I am having problems with primary drive not found as well as unable to open my display properties. I have a dell dimensions 2400 desktop computer system.
    Master:
    Sergeant:
  • 449 Answers
Hi!!!!
try to re-install
the display driver
Posted on Sep 24, 2008
Reinstalled Windows XP on an old computer (DELL Dimension 2400) and the monitor won't display above basic resolution. Downloaded and reinstalled the monitor driver and still no good. Opened up START
According to the Dell Support web site the Dell Dimension 2400 has a built in Intel 3D extreme graphics adapter, assuming you are using this and not a PCI graphics card.
Go to the Intel Download Centre and run their Intel Driver Update Utility which will automatically scan your system for updated drivers for any installed or integrated Intel devices.
If the Intel Utility identifies an updated driver for your graphics adapter then download and install that which should enable you to configure a higher resolution for your display.
Dec 24, 2011 | Computers & Internet
On dell dimension 2400 desktop Primary Drive 0 not found. When I hit F12 it does nothing. I can't get to the Diagnostics page.
More than likely your hard drive has crashed. You'll need to replace it and reinstall the operating system.
If you'd like to try and mount the drive to recover files, I'd recommend downloading and burning ubuntu onto a cdr and launching the live version (advice for advance user)
If you'd like a Pro opinion I'd recommend finding a local repair shop that does FREE diagnostics.
Hope this info helps!
Oct 10, 2010 | Dell Dimension 2400 PC Desktop
My primary drive 1 an 2 not found how do i fix this
well primary drive is the hard drive from which the OS boots so if it is not detected PC cannot boot so check exactly which drive is not found and you can also check the power cable to the drive which is not found and make sure it gets the power .
good luck.
Jan 06, 2010 | Dell Dimension 2400 PC Desktop
Resolution 1024x768 stuck in 8bit color i need
If you are runnineg windowsXP goto control panel by catagory select appearence and things then display, setting, then under color select 32bit, if you are unable to select anythingother than 8 I recommend you go to DELLs website and download display driver for your system.
Nov 23, 2009 | Dell Dimension 2400 PC Desktop
Dell Dimensions 2400 Primary Drive 0 Not Found
For this problem it only means that the Hard Disk of the computer is not being detected
Try doing the ff:
  • reseat the IDE or SATA cable of the Hard Disk
  • Clean the port where the cable is connected (make sure that the computer is unplug)
  • reboot the computer
  • if problem persist contact computer manufacturer
Hope this will help
Thanks
BYron
Sep 24, 2009 | Dell Dimension 2400 PC Desktop
Before I start my dell dimension 2400 computer up, I have to disconnect my usb mouse and usb keyboard because if I don't I will get these 2 errors, Primary drive 1 not found and Secondary drive 1 not...
The resolution for this is to go into the BIOS with the help of F2. Then look for the option USB Legacy devices. If it is enabled disable it or vice-a-versa. Also look for Boot from USB devices. Please disable that option. And select the first boot device to be the HDD (Internal hard drive)
Jul 11, 2009 | Dell Dimension 2400 PC Desktop
How do I get my TV to display my Dell Dimension 2400? I have the cables for the connection and I have connected other computers to to TV with no problems-- it seems this is more of a software/display...
Try this: right click on the desktop (wall paper picture) and select "Properties" (up to XP) or "Graphics Options" (Vista). You should be able to select you TV as a second display. The TV option may only show if it is connected.
Jun 08, 2009 | Dell Dimension 2400 PC Desktop
Dell dimension 2400 diskette drive 0 seek failure
Check your BIOS setting to see if it detects the hard drive (Primary disk 0). If it can't detect the hard drive then the hard drive maybe faulty. Open the case unpluge the IDE cable from the hard drive and reconnect it again, also unplug the IDE cable at the motherboard and reconnect it again including the power connector on the hard drive.
There maybe an option to test the hard drive in the BIOS, if so use it to test the hard drive.
If the hard drive is faulty, you need to replace it and install Windows, the various device drivers and your programs to get a functioning computer again.
You might consider buying a new computer (it will be faster & better than the old Dell) and you have your new monitor to go with it.
May 21, 2009 | Dell Dimension 2400 PC Desktop
Need help please
hello i am bhaigi your computers hard disk belt is may be damage change it and put the jumpher in frist hard disk master and second on slave
Mar 12, 2008 | Dell Dimension 2400 PC Desktop
Computers & Internet Logo
David Payne
David Payne
