Question about Zebra TLP 2844-Z Thermal Label Printer
Zebra printers & MS Word
When using ms word to create labels and sending them to a zebra printer, it is taking an extremely long time to print. We've tried using zebra fonts in word or the normal ms word fonts and its the same.
Has anyone have any advice?
    Problem Solver:
  • 6 Answers
HI Les1810,
You should be printing faster with Zebra fonts.
Which driver are you using? Version?
I strongly recommend the Zebra Designer V1.3.08, available at
To isolate the problem, capture the output to a file.
Define a local port as C:\output.txt and set that as the port in driver properties.
Now print your document. The printer commands will be in C:\output.txt.
Send c:\output.txt directly to your printer.
For LPT1, use the DOS copy command to send the file. (Copy C:\output.txt LPT1)
For serial connections, use Hyperterm to send the file.
For network connections, use ftp.
No easy USB method is readily available.
Does this print faster than printing the original document from Word through the driver?
If yes, then update your driver.
If no, debug your communication to the printer (LPT1, serial, network, etc.)
Posted on Sep 25, 2008
2 partial labels being printed on 1 label
most likely to do with sensor --- label has a notch in it it in middle make sure it is clean --- do labels have a hole that align with sensor?
Look at Cleaning printer to locate sensor
Mar 18, 2013 | Zebra QL420 Plus Portable Thermal Barcode...
Zebra LP 2824 Plus Giving Endless Labels
OK where is the print spooler on the remote client or the server. Have you check whether this is clearing and not an issue with your remote setup and not the printer does the printer work correctly attached directly to the server break the problem down in stages
Dec 07, 2012 | Zebra LP 2824 Plus Thermal Label Printer
On the Zebra it was printing 4x13 labels without a problem. However when I tried to print a 4x6 label it still thought there was 4x13 stock in the printer. I played around with the label format size, even...
I think this is more related to the calibration of the label each time you change the new label size. I use ZM400 and your printer should also have the same setting. Under setting, put the When Head Close setting to Calibration. This will let the calibration perform automatically when ever you load a new label size and close the print head. Well 2 label will be lost every time.
Aug 31, 2011 | Zebra 105SL Thermal Label Printer
Hi I am printing barcode labels on a Zebra Tlp2844-Z. I can print resident barcodes in passthrough mode using the old Zebra driver ( but the barcode does not print using the ZDesigner driver...
Have you tried creating the barcode / label using the ZDesigner software? It is available free on their website and I'm sure you'll find it easy to use. Hope this helps!
Aug 23, 2011 | Zebra TLP 2844-Z Thermal Label Printer
Using MS Access, I am printing labels to a Zebra 110XiIII printer. The output truncates the label to 2" instead of the 3.5" I have the report page settings saved as. I have been through the setup...
First check printer. Change setting "Print Width" to maximum width, save. Switch off. Hold down pause key while switching on (untill all but power light turns off). the subsequent prints should print across the full width. If this is OK fault is with label format.
If you are using windows printer driver check settings there this can over ride printer settings. If using ZPL the problem is most likely in the label format.
Jul 05, 2011 | Zebra 110XIIII Thermal Label Printer
Print labels created in ms access
first check your driver for zebra 2844 it is compatible with the OS, if it's Ok may be you can find third party software that help us create label
May 13, 2010 | Zebra TLP 2844 Label Printer
Trying to use ms word with my zebra tlp 2844, can't figure it out. How do I setup the label size and which one do I choose?
Go to Page setup in MS Word and adjust the page size manually, measure the label and use these dimensions..
Dec 08, 2009 | Zebra TLP 2844-Z Thermal Label Printer
I have a zebra lb2844 label printer. Does anyone know if it can be used as a receipt printer instead? I am looking for a generic driver that may work as the supplied one wants a label size. (I want to...
Normally this printer s meant to print labels.
To have them work as line printers there is only one thing to do. Start the printer while pressing on the button. When it starts feedingthe paper release the button. After printing the configuration it will act as a line printer. But the best way to use it as a receipt printer is to create a program which will send the information to the printer through a windows driver if your software can do that
Aug 09, 2009 | Zebra TLP 2844-Z Thermal Label Printer
Zebra printer 140xilll - Too many print jobs?
It does sound like you have a memory overload when you send the 2nd print job. Each label is getting sent to the printer and filling up the memory. Make sure you are using the printer resident fonts and not a regular windows font. The windows fonts get sent down as graphics and take up memory. What zebra is saying to do is store the format of the label in the printer memory and then just send down the information that changes. For example if you were printing a UPS label the basic format of the label is the same but things such as the addresses and tracking # would change.
Jun 23, 2009 | Zebra 140XiIII Plus Thermal Label Printer
Zebra TLP 2844-Z Thermal Label Printer Logo
2,381 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
