Question about Gateway Computers & Internet
Yes, somehow I accidently got connected to a website called cashbuzz and now when I turn on my p.c. it pops up right in the middle of my screen. I have no way to contact them and it's making me crazy that I can't get rid of this thing.could you please help
  • 75 Answers
IT must be a spyware...intall Anti spyware software and remove it by scanning..
Posted on Sep 24, 2008
Screen
Suggests a problem with the Video Cable, screen Inverter, or LCD screen.
However the diagnosis starts with the graphics chipset. It has to be ruled out as the problem before going on. Otherwise you would be foolishly replacing parts, (Video Cable, screen Inverter, LCD screen), when it would do no good.
1) Laptop OFF, monitor OFF, connect a VGA monitor to the VGA port, on the left side of the laptop.
This is an example of a VGA Cable, and VGA connector (port),
http://en.wikipedia.org/wiki/VGA_connector
Scroll down a little for the VGA Cable example.
You can use a CRT type of VGA monitor, (Looks like a small TV), or a flat LCD screen monitor if it has a VGA cable.
Turn the monitor on. If a CRT type allow it to warm up.
Turn the laptop on.
By factory default settings the display should show on the external VGA monitor.
If not;
There are at least 3 display options;
A) Internal monitor of laptop ONLY
B) Internal monitor of laptop AND external VGA monitor
C) External VGA monitor ONLY
Press, and hold the Fn key down, and at the same time tap once on the F5 key. (The F5 key is the Display Toggle-Over key)
Still no?
Hold the Fn key down again, and tap once more on the F5 key.
Display is good on external VGA monitor?
Then problem is Video Cable, or inside the Display Assembly.
(screen Inverter or LCD screen)
Display is bad on the external VGA monitor, means there is a problem with the graphics chipset.
Most of the time, it is the MOUNTING of the graphics chipset TO motherboard, and not a faulty graphics chipset.
Video Cable:
The Video Cable connects to the motherboard, in an area under the Middle Cover.
(Middle Cover. Acer for Switch Cover. The plastic strip under the LCD screen, and above the Keyboard. Has the Power On button, LED indicator lights, and speakers)
It then runs under the left Hinge, and up into the Display Assembly.
From there a small cable comes off of it, and connects to the screen Inverter. The main part of the Video Cable, then connects to the back of the LCD screen.
So we have - Motherboard connection, screen Inverter connection, and LCD screen connection.
Due to the normal opening, and closing of the laptop; one or all of those connections could be loose.
The Video Cable could be pinched, and pulled on.
It can also cause damage to the Video Cable.
Example of Video Cable,
http://www.ebay.co.uk/itm/Acer-Extensa-5630-5630EZ-LCD-Screen-cable-50-4Z410-002-/200877167645?pt=UK_Computing_Other_Computing_Networking&hash=item2ec536541d
The large white connector at the Bottom, with black insulation around it; plugs into the motherboard.
The small cable with the smaller white plug connector, connects to the screen Inverter.
The main part of the Video Cable goes up, and ends in a large white plug connector. The smaller cable that goes on up from it, plugs into the webcam.
Start by checking the motherboard side connection of the Video Cable.
1) Remove ALL power. Remove the AC adapter (Charger), and Battery.
2) Open the laptop.
Remove the Middle Cover.
The Middle Cover pops off. HOWEVER be aware that there are cable STILL attached.
Come to the right of the Power On's rectangular button. See the parting line of the Middle Cover to Bottom Cover?
I use a thick guitar pick to insert in that parting line, and ease the Middle Cover up a little.
You can also use a Spudger Tool. I do NOT recommend using a metal tool, such as a metal flat tipped screwdriver.
You can mar the plastic parts very easily, and also can cause damage.
IF, this is your only recourse, make SURE the tip of the screwdriver does NOT go in more than 1/8th Inch. That is a tiny bit more than 3mm.
Ease the Middle Cover up, then use your fingertips, and go along the edges of the Middle Cover. You want to pop the Middle Cover off, then roll it over on the Keyboard; with the cables still attached.
The Video Cable motherboard connector, is to the left of the left Speaker, and below the left Hinge.
Visual inspection alone will NOT do. You have to physically try to plug the Video Cable connector in.
Now ease the Battery back in, and reconnect the AC adapter. Plug AC adapter back into power. Turn the laptop on. Fix the problem?
No? Go on.
Remove ALL power again.
This time you are going to check the screen Inverter connection, and LCD screen connection.
The plastic frame in front of the LCD screen is the Display Bezel.
Acer calls it the LCD Bezel.
There are 4 Screw Covers to remove. One in each corner.
Top Left, Top Right, Bottom left, and Bottom Right.
These are made of synthetic rubber, or plastic. They have a type of rubber cement on them, that holds them on.
I take a computer pick, and remove them. You may find a similar tool if you do not have a computer pick.
Start at the bottom edge where the Screw Cover, meets the Display Bezel. Lift up.
If you use care when removing you may be able to reuse the Screw Covers. Don't stick anymore? Apply a tiny dab of rubber cement with a toothpick.
I L-I-G-H-T-L-Y stick them to the Display Bezel for safekeeping.
(They like to stick to the computer pick, your fingers, and it seems sometimes passing satellites)
Remove the 4 Philips head screws. (No.1 Philips screwdriver, or comparable Jeweler's screwdriver)
The Display Bezel has TABS that go around the perimeter, of the inside edges.
These snap into matching Latches on the Display Cover.
The Display Bezel is flexible. Made of space-age plastic.
To remove use your fingertips on the inside edge at the bottom. Flex the middle of the bottom up a little.
When it is high enough, slide s fingertip underneath, and go along the Display Bezel at the bottom. Go towards the Right, or Left.
The Tabs/Latches should start releasing. Snap, snap, snap. Almost sounds like you are breaking it.
Bottom popped loose go up the Left side, or Right side. Pop those Tabs/Latches loose.
Once the Display Bezel has popped loose pretty far, it should come off. I state SHOULD. I have has Display Bezels where I had to fight it all the way off. Every Tab/Latch had to be released.
See the small circuit board at the bottom? That is the screen Inverter. You can physically check the connection, just to see if it was loose.
While you are here though, you need to check LCD screen connection. After that, then make sure the screen Inverter connection is tight.
Reason is you are going to partially remove the LCD screen, to check it's connection; and this could disconnect the screen Inverter connection.
(Remember; all connections have to be Physically checked. If the screen Inverter connection was popped partially loose, when checking the LCD screen connection, you may not see it.
Check screen Inverter connection, AFTER checking LCD screen connection )
LCD screen connection is tight, after physically checking?
Screen Inverter connection is tight?
Lay the LCD screen assembly back in the Display Cover, and Display Cover is tilted back a little bit.
(Don't want LCD screen to fall forward)
All power reinstalled, turn the laptop on again, and see if these connections were the problem.
I have run into this many times, and so have users who have posted on here, through the years.
Still no?
You MUST rule out the Video Cable as the problem before going on.
Means the Video Cable has to be removed, and checked for continuity. Nothing fancy here. You just want to make sure electricity, is passing through every wire in the Video Cable.
Test is performed with a multimeter set to OHM's (1K), and every wire is checked.
No access to a multimeter? Then suggest taking the Video Cable down to the nearest small computer shop, and have them check it for continuity. Should only be a couple of bucks.
More in a Comment.
Jan 24, 2013 | Acer Extensa 5630Z-322G16Mn Notebook
I get a black square in the middle of the tv. I can still see part of the program and hear it but there is a code or something that pops up it starts with lid and has numbers following. If I push the input...
U have the tv original remote wright?Yes.Used ur tv remote look for a button that said CC.Pushes a few times make sure all like CC1,2,3 so on to all off.The black square box show up in the middle of the tv screen,numbers and printting words on the screen it is are call Close Caption for the hearing impair person to read,will disappear from the middle of the tv screen.
Apr 04, 2011 | Sharp AQUOS LC-32D44U 32 in. LCD TV
There is a vertical strip right of centre of screen an inch thick. Is there any chance of this being repaired without parts, and have you come across this before. Thank you. Ray.
Yes and no.The board call the T-CON decoders board have the problem.This board sit in the middle bottom of the LCD screen panel.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish T-CON decoders board for the replacement.
Dec 09, 2010 | Toshiba 42WP26 Television
When I turn on my Vizio P42hd I get lines of different colors down the left side of the unit from top to bottom. Is this something that can be fixed? My email is mdrye@holtville.k12.ca.us
This problems is not causes by a person or some objects by hitting ur LCD tv picture screen panel?If,yes,by a person or an objects by hitting the picture screen panel.This tv is not repairable only can be by replaced the whole entire LCD picture screen panel only,sorry than this tv is not worth repairing.Because by replacing the tv LCD picture screen panel itself,will cost the same as a new tv.If these colors strips show up by itself,yes,tv it is repairable.The board call the T-Con decoders board is dead.This board sit right at the bottom right in the middle of the LCD picture screen panel.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish T-Con decoders board for the replacement.
Nov 22, 2010 | Vizio P42HD Television
I turned on the tv and heard a popping sound and the screen went to horizontal lines with some protions of the picture missing. Is this something I can fix, and if so, what are the part numbers that would...
The board call the T-CON decoders board is dead.This T-CON decoders board sit wright in the middle bottom of the LCD screen panel.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish T-CON decoders board for the replacement.
Oct 30, 2010 | Samsung Televison & Video
A black box keeps appearing in the middle of the screen and stays on until I either turn off the TV or turn on the settings screen and clear it
Somehow, the cable box or some other device changed the settings for the caption box on the TV. While no closed captions were appearing on the screen, the box was being displayed. The box stopped popping up when the captions setting was turned off.
Dec 27, 2009 | Toshiba 27AX61 TV
My action replay dsi turns red when i turn it on
ok it took me like 2 hours but I read the whole manual at the back page it says if anything like this happens you'll have to reset the system through the ar pc manager what to do exactly is in the manual the
connect ar to pc
load the code manager
right click on the program in the top lerft of screen
choose about action replay from the pop up menu
click on the reset action replay button
note: you will lose all codes on the system but it should work
Oct 06, 2009 | Nintendo DS Lite
Need to change language
I will do my best
1.Turn the unit on and wait for the street map to show up
2.Press the screen once in the middle
3.Six icons appear. bottom row middle one should be a spanner, press once
4.Now an arrow shows on bottom row on the right hand side, press once
5.Press arrow again once
6.Press arrow again once
7.Hopefully you can now see 'Flags' on the bottom row, middle icon, press once
8. Select you language 'I assume English UK' is what your after
9.Press YES on the left (IN GREEN)
Thats it , your done and hopefully seeing all in English
Hope this helps
Please rate and thank you
compusat
Mar 12, 2009 | Tomtom GO 520 GPS Receiver
Monitor settings
hi swalle1, it sounds like you display settings have been changed, to fix this when your computer has finished starting right click a space on the desktop where there are no icons, then click on properties, a pop up will appear, at the top you will see tabs choose the Settings tab, now in the middle of the screen to the left you will a box on the called screen resolution with a slider, place your mouse on the slider and slide it the left till it says 1024x768 then click apply, now this may not be the setting you use as you may have a wide screen but this is default setting to get you started, you can slide that slider till you get the right setting back either to the right for higher resolution or the left lower.
I hope this helps but if it does please let me know.
Oct 08, 2008 | Acer Aspire 3000 Notebook
Computers & Internet Logo
21 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
