PHASER 8550D error report 07,010.43:217298
Error report 07,010.43:217298
  • 300 Answers
7,010.4x: PM_FAULT_HEADTILT_HOME_ERROR
The printhead is stuck in the tilt position by the tilt arms. The process motor gearbox
being out of sync can also cause this error.
1. Reboot the printer.
2. Verify the lock arms rotate correctly.
3. Check for spilled ink around the printhead.
4. Check the process motor gears for damage. Ensure the
process gears are correctly aligned and homed.
5. Verify the process gear box, process shaft, and drive
module shaft are at home position.
6. Verify the headtilt gear will engage, see the home
positioning procedure on page. You can manually
engage the headtilt gear.
7. Run the Tilt Axis Drive test.
8. Run the Process Motor test.
9. Run the Head Maintenance Clutch test, if the test fails
replace the clutch.
10.Run Wiper Drive test. If this fails inspect the wiper
drive system.
Posted on Sep 24, 2008
Getter "Report fault 917" on my Phaser 7400. How can I fix?
I am getting a report fault 917 error on the phaser 7400
Sep 23, 2010 | Xerox Phaser 7400/DXF Laser Printer
What is the 93.12.0 error
It is difficult to discern your error, as the code is not quite what Xerox reports the error numbers as ...
POSSIBLY: 90 to 99 Replace Non-Xerox [C][M][Y][K] Toner Cartridge
However, you may wish to check out this page, as it lists the different codes and what error they are reporting.
http://www.support.xerox.com/SRVS/CGI-BIN/WEBCGI.EXE/,/?St=423,E=0000000001536475895,K=6143,Sxi=19,UseTemplate=FaultCodeSearch.tem
Jul 10, 2009 | Xerox Phaser 6350DT Laser Printer
Printer error Contact service Report fault 15,004.45:40227
There are 2 , 150 watt halogen lamps in the drum heater assembly. One or both are burned out.
I can send you instructions on how to replace them. Xerox will want over $250 for an entire heater assembly. You can buy the lamps at Lowes or any place that sells Halogen lamps for around $15 for a set.
May 05, 2009 | Xerox Phaser 8200 Laser Printer
Printer error - call for service, 9-911 what does this mean?
It will be best to run diagnostic tests on the printer and especially the electronics before coming to any conclusions. My first guess would be that some part of the memory went south. The test procedures are in the service manual which can be downloaded at: www.lpscomputer.com/ec/Phaser_7700_Service_Manual.pdf
Apr 16, 2009 | Xerox Tektronix Phaser 7700GX Laser...
I have a Tektronix 860dp phaser printer that is showing service report error 07.005.47:26078 Can you help? It prints test page perfectly Regards Alan
Fault 07,005.47 is a failure of the drum maintenance system. Having the printer repaired by a certified technician is strongly recommended because the printer's covers will have to be removed, and the printer partially disassembled.
Jan 14, 2009 | Tektronix Phaser 860DP Thermal Printer
Xerox Phaser 6110MFP reports FM_IO.c 172 ROOT during startup
Also make sure you have the machine plugged directly into the wall outlet...some surge protectors or multi-outlet strips won't allow sufficient power to properly boot up and run the machine !
Dec 10, 2008 | Xerox Phaser 6110 Laser Printer
Error message
Cause:
This message is related to the on-board SRAM on the Print Engine Control Board Solution: thumbsup.gif Fixed! thumbsdn.gif Did not fix. Replaced the Print Engine Control Board,
Dec 19, 2007 | Xerox Phaser 7300DN Laser Printer
Xerox phaser 8500 reports Internal Error
I would suspect the elecrtonich module has gone bad.
Without an error tht is my best guess.
Oct 23, 2007 | Xerox Phaser 8500/DN Printer
224 people viewed this question
jasbo
jasbo
