Question about Jenn-Air JJW8530C Expressions Collection Dual Single Oven
Wiring diagram I have a Jenn air electric cooktop model #JEC9536ADB that is missing the wiring diagram. I'm not able to find them online can you help? need help wiring a jenn air cook top 4 wire to a 3 wire outlet
  • Anonymous Mar 21, 2014
    how to connect the electric wires of defy 770 ceran touch screen hob. Diagram not supplied in booklet
    Scholar:
  • 121 Answers
This model of cook top needs the 4 wire install because it has both 220v and 110v circuits. The forth wire is a neutral that operates the 110v circuit. You can move the ground of the 3 wire outlet to neutral, but ONLY! if the ground wire is insulated. What this will do is give you both your 220v and 110v circuits. The problem with that is your cook top will not be grounded. The best solution is to locate a neutral wire and tap into it, this will give you your 4 wire circuit. Your missing a neutral in a 3 wire outlet.
More Asst.
eboukater@gmail.com
Posted on Sep 24, 2008
I have a Kenmore Elite Electric Slide in model 790.4671 that is 5 years old. The entire cooktop will not work. The oven, clock etc. are working fine. I have no error codes, beeps or anything, used it...
You should probably pull the entire unit out of its spot in amongst the cabinets and remove the back cover. Check for burned or broken wires and connectors. Also, there will be wiring diagram on that rear panel that illustrates how the various parts of the oven and cooktop are wired. Check that diagram to see if there are any fused links or other "over-current" protective device built into the circuit. If there are, identify them and check them for continuity (confirm that they are still viable and have not opened or "tripped"). Finally, look at the diagram and determine what wires supply power to the cooktop controls. My guess is that one of these wires has some how been compromised and needs to be repaired or replaced. Make sure that the unit is unplugged when you are inspecting and testing the various portions of the electrical system. You will need a volt-ohm meter to check for continuity and, once you've made repairs to check for voltage at different points in the stove's electrical system. Most electric stove/cooktops are 220 Volts. If you are not comfortable and familiar with troubleshooting electrical appliances you may want to farm this project out to someone who is. There is always risk of injury or death when working on electrical equipment without proper knowledge, safeguards and equipment. Good luck and please be careful. Hope this helps.
Nov 05, 2013 | Ovens
Oven, clock, timers all work, but grill & cooktop do not function Jenn Air Model SVE87600
Check the back and make sure the wiring to the grill cooktop is not unplugged from the main oven.
Nov 04, 2013 | Ovens
MY JENN-AIR MODEL #WW2460B WALL OVEN DOES NOT DISPLAY THE CLOCK/TIMER. IT STOPPED WORKING DURING A SELF CLEAN CYCLE. IS THERE A WAY I CAN ORDER THE PART TO REPLACE IT MYSELF AND ARE THERE WIRING SKEMATICS...
There is a high limit thermostat that will cut all the power to the upper oven elements. Their is a wiring diagram in this link http://www.searspartsdirect.com/partsdirect/part-model/Jenn-air-Parts/Wall-oven-Parts/Model-WW2460B/1266/0125300?pathTaken=&prst=0&shdMod=WW2460B
when clicking on it,it will say not avaliable. A trick i have found is to open that link and then using your computer tools select the maximum zoom i use IE set to 400% and its pretty ledegable.
Gene
Aug 11, 2011 | Jenn-Air Ovens
I'm looking for a Jenn Air wall oven W136 schematic, is there one available?
Jenn-Air is now a division of Whirlpool so you might want to check with their closest service company and ask if there is a wiring diagram pasted inside a panel of the unit. This is common practice on many appliances.
May 17, 2010 | Jenn-Air 27 in. Electric Single Wall Oven...
The motor in our Jenn-Air central downdraft has stopped working. It's an electric cooktop. We think it's time to replace the unit; want to keep the central downdraft format, but this time want to have...
Not a problem . take a look at Jenn-air 's dual fuel . gas top elect oven and also down draft unit . can be vented several way's .. mm hope this helps . feed back pls . 84020
Dec 21, 2009 | Ovens
I HAVE A W136C Jenn-Air wall oven and would like a wiring connection diagram. Icant figure where to connect the orange wire
Look for schmatic behind control panel, open oven door and remove 4 screws that hold upper face panel down, panel should slide up 1/2' or so and lift off.
Sep 14, 2009 | Jenn-Air 27 in. Electric Single Wall Oven...
Wiring 4 wire cook top to 3 wire outlet
What you have is a 220v and a 110v circuit within the cook top. It needs a 4 wire feed to supply 2 hots, 1ground, and 1 neutral. The 3 wire outlet only has 2hots and a ground no neutral, which will probably not allow your control circuit to operate. You nee to run a neutral wire to obtain a 110v circuit. DO NOT try to run neutral off the ground or you will energize your cook top cabinet and it will shock you. Your solution is to run a neutarl wire from the closest circuit that you can find.
If you need further asst.
Eboukater@gmail.com
Sep 24, 2008 | Jenn-Air JJW8530C Expressions Collection...
Jenn-air ww30430p
this can be the light unit or the power unit supplying the voltage to the light unit. both cost about$150 each. I need a wiring diagram or know the voltage that comes out of the epower supply
Nov 14, 2007 | Jenn-Air WW30430P Stainless Steel Electric...
Jenn-Air JJW8530C Expressions Collection Dual Single Oven Logo
574 people viewed this question
Top Jenn-Air Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Craig Butler
Craig Butler
Are you a Jenn-Air Oven Expert? Answer questions, earn points and help others
