Hp pavillion s3420f slimeline power light shows green but the switch won't turn the computer on
  • 45 Answers
Have you tried taking the battery out and putting it back in again and trying again, if yes take it to a specialist and get them to check the connection on the board itself should be a cheap fix hope this helps
Posted on Sep 24, 2008
Computer monitor HP Pavillion keeps clicking and flashing but won't turn on the screen
you need to bring your PC to a technician... Its the best solution for that. It will save you time and money.
Mar 08, 2013 | Computers & Internet
HP Pavillion a1514n Won't Turn On
Yes even with the green light on it could still be the power supply. Have you pulled the power, opened the case, and pulled the BOIS battery? Could be the BOIS needs to be reset. You might also pull all the memory chips, turn it on and see if you get a beep code. I have had that happen in the past. Then I would replace the power supply (if you have an old one laying around use it to test, with just the MOBO plugged in). If the power supply fails, that leaves only the mother board as the issue.
Good luck, I hope one of these suggestions works for you.
Jun 29, 2012 | HP Computers & Internet
Hook a monitor to the video output, if no change! the video graphics chip is bad located on the motherboard.
Jun 29, 2012 | HP Pavillion dv9740us Notebook
Hi ... I powered down my HP Pavillion a622n for the first time in a while. When I plugged it back in, the power light is flashing and the computer won't start. Can you please help me to determine what...
power off the computer by removing the power from the rear of the computer then remove the cover of the cpu then also remove the power conector to the hard disk then locate the memory card remove them then wipe them clean with a dry clean cloth then insert the memory into the slot connect the power plug and switch on if the display screen is ok and post bios showing then switch off the computer and connect the power conector of the harddisk
Jul 03, 2011 | HP Pavilion a622n (PC108A) PC Desktop
Computer won't use sleep mode anymore
Go to Advance Power Settings.
Set hard drive to turn off a minute or 2 before sleep.
Set Hybrid and Hibernate modes to "Off"
Under USB settings select "Disable"
Under Multimedia select "Allow ....." also setup your screen to turn off ( pick how long monitor will stay on. you can also try going into the bios and setting it to default. save and reboot. let me know if this helps.
Nov 13, 2009 | HP Pavilion S3420F Slimline Desktop PC
Computer will not turn on
Posible bad power supply try using another power supply.
Jul 03, 2009 | HP Pavilion a620n (PC028A) PC Desktop
HP Pavillion 400 Power switch problem???
Could be your power supply is broken. That is a very common problem. Sometimes the computer will keep on restarting when the power supply is about to give way. I doubt it's the motherboard that is causing the problem, but then again i have never had a motherboard fail on me.
May 03, 2009 | HP Computers & Internet
HP Pavillion a550y
GATEWAY DESKTOP DX4900-09 GREEN POWER LIGHT KEEPS BLINKING, COMPUTER WON'T COME ON.
Mar 02, 2008 | Computers & Internet
No power
the power supply should be replaced.
Go to Blinking LED section.
Here are steps to take from HP:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bph06788&lc=en&cc=us&dlc=en&product=449144&lang=en
Jan 07, 2008 | HP Pavilion a805n (PS519AA) PC Desktop
Computers & Internet Logo
98 people viewed this question
David Payne
David Payne
