Question about Jenn-Air JJW8530C Expressions Collection Dual Single Oven
Wiring 4 wire cook top to 3 wire outlet
Need help wiring 4 wire jenn air cooktop to a 3 wire outlet
  • tomdowd45 Nov 07, 2008
    I am replacing my old Jenn-Air Cooktop with a new jenn-Air Cooktop, Model# JED8430.  The wiring to the old cooktop is a 2 Pole 40Amp Braker with 2 black wires and 1 Alum. Grd., however the new cooktop requires a 4 wire hookup.  Can I tap into a White wire from another outlet?
    Scholar:
  • 121 Answers
What you have is a 220v and a 110v circuit within the cook top. It needs a 4 wire feed to supply 2 hots, 1ground, and 1 neutral. The 3 wire outlet only has 2hots and a ground no neutral, which will probably not allow your control circuit to operate. You nee to run a neutral wire to obtain a 110v circuit. DO NOT try to run neutral off the ground or you will energize your cook top cabinet and it will shock you. Your solution is to run a neutarl wire from the closest circuit that you can find.
If you need further asst.
Eboukater@gmail.com
Posted on Sep 24, 2008
Oven, clock, timers all work, but grill & cooktop do not function Jenn Air Model SVE87600
Check the back and make sure the wiring to the grill cooktop is not unplugged from the main oven.
Nov 04, 2013 | Ovens
Good morning; We have a new Jenn-Air black glass
Any proprietary glass top cleaner should be suitable. Avoid using a wire based scouring pad but the Scotch type 'plastic/foam' cleaning pads are ok.
Jan 04, 2010 | Jenn-Air Ovens
The motor in our Jenn-Air central downdraft has stopped working. It's an electric cooktop. We think it's time to replace the unit; want to keep the central downdraft format, but this time want to have...
Not a problem . take a look at Jenn-air 's dual fuel . gas top elect oven and also down draft unit . can be vented several way's .. mm hope this helps . feed back pls . 84020
Dec 21, 2009 | Ovens
I have a jenn-air wall oven it has a red wire a black wire a white wire and a copper wire but coming out of my wall is only a red/black and copper what dose the white wire go to please help thank you
IF you nhave a 3 wire feed fronm the house for your range, you connect the red and black for the power and then use the copper wire from the wall to connect to the white and copper wires from the range. All new construction must have a 4 wire feed to a range and dryer.
Oct 26, 2009 | Jenn-Air 30 in. Pro-Style Electric Single...
Burnt sugar caramelized on a Jenn-Aire glass cook top
We Use Debruce Polish on all our cooktops. Debruce also works on stainless steel and polished granite, marble, porcelain, formica and glass. DeBruce is non-toxic odor-less and eco-friendly. You can get DeBruce on line at debrucepolish.com.
This stuuf really works
Mar 14, 2009 | Jenn-Air JJW8230D Electric Double Oven
Wiring diagram
This model of cook top needs the 4 wire install because it has both 220v and 110v circuits. The forth wire is a neutral that operates the 110v circuit. You can move the ground of the 3 wire outlet to neutral, but ONLY! if the ground wire is insulated. What this will do is give you both your 220v and 110v circuits. The problem with that is your cook top will not be grounded. The best solution is to locate a neutral wire and tap into it, this will give you your 4 wire circuit. Your missing a neutral in a 3 wire outlet.
More Asst.
eboukater@gmail.com
Sep 24, 2008 | Jenn-Air JJW8530C Expressions Collection...
Jenn-Air Gas Range SEG196 NO CLOCK/DISPLAY
THE ONLY SOLUTION FOR THE BAD DISPLAY IS TO REPLACE THE CLOCK. I HAVE A JENN AIR OVEN TODAY AS A WORK ORDER TO REPLACE THE CLOCK FOR A FAILED DISPLAY.
FOR THE JGW8130DDB WITH NO POWER ANYWHERE, IT SOUNDS LIKE YOU HAVE A SUPPLY PROBLEM. MAKE SURE THE WIRING IS HOOKED UP WITH THE RED AND WHITE WIRES RECEIVING 240 VOLTS AND THE WHITE WIRE ATTACHED TO NEUTRAL / GROUND.IF THE OVEN HAS A BARE COPPER WIRE AND THE HOUSEHOLD WIRING ONLY HAS THREE WIRES, COMBINE THE WHITE WIRE AND THE COPPER WIRE TOGETHER AND ATTACH TO THE HOUSEHOLD NEUTRAL / GROUND .
UNLESS YOU ARE SURE ABOUT THE HOOKUP IN THE BREAKER/FUSE BOX, DO NOT GO SIMPLY BY THE COLOR OF THE WIRES.
Apr 10, 2008 | Jenn-Air JGW8130A Electric Single Oven
Jenn-Air 88370 drop-in stove, want to convert!
your old jennair is 220 should be three or 4 wires in it red for 1 side of the 220 black for the other side of the 220 white for the bottom of the outlet and if green is there you can hook it with the white wire or just not use it let me know if your colors are different
Feb 14, 2008 | Ovens
Jenn-Air part RI302 4 pt gas re-igniter with flame rectification tytronics #Z21-20 and 7431 PO38-60
We had the same problem on a Thermador cooktop with the same RI-302 ignitor. Turns out it was one of the switches that sits on top of the gas valves. These switches cause the ignotor to fire when the valve is turned. In our case, one of the switches had malfunctioned and was "always on" causing the ignitor to continuously fire.
Oct 29, 2007 | Jenn-Air JJW8530C Expressions Collection...
Jenn-Air JJW8530C Expressions Collection Dual Single Oven Logo
705 people viewed this question
Top Jenn-Air Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Are you a Jenn-Air Oven Expert? Answer questions, earn points and help others
