Serial connecter - no port on computer
Unable to connect my sewing machine to computer as it has a serial connection and the computer only has USBs
  • 45 Answers
Try getting this ...
http://www.moxa.com/land/USB_to_Serial_Hubs.htm?_kk=usb%20to%20serial%20port&_kt=702f397c-d26e-461b-8187-4595e9b2aa61&gclid=CNrH3Oag9JUCFQWR1QodDVMAig
or something similar.
Posted on Sep 24, 2008
I purchased a serial port that is not compatable with my sewing machine, I also purchased an updated software with Bernina to make my embroidery machine user friendly. however,I am unable to connect
Problem is that the Bernina software you are using expects to talk to a 'COM port and the PC's USB serial interface doesn't automatically default to a COM port. Make sure you have installed the software that was delivered with your USB-to-Serial adapter and look on your PC's 'Device Manager' under 'Ports' - you should see the USB adapter listed and it should be assigned to a COM Port number. You need to check what COM port numbers are accepted by the Bernina embroidery software (sorry, I cant remember and haven't got one here presently) - it should be in the Options menu. You have to ensure that the USB 'virtual COM port' is the same as that which is set in the Bernina software. If the Bernina software doesn't support the COM port allocated to the USB interface, go to 'Properties, Port settings, Advanced, COM port number and set this to the same as the COM port number in the Bernina software - hopefully this should set up the link OK, provided you haven't got a COM port clash - to avoid this, it's usually best to choose a COM port number of 2 or above.
Dec 02, 2011 | Bernina Artista 180
Connecting scan n sew
adpoter on that aint suitable maby they make a parelle pci card u could use
Jan 27, 2008 | Sewing Machines
Cant connect my artista 180 to my pc it says 'serial port engaged'
Try changing to a different COM port and make sure you haven't got any other applications running that might be using the serial port, even if you've nothing connected ... have you recently installed something that might be using the COM port ?
Nov 19, 2011 | Bernina Artista 180
I was just given a 180e embroidery machine ( I am a total novice) and I am not sure how to connect the dongle and get designs that are in my computer. Thank you so much cat
I am not exactly sure of this particular model. But the dongle should just plug into the computers port on the back of the computer.
Jan 19, 2011 | Bernina Artista 180
Trying to connect a USB to the serial port of a Bernina Sewing Machine (Bernina 170). Has been working for a couple of years and has stopped all of a sudden. Does not work on and XP PC, Vista or win 7....
The Dynex adapter does not have any numbers on it. It was the one that is only about a foot in length and has a square center piece that houses the conversion electronics. Standard 9 pin RS-232 male plug on one end and the standard USB plug on the other end. I purchased it within the last month at BestBuy here in Austin TX.
Oct 28, 2010 | Bernina Artista 170
Old Dell Omniplex pci communication serial port needs driver
Go to the Dell support website http://support.dell.com/support/downloads/
Put in your service tag # (it is usually located on a little barcode sticker on the back of your machine). It does not matter if your machine is out of warranty or not. This is one of the reasons I like DELL. DELL has drivers for their machines that go back 10 years or more. I have never had a problem getting them from the website. When you see the downloads that you need download the ones that say driver. You may have to download the chipset driver also. When you do download the drivers and it asks you for the filename to save it as I find that it helps to add a name to the dell #'s to describe the driver so that it looks something like R264710video. Once you download them and transfer them to your computer they should install themself in the correct location (you just have to double-click on the .exe file and answer the prompts (if any)). Let us know if this helps.
May 21, 2009 | Javelin Systems Inc (81160083W98) PC...
Usb problem
need to check in the device manager whether the usbs are enabled or not . you can right click on my computer and the go to properties and then go to the hardware tab and then device manager .
right click on the usb and then last option which has power options need to check that option is not checked in all the usbs and then restrt the machine and then try to connect , if still doesnot work then motherboard of the system will be replaced.
Mar 27, 2009 | Acer Aspire 7520-5757 Notebook
I can't get a design to transfer to my sewing from the computer. I even hooked it up with a wire so the problem must be in the sewing machine.
Hi Callieprince,
I am sure i will be able to help you, but i need more info:
  • Do you connect directly from the machine serial port to an old computer serial port, or do you connect from the machine serial port, via a serial/usb adapter to usb?
  • Does your computer reconize the communication port?
  • If you click on "transfer to machine", there is a port icon, and also a bits per second icon, which can be changed by clicking on the little black upside down triangle. Which ones are you using?
If you can answer my questions, I will respond as soon as possible
Dec 21, 2008 | Singer Quantum XL-6000 Computerized Sewing...
Connection problem with computer to sewing machine and reader/writer
It is not true that the 180 is not compatible with new software.
I'm owning a artista 180 from 2002 and just installed the software designer V5+ on a laptop with windows vista.
The only problem was that there was no serial port on the laptop, now I have a new cable with USB ans serial output and the software works very well !!
When you contact Bernina you will get the same answer.
greetings Carla
Jul 16, 2008 | Bernina Artista 180
Computers & Internet Logo
56 people viewed this question
David Payne
David Payne
