Question about Symbol LS2208 Handheld
LS2208 keyboard Wedge only works with PC keyboard connected
We have a LS2208 PS2 keybaord wedge I/f, but we have to connect the PC keyboard to it to allow this to work how can this be avoided
  • mrbilly Oct 06, 2008
    we cannot find this option, however by setting to laptop emulation it works but seems to loose this whent he pc is rebooted
  • 661 Answers
One of the settings in the code book is to emulate keyboard function. turn this on and you do not need to have the keyboard plugged in
Posted on Sep 30, 2008
Hello I have trouble with laser ls2208 it is PS2 connection but i have only USB on PC so i buy converter ps2 to usb but after connected scanner read product but not send text to pc .
You can try scanning the Keyboard Wedge host type barcode IBM AT Notebook then rebooting your PC. If this does not work you should order a CBA-U01-S07ZAR. This is the USB cable for use with the LS2208. Zebra Technologies support solution ADC-00217 addresses this type of issue. The article was written for connecting to a laptop, but your connection is similar if you do not have a keyboard attached to the cable. This link will take you to the solution which includes the IBM AT Notebook barcode. portal motorolasolutions com Print the article and scan the barcode then reboot your PC.
Dec 11, 2014 | Symbol LS2208 Handheld
Hi can u tell me that symbol scanner ls2208 will work on ATS
The LS2208 is a universal scanner with many supported interfaces. Please check the ATS if one of the interfaces are available. See the list below:
RS-232 IBM 468X/469X Keyboard Wedge Wand Emulation Undecoded Scanner Emulation USB Synapse Adapter
Oct 28, 2010 | Symbol LS 2208 Barcode Scanner - P/N...
I cant use symbol ls2208ap . how i use it
hello, once you have it connected to your computer via usb, serial or keyboard wedge, you scan the barcodes that come in the user guide to set it up, its pretty much a plug and play. you can find the quick start guide at
http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=7188201cpdf&sliceId=&dialogID=165478796&stateId=1%200%20165462678
Let me know if i can be of additional assistance,
Kim Ganoe
800.933.2839 x251
Feb 01, 2010 | Symbol LS2208-7AZK0100S Handheld
Reading codebars
A solution to your problem would be to use usb cable to connect the scanner to the POS system. I have had a similar issue in the past where the IBM pos system did not like the cable that the customer had and we've got around this by using usb instead.
I hope this helps you although it may not be the kind of answer that you were looking for,
Mar 24, 2009 | Symbol LS2208 Handheld
Can't install Symbol LS2208 barcode scanner on a PC (Wedge cable)
You will need to scan the barcode that configures the LS scanner to use keyboard wedge or even the set all defaults barcode. You will be able to find both of this on the product reference guide that you can download from www.symbol.com in the support page.
Mar 14, 2009 | Symbol LS2208 Handheld
I have an LS4071 with an RL474 base. The cable has the PS2 Keyboard end. Scanner gets a good scan but no data goes into the computer. Testing with notepad open to receive the scan.
When I connected this scanner (purchased at a great discount through eBay) to my computer using the keyboard wedge (with a ps2 connection - the round connector) I received the error message that my computer could not recognize this external hardware. I went to barcodediscount.com and ordered the usb connector for this scanner as usb connections are usually recognized. The part # for this connector is STI85-0200R. It cost 72.55 with shipping, but I received the scanner at such a wonderful price that I thought I'd chance it and try it with a usb rather than a keyboard wedge connector.
The computer immediately recognized the usb connection, and the usb connector comes with a manual with codes to enable proper scanning, but still no luck getting the data into the computer. So I called Symbol's technical support department. The technician told me to remove the rubber "boot" at the bottom of the hand held scanner (not the scanner base) by pulling on the front of it (where the 2 little round circles are). It's tough to remove, but keep at it. Then gently remove the battery and unplug it, then plug it back in and reattach the base. He said this would reset the battery. Voila!!!! Sucess!!!!
If your scanner's keyboard wedge connection is recognized (a little popup window will say that it is a Symbol barcode scanner and that it is installed and ready to use), try taking the battery out and putting it back in to reset it. Hopefully this will also work for you. Symbol's technical support # is (800) 722-6234.
Mar 11, 2009 | Symbol LS 4071 Handheld
LS2208 works - Keyboard does not
Check that the wedge is good. It is basically a hybrid spltter that powers both the scanner and the keyboard.
USB keyboard?
If so, you may want to go direct to either a serial port or a USB direct connection
Feb 24, 2009 | Symbol LS2208 Handheld
Scanner doesn't turn on
Hello Loverboy,
the scanner turns on automatically as he he receives power from the host interface.
Please check the cables and connection. For RS232 interface would you need an external power supply. USB can power the scanner without external power supply. By Keyboard Wedge installation please connnect also the Keyboard.
Nov 09, 2008 | Symbol LS2208 Handheld
SCANNING PROBLEMS
We are major Symbol/Motorola dealers...I can help. I don't understand your question. (By the way, by changing the cable on your keyboard wedge models, you can also use them on the USB ports. Give me a call at 1-866-306-7226, or you can also contact the Help Desk at 1-800-653-5350
Cheers.
Bill Matisz,
qdata inc.
Edmonton, AB
Mar 03, 2008 | Symbol LS2208 Handheld
Datalogic Dragon D101
You could use a ps2 splitter cable to connect both the barcode scanner and the keyboard to the pc. You would also have to use the correct scanner codes to ensure that the scanner is configured properly. Alternatively, you could try connecting the scanner with only the ps2 to usb and miss out the extension cable to determine if that is the problem. If the scanner is a ps2 wedge scanner, it will need reprogrammed with the correct scanner codes for usb.
Aug 28, 2007 | Datalogic Dragon D101 (902151240) Portable...
Symbol LS2208 Handheld Logo
1,036 people viewed this question
Top Symbol Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Greg Cann
Greg Cann
Michael
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
