself.
Grip the wing nut with your other hand and unscrew it CLOCKWISE.
Remove the wing nut. You can now remove the blade from the plastic base.
Put the blade assembly in the new jug and offer up the plastic base from under the jug so that the blade shaft protudes enough for you to install the wing nut.
Screw the wing nut ANTI-CLOCKWISE to secure the blades to the plastic base.
Do not over tighten the wing nut; you may have to replace your jug again at some point.
Jun 06, 2009 | KitchenAid KHB300 Handheld Blender
Seal/Gasket missing on Braun Blender
Hi. There's only one common blender made by Braun, which has a triangular jug in either glass or plastic, but the locking ring and gasket are the same. It'd be a 4184, either a MX2000 or MX2050.
Auckland has a Service Centre:
0.gif Key Service Ltd
7D Echelon Place, East Tamaki, Manukau City Auckland
P.O. Box: 38569 Howick
Manukau City
Phone Country Code: +64
Phone: 09-916 0960
Fax: 09-916 0970
Service for: All products
Otherwise, you can locate Service Centres in Australia.
Apr 13, 2009 | Braun MX 2050 PowerMax Work Top Blender
I have a krups 574 blender. The male part of the
I carved off the rubber with a knife; inserted a flathead screwdriver throught the slot in the bottom to hold the gear in place; using pliers I unscrewed (COUNTERCLOCKWISE) the rubber gear.
Mar 28, 2009 | Krups 574 Power Xtreme VI Premium Work Top...
My blender's jar is broken, i want a new one
You might need to order one from the UK and pay delivery charges? I am based in the UK and it is tricky finding this part, but I think possible. I smashed my blender measuring jug this morning and I hope I can get a new one at viewpointdirect@aol.com - just placed an order. You don't mention a model of yours but the one I found is compatible with several makes - check out this link http://www.viewpointdirect.co.uk/philips-measuring-jug---for-use-with-hand-blenders-573-p.asp. They deliver worldwide for a reasonably high charge. Else there are some other jugs you can find, without pictures though, which might be compatible with your make, at http://www.buyspares.co.uk. Good luck!
Dec 16, 2008 | Philips HR1358 Handheld Blender
Krups Type Blender 577
Mine did the same thing. I am ordering a new one from America for around $5.
I am in Australia and they deliver worldwide.
Caz
Jun 12, 2008 | Krups 572 Power Xtreme VI Work Top Blender
Breville CBL10 BlendMaster Classic Work Top Blender Logo
Top Breville Blenders Experts
Mike
Joseph Hoffmann
Are you a Breville Blender Expert? Answer questions, earn points and help others
