Question about Foxconn WinFast K7S741MG Motherboard for AMD Socket 462 CPU (K7S741MB6L)
Motherboard keeping beep and the computer can not startup..
  • Anonymous Oct 09, 2008
    my pc needs a bios update
    Brigadier General:
  • 6,966 Answers
To my knowledge, there could only be three (3) reasons for the motherboard to be doing a series of beeping sounds. Depending on the sequence and frequency of beeps, it could indicate:
  • memory problem;
  • video card problem;
  • BIOS problem.
Of course corrective solution is largely based on which is the problem and could be corrected with/by:
  • check/clean/replace;
  • or in the case of the BIOS, reset, update or flash.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Sep 24, 2008
  • 22 Answers
Different kind of beeping have different meaning.. But, the common problem is your hardware allocation on the board. Just try to pull out the ram and insert it back. Do this also on your vga card. By the way, what type bios do you use? e.i : pheonix, award, IBM. Explain the type of beep of your computer.
I have a P5K Deluxe asus mother board error beeps no visuals
Two beeps is usually the video card.
Do you have a spare video card to change out?
This is why people keep obsolete PCI video cards for just such tests.
Dec 05, 2015 | ASUS P5k Deluxe Socket 775 Motherboard
No bios on startup 6 beeps
Go to the manual for your Server motherboard. At the back, under Troubleshooting you should find a beep code index. The manual is probably on a DVD that came with the Server. Six beeps often means failure of one of the boards: motherboard, graphics board ...
Jul 20, 2014 | Cybertron Computers & Internet
Compaq presario C700 continous beep when starting up
Potential Hard Drive failure, (Hard drive s.m.a.r.t. beep) or if MB beep it's chassis intrusion..
1. Remove battery + disconnect power
2. Hold down power button for 20 seconds
3. connect power only (no battery)
4. Turn computer on.
If the beeps stopped.. get a new battery, if the beeps continue..
ABANDON SHIP!
Apr 27, 2014 | Compaq Presario 1200,1600, Series CD...
Continuous beep at startup when loading windows files
If you mean that your computer always beeps at startup, this is a sign that everything is working as it should. This is a good thing. However, if you mean that your computer beeps continuously without stopping, and your computer does not load windows properly, you may need to use a windows disc to reinstall your operating system. If your computer still does not work, you may need to take your motherboard to your nearest pc store to have it looked at. Preferably go where you bought it.
Feb 18, 2013 | Toshiba Satellite Computers & Internet
MY PC KEEPS BEEPING ALL THE TIME AND MY RESET BUTTON DON'T WORK
I'm assuming that it beeps on startup and wont boot. If so this typically indicates faulty memory, or a bad configuration of the memory, but this can mean many different issues.
Aug 05, 2012 | MSI Ms-7528 G31m3 Motherboard Intel Intel...
Computers doesn't startup and has no beep
remove the RAM chip and start the computer without the ram chip inserted and see if you get beeps if yes the motherboard/bios is ok, even if you dont get to hear any beeps, try rubbing the edge of the ram which goes into the ram slot using a Eraser and then reinsert the same back in Ram slot and then see if you can at least get to bios and see if hard disk is detected as windows boots from hard disk if yes check if you can boot to windows if no may need to reinstall windows.please reply with results so that can help
Feb 22, 2012 | Foxconn (945G7MA-8KS2) Motherboard
Dell Dimension 9200 beeps on startup, with nothing...
A beep code of 3-3-4= Video Memory(RAM) Test Failure that would explain why you get nothing on your screen the first thing you would need to do is disconnect your monitor and try it on another computer. if it works fine then the problem is your video card. If that the case and the video card is intergrated with the motherboard, you will need to repalce the motherboard --- Sorry-- Please vote me a 10 when this works
May 20, 2010 | Dell Dimension 9200 PC Desktop
Constant buzz after beep...
Hello
These are sound codes or beep codes.Usually one long steady beep is a problem with your memory or cpu is not onstalled correctly
Apr 21, 2010 | Gigabyte GA-EP45-UD3R Motherboard
Computer gives 1 loud continuous beep on startup
unplug your memory and reseat it... that should fix the issue
Robert
Please take a moment to rate this solution.. thanks
Jan 26, 2009 | HP Pavilion M9040N Elite Desktop PC
Foxconn WinFast K7S741MG Motherboard for AMD Socket 462 CPU (K7S741MB6L) Logo
149 people viewed this question
Top Foxconn Computers & Internet Experts
Alun Cox
Rommel Balcita
David
David
Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
