Question about Mico DVDR310 DVD Recorder
Mico alma t300 home theatre speaker sound
When i put down mix, only the center speaker produces sound
when the option is 5.1, only the subwoofer n front speakers!
what can i do to get sound from all the subwoofer, center, front n sorround speakers?
Why is it intermittently losing channels...front speakers and or rear surround?
How to troubleshoot low sound or no audio from the rear ...
https://us.en.kb.sony.com/.../how-to-troubleshoot-low-sound-or-no-audi...
Aug 15, 2015 - Verify that the rear surround speakers are properly connected to the ...For Dolby® ProLogic surround sound, the center-channel mode must be set to ... the center or rear surround speakers for the Home Theatre (HT) system.
Why Are My Speakers Producing Static? - Electronic House ...
www.electronichouse.com/.../home-audio/why-are-my-speakers-produci...
Here are 3 reasons that speakers produce static and solutions you can try. ... If they are your dedicated front L/R channels speakers in a 5.1 or 7.1 system, you more ...Since you have no problem with your existing rear speakers, if they begin to distort on... Home Theater Subwoofer Puts Boom in This Room · Soundbase vs ...
How to Check if your Speakers are Wired Correctly ' Richard ...
www.richardfarrar.com > Podcasting
Mar 25, 2009 - Attaching speakers to your Hi-Fi system usually only requires a few cables. ..... Is this test applicable for a home theater setup with 5 speakers? ... frontstereo speakers, but to do a similar test on your rear surround speakers would ... Yes, switching polarity on one channel of the amp output to your speakers ...
Pioneer VSX-816 speaker drop out - AVS Forum ' Home Theater ...
www.avsforum.com/.../1068233-pioneer-vsx-816-speaker-drop-out.htm...
Sep 20, 2008 - 30 posts - ‎24 authors
The right front speaker sound drops out intermittently as of about 6 months ago. ...mode and back to Auto Surround would bring the center channel back. ... the push pin that holds several grey wires in place, and pull the wires loose. 9. ..... Is it possible that the cold joints are elsewhere in the system, but that ... Yamaha RX-V663: Intermittent/No Audio in Front ...
Jan 23, 2014
Sony Receiver going in to Protect Mode
Jan 12, 2012
The Official Sony STR-DH820 Thread
Aug 29, 2011
Denon AVR-1910 - No more sound.
Feb 15, 2011
More results from www.avsforum.com
Dec 12, 2015 | Audio Players & Recorders
4 ohm and 8 ohm speakers
You can plug in higher ohm speakers , the higher the ohm the higher the resistance is, it is a danger when you plug lower ohm speakers into a higer ohm Amp , at a high volume that will cause them to blow , the center speaker would be fine to use a higer ohm speaker , your best choice is to buy a Active Subwoofer, which means the sub has it's own power supply , and u can blast the thing as much as u like , thn u can turn the bass down on all the other speaker's so u can play it louder , and have the sub turned up has high as u like , this is the best way to get great sound with high volume , buy a Active sub woofer , any active subwoofer is ok , a active sub woofer has its own volume and inputs on the speaker ,
Dec 09, 2007 | Audio Players & Recorders
My LG HT904SA home theater rear and center speakers not working
I have just set up my LG HT904SA home theatre and when I play a dvd I am getting little or no sound from the rear speakers? What do I need to do? What do I need to press?
Help!
Dec 27, 2009 | Audio Players & Recorders
No human sounds when playing dvds.
sound like the center channel is out
either bad connection at speaker or receiver is not putting out sound on center. A quick swap of speakers at receiver end will tell you if it is the latter
Apr 13, 2009 | Audio Players & Recorders
Instalation instructions required
Uhmmm. . .okay. . .I would use nothing less than 16AWG speaker cable. Do not run the speaker cable parallel in close proximity to any AC wiring. Speaker cable rated to run through walls with usually be color coded red and black. Connected the red to the red on the speaker and red on your home theatre receiver. Do the same for the black. If speaker cable insulation is clear, look closely for subtle markings or writing on the insulation. The writing will only be on one of the two wires. Designate that as the POS or PLUS or + or RED. Connected it to the red on the speaker and the red on the back of your home theatre receiver. The other is by default the black and connect it to like colors. Repeat for all 5, or 7 speakers in your theatre. Your subwoofer probably has a seperate amplifier, so it gets it's power from it's own AC power plug. . .so plug it in. The sound coming from the Home Theatre receiver will be low-power and will carry on an RCA cable. Look for the subwoofer output on the home theatre and connect it to the input on the subwoofer. There may be a right and a left input on the woofer. . .it doesn't matter which you plug it into. . .either one will do.
Mar 09, 2009 | Audio Players & Recorders
Can i connect JVC SXXSW6000 home theatre to my pc...if so how?
You need a receiver. A surround sound receiver is a 5-channel amplifier with a line-level subwoofer out. These are available at electronics stores. Receivers usually have digital inputs like optical and coaxial that you can use with the S/PDIF output of your PC.
Nov 06, 2008 | JVC SXXSW6000 Speaker
I'm not sure how to set up my LG HT762TZ home theatre system up properly. I have connected everything and made sure it is working properly, but i am not sure where to put the speakers and which way to put...
The rear speakers are meant to be placed at the rear preferrably overhead or at the bottom behind your listening area. Both speakers should be facing the sides. You can place your subwoofer anywhere as its sound is non directional. Don't forget to adjust its volume properly, the rear should not overwhilme the front/center sound. Happy Listening
Mar 27, 2008 | Audio Players & Recorders
Cant Hear Dialogue Over the Background Sound
The owner's manual should have a section on how to balance the system. I don't have one at the moment, but I believe that this model also has a setup tone generator option. Look in the owner's manual or online at Yamaha for a copy of it. This will contain the instructions for the setup.
Dan
Mar 20, 2008 | Audio Players & Recorders
5.1 Home Theatre - PC
Its due to 2.1 channel sound input from your PC. Your Laptop supports only 2.1 channel sound so all the 5 speakers cant be played at a time! You need 5.1 channel input to work all 5 speakers
Dec 07, 2007 | Bose 701 Main / Stereo Speaker
Mico DVDR310 DVD Recorder Logo
91 people viewed this question
Top Mico Televison & Video Experts
Are you a Mico Televison and Video Expert? Answer questions, earn points and help others
