Question about Refrigerators
My lg gr-222sbd fridge/freezer is not working properly. Every 5 minutes, there is a click sound, then a buzz for about 10 seconds, then another click sound. It is not cooling properly. Do I need to buy a new fridge or is this fixable?
  • Anonymous Nov 15, 2008
    FREEZER NEEDS TO BE ON NO 7 TO KEEP COOL . WHEN YOU PUT THERMOSTAT ON 3 OR 4 IT DOES NOT COOL. IS IT A FAULTY THERMOSTAT ?
  • 943 Answers
Hi thanks for the question it sounds like the compressor is trying to start your problem is the relay or a bad compressor replace the relay and see if this solves the problem if it does not then a faulty compressor thanks please leave a positive feed back the appliance doc
Posted on Sep 24, 2008
Buzzing sound Kitchen Aid fridge Model KBLA20EMSS
It may be the arm in the ice maker is down. Even though the ice maker does not have the water hooked up if the arm above the ice bin is down it will still cycle the ice maker try lifting up the arm it should stay up this signals the ice maker that the bin is full and should shut off the ice maker. Hope this helps.
Dec 31, 2013 | KitchenAid KSCS25FKSS Side by Side...
LG Fridge-Freezer model no. GR-T632DVQ The upper freezer lights works. The lower fridge light stopped working. When tested the light bulb works and is NOT broken. There is a combination double...
looking for a door for lg refrigerator GR-T632DVQ
if anyone can help me plz ring 0421203100
perfect fridge, had it for 10 years, door fell off today :(
i've been searching everywhere, *sigh
please help if u can
Mar 16, 2011 | Refrigerators
My refridgerator is making a buzzing sound with a click at the end every 2-3 minutes. The buzzing lasts about 5-7 seconds with a single clock at the end. When this sound is made the lights in the fridge...
Possible this can be a faulty thermostat sensor action tripping the relay which is clicking. You must remove and check the backside relay if the fridge is old for a wearing off.
Also a fault in the circuit of the auto defrost can cause the compressor to shut and start.
Since the fridge works well the fault can be related only to a erratic connection or failing component.
Jan 31, 2011 | KitchenAid KBRP20EMSS Bottom Freezer...
I have a LG GR-L207DUZA ''er ff''
i dont have the manual however.. this could be your freezer fan is perhaps seized.. you can test this by leaving your freezer door open to raise the temp and wait ti see if your fan comes on.. this may take upto 10 minutes so be patient
Nov 11, 2009 | LG Refrigerators
The fridge/freezer is making buzzing noises that go on for 10/15 seconds every 5 minutes or so. Both fridge and freezer have heated up to 49 and 26 degrees through the night. Help!
ur compressor is trying to start but the safety is turning it off may have a bad compressor but try this first might get it working again -(safety click sound) disconnects power when compressor gets to hot or is drawing to many amps--stuck--comp gets hot unplug unit and clean with a vacuum carefully under where comp and fan are this is the condenser area after cleaning or 1 hr plug in and check for start and that condenser fan is working may be reason for overheating-if still not working compressor needs service
Nov 04, 2009 | Maytag Freezers
Buzzing and low temps
sound like a compresser relay/overload ,uplug the refigerator remove back cover, remove relay that is on the compressor and check it by shaking it , it should not rattle. if it does replace it..
Aug 10, 2008 | Frigidaire FRS26R4A Side by Side...
Refrigerator buzzing for 10 seconds every 4 or 5 minutes
Buzzing is usually a fan, like one in the freezer, or back bottom - for cooling the freon. The compressor over-heat usually will make a single click (off) and a few minutes later a click (on). If the fan in the freezer stops working well, the freezer will frost up and the fridge section will not be cold enough.
Apr 20, 2008 | Refrigerators
REF AND FREEZER STOP COOLING
We had a repairman come out, said it was the compressor, bad news...$650 if he repaired...good news...compressor under manufacturer's warranty for five years so you may want to call Maytag. It will be less expensive if the part is covered and you only have to pay for labor. Hope this helps. Bought our fridge 12/2004 so it was covered.
Feb 03, 2008 | Maytag MFD2560HES Bottom Freezer French...
Refrigerators Logo
158 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
