1.
Make sure the printer is on.
2.
Open the printer cover. The print cartridge carrier moves and stops at the
loading position, unless the All-in-One is busy.
Note: If
the carrier does not automatically move to the center, turn off the
printer/unplug the printer from the power source and then slide the carrier to
the center.
3.
Remove both cartridges from the carrier.
4.
Close the printer cover.
5.
Rebrick (pull out the power supply, black box where
the power cord is plugged in at the back of the printer, and put it back after
30 seconds).
6.
When the printer turns on, reinsert one cartridge first.
7.
Close the printer cover and check for any errors.
8.
If no error appears, reinsert the other cartridge. Close the printer cover.
9.
Replace whichever cartridge is causing the error to appear with a new
cartridge.
If problem continues, please contact Lexmark Technical Support Center for additional assistance.
Front panel says COVER OPEN and no response to pressing any buttons. Help?
can't seem to find the switch, to which you refer
